    Suddenly extrusion buttons Extrude/Retract are grey!
    RepRapFirmware on other controllers
    1.5k
    • tecnoundefined
      tecno
      Can not get E0 to extrude, M302 P1 = still grey buttons
      Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
      • Rushmere3Dundefined
        Rushmere3D @tecno
        @tecno Do you have a tool selected?
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @Rushmere3D
          @rushmere3d
          As far as I can tell Yes
          deckingmanundefined jay_s_ukundefined Rushmere3Dundefined 3 Replies Last reply Reply Quote 0
          • deckingmanundefined
            deckingman @tecno
            @tecno I don't know if it will make any difference but try using upper case instead of lower case. i.e. M302 P1 then hit send, rather than m302 p1.
              jay_s_uk @tecno
              @tecno what version of RRF and DWC are you using?
                Rushmere3D @tecno
                @tecno Why is your tool T1 and not T0?
                • tecnoundefined
                  tecno @jay_s_uk
                  @jay_s_uk
                  • tecnoundefined
                    tecno @Rushmere3D
                    @rushmere3d
                    Old habit, all my printers have T1
                      jay_s_uk @tecno
                      @tecno can't remember if there were any bugs back with 3.3.0. Best update to 3.4.1
                      • tecnoundefined
                        tecno @tecno
                        NOT SOLVED
                        Error in writing config.g so I took an older one and edited necessary lines.
                        Got M302 P1 working and then lost connection and now I can not reach the printer.
                        • tecnoundefined
                          tecno @tecno
                          I have now updated DCW to 3.4.1 = still no M302 P1
                          Only TOOLS section was edited before all this with no filament feed occured.
                          https://forum.duet3d.com/topic/29618/superslicer-question/5
                          ; Configuration file for Fly-E3 (firmware version 3)
                          ; generated by RepRapFirmware Configuration Tool v3.3.1-LPC-STM32+7 on Mon Mar 14 2022 20:23:48 GMT+0100 (centraleuropeisk normaltid)
                          G90                                            ; send absolute coordinates...
                          M83                                            ; ...but relative extruder moves
                          M550 P"VORON"                                  ; set printer name
                          M669 K1                                        ; select CoreXY mode
                          M564 H0
                          M551 P"     "                                  ; set password
                          M552 S1                                        ; enable network
                          M586 P0 S1                                     ; enable HTTP
                          M586 P1 S0                                     ; disable FTP
                          M586 P2 S0                                     ; disable Telnet
                          M569 P0 S1                                     ; physical drive 0 goes forwards using default driver timings
                          M569 P1 S1                                     ; physical drive 1 goes forwards using default driver timings
                          M569 P2 S1                                     ; physical drive 2 goes forwards using default driver timings
                          M569 P3 S1									   ; physical drive 3 goes forwards using default driver timings
                          M584 X0 Y1 Z2 E3                               ; set drive mapping
                          M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                          M92 X80.00 Y80.00 Z400.00 E690.00              ; set steps per mm z400
                          M572 D0 S0.10								   ; PA
                          M566 X100.00 Y100.00 Z100.00 E600.00           ; set maximum instantaneous speed changes (mm/min)
                          M203 X5000.00 Y5000.00 Z2600.00 E7200.00       ; set maximum speeds (mm/min)
                          M201 X1500.00 Y1500.00 Z1500.00 E800.00        ; set accelerations (mm/s^2)
                          M906 X1250 Y1250 Z400 E800 I25   			   ; set motor currents (mA) and motor idle factor in per cent
                          M207 S1.5 F7200 Z0.2 						   ;firmware retraction
                          M84 S30                                        ; Set idle timeout
                          M208 X0 Y0 Z-3 S1                                ; set axis minima
                          M208 X120 Y100 Z110 S0                          ; set axis maxima
                          M574 X2 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
                          M574 Y2 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
                          M574 Z2 S1 P"zstop"                            ; configure active-high endstop for low end on Z via pin zstop
                          Z-Probe
                          M558 P0 H5 T6000 F1500:250 ;A5 ;S.25    ;
                          ;G31 P1000 X0 Y20 Z1.7
