    problem stop printing
    905
    • tom33undefined
      tom33 @chrishamm
      @chrishamm
      moteur.g
      while sensors.gpIn[9].value=0
      	M291 S2 R"warning" P"Défaut Moteur / Reset nécessaire"
      	M150 R255 U0 B0 S60 F0 Y31
      ATU
      while sensors.gpIn[0].value=1
      	M150 R255 U0 B0 S120 F0 Y31
      	M112
      	M291 S2 R"warning" P"ATU enfoncé / Armement nécessaire"
      led.g
      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
      	M150 R0 U0 B255 S17 F1
      	M150 R255 U255 B255 S7 F1
      	M150 R255 U0 B0 S7 F1
      	M150 R255 U0 B0 S89 F0
      elif state.status = "halted"
      	M150 R255 U0 B255 S120 F0
      elif state.status = "idle" ; state.status = "idle"
      	if sensors.gpIn[5].value=1
      		M150 R255 U100 B0 S89 F0
      	else
      		M150 R0 U255 B0 S89 F0
      elif state.status = "paused"
      	M150 R250 U250 B25 S89 F0
      elif state.status = "processing"
      	M98 P/macros/Machine/Led/02_Job.g
      else state.status = "busy"
      	M150 R255 U255 B255 S89 F0
      • tom33undefined
        tom33 @chrishamm
        @chrishamm
        I tryed to rename the daeamon file and remove the else but nothing change.
          Does Pause and Cancel in the DWC work?
          tom33undefined 2 Replies Last reply Reply Quote 0
          • tom33undefined
            tom33 @Phaedrux
            @phaedrux
            The pause / resume work but not the Stop.
            I try to remove the stop.g, resume.g pause.g and also the resurrect & resurrect.prologue but nothing change...
            • tom33undefined
              tom33 @Phaedrux
              @phaedrux @chrishamm
              I noticed something at the end of a job the printer do not execute the stop.g
                jay_s_uk @tom33
                @tom33 stop.g won't be ran unless you have M0 at the end of your job file
                tom33undefined 1 Reply Last reply Reply Quote 1
                • tom33undefined
                  tom33 @jay_s_uk
                  @jay_s_uk @chrishamm @Phaedrux
                  I found the problem. The problem occurs when my V & W axis are not home.
                  Like I use M584 P3 to hide them there is a way to avoid this ?
                    What exactly are your V and W axis? Are they axis which could be forced homed with G92?
                    tom33undefined 1 Reply Last reply Reply Quote 0
                    • tom33undefined
                      tom33 @Phaedrux
                      @phaedrux
                      I have two axis on the Y and Z, I use them to offset the position and make sure all my axis are perprendicular
                      anaghundefined 1 Reply Last reply Reply Quote 0
                      • anaghundefined
                        anagh @tom33
                        @tom33 @Phaedrux @dc42
                        I am facing the same issue. When one axis is not homed, the pause.g and resume.g files are not being run when I press the pause or resume buttons on the DWC. Has this been resolved or is this a bug of some sort? Please let me know. Thank you!
