Mistake True bed levelling G32
@sgk says it all really. the z probe readings are the same within the tolerance band thats set. I'm not sure how good the IR probe is with PEI surfaces
@jay_s_uk with the duet 2 card I never had a problem with the pei
@sgk
@jay_s_uk merci pour tout jay_s
@sgk
I found the problem because of daylight, I don't know why with duet 2 it never does it to me and with duet 3 it does it to me. but even if I put a white sheet on the pei it does it do the same error. -
@sgk IR probes aren't great with direct sunlight
@jay_s_uk
even with a white sheet. What can you advise me specifically? -
@sgk i've never got on with them when i've tried them
@jay_s_uk and what probe do you have?
@sgk on my machines now I use Euclid probes https://euclidprobe.github.io/ that can be picked up when used.
I have in the past used BFPtouches https://www.thingiverse.com/thing:2890290
I'm not a fan of normal bltouches as they seem to cause too many issues for people.
inductive can be good but you need to be able to adjust for temperature affecting the readings -
@jay_s_uk I agree with you the ones I had before I had bltouch and I also had only problems he only had the ir that it was fine but now that I am in duet 3 only problems too
@jay_s_uk
this Euclid probes looks good to me but too complicated for me already that I have trouble with an ir probe or bltouch -
@sgk you can also look at something like the klicky or unklicky
@jay_s_uk
it's magnetized? -
@sgk yes. klicky, unklicky and euclid all use magnets for attaching the bottom half of the probe
@jay_s_uk it's too good this idea I imagine that it is necessary to program the printer and what to get the probe really quite complicated this part
@sgk the printer uses the probe as a standard switch.
there are example macros required for picking up and docking the probe so its fairly simple to implement -
@jay_s_uk ha but that's really what you're telling me, do you have any idea by chance where we could find it's macros?
