    Suddenly extrusion buttons Extrude/Retract are grey!
    RepRapFirmware on other controllers
    1.4k
    • tecnoundefined
      tecno @jay_s_uk
      @jay_s_uk
      • tecnoundefined
        tecno @Rushmere3D
        @rushmere3d
        Old habit, all my printers have T1
        tecnoundefined 1 Reply Last reply Reply Quote 0
          jay_s_uk @tecno
          @tecno can't remember if there were any bugs back with 3.3.0. Best update to 3.4.1
          • tecnoundefined
            tecno @tecno
            NOT SOLVED
            Error in writing config.g so I took an older one and edited necessary lines.
            Got M302 P1 working and then lost connection and now I can not reach the printer.
            • tecnoundefined
              tecno @tecno
              I have now updated DCW to 3.4.1 = still no M302 P1
              Only TOOLS section was edited before all this with no filament feed occured.
              https://forum.duet3d.com/topic/29618/superslicer-question/5
              ; Configuration file for Fly-E3 (firmware version 3)
              ; generated by RepRapFirmware Configuration Tool v3.3.1-LPC-STM32+7 on Mon Mar 14 2022 20:23:48 GMT+0100 (centraleuropeisk normaltid)
              G90                                            ; send absolute coordinates...
              M83                                            ; ...but relative extruder moves
              M550 P"VORON"                                  ; set printer name
              M669 K1                                        ; select CoreXY mode
              M564 H0
              M551 P"     "                                  ; set password
              M552 S1                                        ; enable network
              M586 P0 S1                                     ; enable HTTP
              M586 P1 S0                                     ; disable FTP
              M586 P2 S0                                     ; disable Telnet
              M569 P0 S1                                     ; physical drive 0 goes forwards using default driver timings
              M569 P1 S1                                     ; physical drive 1 goes forwards using default driver timings
              M569 P2 S1                                     ; physical drive 2 goes forwards using default driver timings
              M569 P3 S1									   ; physical drive 3 goes forwards using default driver timings
              M584 X0 Y1 Z2 E3                               ; set drive mapping
              M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z400.00 E690.00              ; set steps per mm z400
              M572 D0 S0.10								   ; PA
              M566 X100.00 Y100.00 Z100.00 E600.00           ; set maximum instantaneous speed changes (mm/min)
              M203 X5000.00 Y5000.00 Z2600.00 E7200.00       ; set maximum speeds (mm/min)
              M201 X1500.00 Y1500.00 Z1500.00 E800.00        ; set accelerations (mm/s^2)
              M906 X1250 Y1250 Z400 E800 I25   			   ; set motor currents (mA) and motor idle factor in per cent
              M207 S1.5 F7200 Z0.2 						   ;firmware retraction
              M84 S30                                        ; Set idle timeout
              M208 X0 Y0 Z-3 S1                                ; set axis minima
              M208 X120 Y100 Z110 S0                          ; set axis maxima
              M574 X2 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
              M574 Y2 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
              M574 Z2 S1 P"zstop"                            ; configure active-high endstop for low end on Z via pin zstop
              Z-Probe
              M558 P0 H5 T6000 F1500:250 ;A5 ;S.25    ;
              ;G31 P1000 X0 Y20 Z1.7
              M557 X20:120 Y20:110 S30                       ; define mesh grid
              M308 S0 A"Bed" P"bedtemp" Y"thermistor" T100000 B4092 		; configure sensor 0 as thermistor on pin bedtemp
              M950 H0 C"bed" T0                              				; create bed heater output on bed and map it to sensor 0
              M307 H0 B0 R1.109 C133.4 D4.22 S1.00 V0.0     				; disable bang-bang mode for the bed heater and set PWM limit
              M140 H0                                        				; map heated bed to heater 0
              M143 H0 S120                                   				; set temperature limit for heater 0 to 120C
              M308 S1 A"Nozzle" P"e0temp" Y"thermistor" T100000 B4092  	; configure sensor 1 as thermistor on pin e0temp
              M950 H1 C"e0heat" T1                          				; create nozzle heater output on e0heat and map it to sensor 1
              M307 H1 B0 R2.424 C165.6 D6.10 S1.00 V0.0      				; disable bang-bang mode for heater  and set PWM limit
              M143 H1 S280                                   				; set temperature limit for heater 1 to 280C
              M950 F0 C"fan0"                                ; // PART FAN
              M106 P0 S0 H-1								   ; P0 = fan0 S0 = Speed 0 H-1 = Disable Termostatic mode
              M950 F1 C"fan1" 		                       ; // TOOL FAN
              M106 P1 S1								       ; P1 = fan1 S1 = Speed 100%
              M563 P1 H1 F0                                  ; P1 = tool1 H1 = heater1 F1 = fan1
              G10 P1 X0 Y0 Z0                                ; set tool 0 axis offsets
              G10 P1 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
              T1                                             ; select first tool
              jay_s_ukundefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
                jay_s_uk @tecno
                @tecno have you updated the firmware too?