                          M557 X20:120 Y20:110 S30                       ; define mesh grid
                          M308 S0 A"Bed" P"bedtemp" Y"thermistor" T100000 B4092 		; configure sensor 0 as thermistor on pin bedtemp
                          M950 H0 C"bed" T0                              				; create bed heater output on bed and map it to sensor 0
                          M307 H0 B0 R1.109 C133.4 D4.22 S1.00 V0.0     				; disable bang-bang mode for the bed heater and set PWM limit
                          M140 H0                                        				; map heated bed to heater 0
                          M143 H0 S120                                   				; set temperature limit for heater 0 to 120C
                          M308 S1 A"Nozzle" P"e0temp" Y"thermistor" T100000 B4092  	; configure sensor 1 as thermistor on pin e0temp
                          M950 H1 C"e0heat" T1                          				; create nozzle heater output on e0heat and map it to sensor 1
                          M307 H1 B0 R2.424 C165.6 D6.10 S1.00 V0.0      				; disable bang-bang mode for heater  and set PWM limit
                          M143 H1 S280                                   				; set temperature limit for heater 1 to 280C
                          M950 F0 C"fan0"                                ; // PART FAN
                          M106 P0 S0 H-1								   ; P0 = fan0 S0 = Speed 0 H-1 = Disable Termostatic mode
                          M950 F1 C"fan1" 		                       ; // TOOL FAN
                          M106 P1 S1								       ; P1 = fan1 S1 = Speed 100%
                          M563 P1 H1 F0                                  ; P1 = tool1 H1 = heater1 F1 = fan1
                          G10 P1 X0 Y0 Z0                                ; set tool 0 axis offsets
                          G10 P1 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                          T1                                             ; select first tool
                          jay_s_ukundefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
                            jay_s_uk @tecno
                            @tecno have you updated the firmware too?
                            try switching to tool 0
                            • tecnoundefined
                              tecno @jay_s_uk
                              @jay_s_uk
                              No, will do
                              What lines in config needs to be changed for T0
                                jay_s_uk @tecno
                                @tecno said in Suddenly extrusion buttons Extrude/Retract are grey!:
                                change those to these
                                M563 P0 H1 F0                                  ; P1 = tool1 H1 = heater1 F1 = fan1
                                G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                                G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                                T0
                                • tecnoundefined
                                  tecno @jay_s_uk
                                  @jay_s_uk
                                  OK, done that. But still no M302 P1 = all gray buttons
                                  tecnoundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                                  • tecnoundefined
                                    tecno @tecno
                                    Updated FW = still same error
                                      deckingman @tecno
                                      @jay_s_uk
                                      If you've changed the tool from T1 to T0, then you need to use M302 P0 not M302 P1.
                                      Edit. Ignore that crap. Next time I'll try and engage my brain before typing.....
                                      jay_s_ukundefined tecnoundefined 2 Replies Last reply Reply Quote 0
                                        jay_s_uk @deckingman
                                        @deckingman i thought M302 was system wide? https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m302-allow-cold-extrudes
                                        P1 = allow, P0 = not allow?
                                        • tecnoundefined
                                          tecno @deckingman
                                          @deckingman said in Suddenly extrusion buttons Extrude/Retract are grey!:
                                          @jay_s_uk
                                          2022-08-18 12:57:49	M302
                                          Cold extrusion is forbidden (use M302 P1 to allow it), min. extrusion temperature 160.0C, min. retraction temperature 90.0C
                                          2022-08-18 12:57:39	M302 P0
                                            deckingman @jay_s_uk
                                            @jay_s_uk said in Suddenly extrusion buttons Extrude/Retract are grey!:
                                            Oh crap - you are right of course - more caffeine needed 🙂
                                            tecnoundefined 1 Reply Last reply Reply Quote 1
