Euclid facility
@phaedrux
I deleted my deploy and retract and I didn't save -
@sgk said in Euclid facility:
retractprobe.g homez.g homeall.g deployprobe.g config.g bed.g
want the files in raw or it goes in ZIP
Good thing you uploaded them here.
@phaedrux yes nice
it works but not very well every time the probe feels it comes home
I will make a video
and above all it does not balance the left and right bed
@sgk Have you changed bed.g to what @Phaedrux suggested? it should now look like this -
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by Ben Levi - BLV developer as a basic version M561 ; clear any bed transform G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G28 ; home all M401 ; deploy Z probe (omit if using bltouch) G30 P0 X10 Y175 Z-99999 ; probe near a leadscrew, half way along Y axis G30 P1 X330 Y175 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors M402 ; retract probe (omit if using bltouch) M291 P"Leveling finished !" R"Probing.." S1 T2 once you have done that go into your deployprobe.g find the line that says -
G0 X170 Y170 G3000 ; move to the center of the bed
and change it to read to read, to correct the warning -
G0 X170 Y170 F3000 ; move to the center of the bed
hello to all of you it's finally starting to work thank you to all of you. I have to settle because the probe often comes home before doing g32 or g29. but it works it works thank you thank you thank you you're really king
thank you to all and to the group