                try switching to tool 0
                • tecnoundefined
                  tecno @jay_s_uk
                  @jay_s_uk
                  No, will do
                  What lines in config needs to be changed for T0
                    jay_s_uk @tecno
                    @tecno said in Suddenly extrusion buttons Extrude/Retract are grey!:
                    change those to these
                    M563 P0 H1 F0                                  ; P1 = tool1 H1 = heater1 F1 = fan1
                    G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                    G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                    T0
                    • tecnoundefined
                      tecno @jay_s_uk
                      @jay_s_uk
                      OK, done that. But still no M302 P1 = all gray buttons
                      tecnoundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                      • tecnoundefined
                        tecno @tecno
                        Updated FW = still same error
                          deckingman @tecno
                          @jay_s_uk
                          If you've changed the tool from T1 to T0, then you need to use M302 P0 not M302 P1.
                          Edit. Ignore that crap. Next time I'll try and engage my brain before typing.....
                          jay_s_ukundefined tecnoundefined 2 Replies Last reply Reply Quote 0
                            jay_s_uk @deckingman
                            @deckingman i thought M302 was system wide? https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m302-allow-cold-extrudes
                            P1 = allow, P0 = not allow?
                            • tecnoundefined
                              tecno @deckingman
                              @deckingman said in Suddenly extrusion buttons Extrude/Retract are grey!:
                              @jay_s_uk
                              2022-08-18 12:57:49	M302
                              Cold extrusion is forbidden (use M302 P1 to allow it), min. extrusion temperature 160.0C, min. retraction temperature 90.0C
                              2022-08-18 12:57:39	M302 P0
                                deckingman @jay_s_uk
                                @jay_s_uk said in Suddenly extrusion buttons Extrude/Retract are grey!:
                                Oh crap - you are right of course - more caffeine needed 🙂
                                tecnoundefined 1 Reply Last reply Reply Quote 1
                                • tecnoundefined
                                  tecno @deckingman
                                  I hope I have finally found the error, did run RRF Config Tool and copied the config.g and now it looks lite it is working. Do have to finetune motorparameters. I can not see any differences other than speeds.
                                  Will report my findings.
                                  So it looks like writing data on µSD card is somehow corrupted. Is it possible the write process is too fast and no CRC or whatever to verify is done?
                                  deckingmanundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
                                    deckingman @tecno
                                    ................ Is it possible the write process is too fast and no CRC or whatever to verify is done?
                                    In DWC - Settings - Machine Specific, there is a toggle entitled "Use CRC32 checksums for uploads" or some such. Make sure it's "On".
                                    • tecnoundefined
                                      tecno @deckingman
                                      @deckingman
                                      Has always been ON
                                      • gloomyandyundefined
                                        gloomyandy @tecno
                                        What makes you think there is an SD card corruption? Do you have an example of a corrupt file?
                                        What make and size of SD card are you using? Try inserting it in a Windows PC and checking it for errors.
                                        • tecnoundefined
                                          tecno @gloomyandy
                                          @gloomyandy
                                          Hi Andy,
                                          Config.g was damaged obviously as it did work with a new copy written on card.
                                          32G from Sandisk, no errors in Win.
                                            gloomyandy
                                            @tecno So do you have the damaged version of the file? If so please post it....
