    Euclid facility
    91
    4.7k
    • A Former User?
      A Former User @Nurgelrot
      @nurgelrot that's my Deploy
      ; uncomment next line to echo the probe deploy state
      ; echo "Object Model Deployuser token =" ^sensors.probes[0].deployedByUser
      M564 H1 S0 ; Allow movement BEYOND axes boundaries (for Y to reach probe dock)
      G91 ; relative positioning
      echo "Lift Z in advance of deploy"
      G0 H2 Z15 F3000 ; move Z 15 for clearance above dock.
      ; ; need to figure out some safety check on this
      G90 ; absolute positioning
      ; uncomment next line to echo the probe value
      ; echo "Probe Value =" ^sensors.probes[0].value[0]
      if sensors.probes[0].value[0]!=1000 ; if sensor is value other than 1000 do this
      ; echo "deployuser token = " ^sensors.probes[0].deployedByUser
      ; echo "Probe State = " ^sensors.probes[0].value[0]
      abort "deployprobe start value Probe already picked up. Manually return probe to the dock"
      ; if we're here we know it's becasue the above is true which I assume is because you have an NC switch as a probe.
      ; echo "Passed first logic test to deploy probe"
      ;Preflight position is X100 Y8.5
      ;Dock Side position is at X30 Y8.5
      ;Docked probe postion is at X0 Y8.5
      ;Dock exit point is at X0 Y40
      ;Dock Re-Entry Staging Position is at X0 Y70
      ;Probe Ready Position X150 Y150
      ; echo "Probe Pickup macro running"
      G0 X100 Y8.5 F6000 ; move to Preflight Position
      M400 ; wait for moves to finish
      G0 X30 Y8.5 F6000 ; move to Dock Side dock location
      ; uncomment next line to echo the probe deplot state
      ; echo "Object Model Deployuser token (before while loop) = " ^sensors.probes[0].deployedByUser
      G0 X0 Y8.5 F3000 ; move over Dock
      G4 P500 ; pause 0.5 seconds
      G0 X0 Y100 F300 ; slide probe out of dock - slowly
      G0 X170 Y170 F3000 ; move to re-entry position
      echo "Probe Pickup complete"
      ; uncomment to echo the probe deploy state
      ; echo "Object Model Deployuser token (after while loop) = " ^sensors.probes[0].deployedByUser
      G0 X170 Y170 G3000 ; move to the center of the bed
      if sensors.probes[0].value[0]!=0
      echo "Object Model Deployuser token (in abort if section)= " ^sensors.probes[0].deployedByUser
      abort "Deployprobe endvalue not 0 Probe not picked up! Deployt cancelled."
      M564 H1 S1 ; Restrict movement to within axes boundaries (for normal Y movement)
      echo "Macro deployprobe.g complete"
      • A Former User?
        @nurgelrot my Retract
        echo "running retractprobe.g macro"
        ; Preflight position is X100 Y0
        ; Dock Side position is at X30 Y0
        ; Docked probe postion is at X0 Y0
        ; Dock exit point is at X65 Y0
        ; Dock Re-Entry Staging Position is at X0 Y70
        ; Probe Ready Position X150 Y150
        M564 S0 ; allow beyond limit axis to print area
        if sensors.probes[0].value[0]!= 0
        abort "retractprobe: Probe not currently picked up!"
        ; echo "pass first logic loop"
        ; uncomment next line to echo the probe value and probe deploy state
        G0 X0 Y70 F3000 ; move to ready position
        G0 X0 Y30 F3000 ; move to the entry position for the dock
        G0 X0 Y8.5 F300 ; move into the dock position
        G4 P250 ; pause 250 usecs
        ;G0 X0 Y8.5 F6000 ; move to the side adjacent to the dock swiping the probe off
        ;G0 X170 Y170 F3000 ; move to the side adjacent to the dock swiping the probe off
        G0 X170.0 Y170.0 F6000 ; move to the center of the bed
        M564 S1 ; limit axis to print area
        ; echo "complete movement commands"
        if sensors.probes[0].value[0]!= 1000
        abort "retractprobe.g Probe not correctly dropped off in dock!"
        echo "Macro retractprobe.g complete"
        • A Former User?
          @nurgelrot
          https://github.com/Nurgelrot/Voron-2.4r2-RRF-configs
          ok ok i just saw the config you sent me from voron i understand better than my config there are too many things that are not correct
          • A Former User?
            A Former User @PaulHew
            @paulhew
            the config you sent me are examples where I must copy certain things?
            I'm really sorry, I don't understand very well, what should I do?
            thank you for your understanding
            • A Former User?
              A Former User @A Former User
              my bed
              • A Former User?
                • A Former User?
                  config.g
                  ; ================ General preferences ============
                  M550 P"duet3" ; set printer name
                  M669 K1 ; select CoreXY mode
                                                ; ================ Network ========================
                  M552 S1 P192.168.1.116 ; enable network and acquire dynamic address via DHCP
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S0 ; disable FTP
                  M586 P2 S0 ; disable Telnet
                                             ; ================ Drives mapping =================
                  M569 P1 S0 ; physical drive 0.1 goes forwards - X driver
                  M569 P2 S0 ; physical drive 0.2 goes forwards - Y driver
                  M569 P3 S1 ; physical drive 0.3 goes forwards - Z1 Right driver
                  M569 P4 S0 ; physical drive 0.4 goes forwards - Z2 Left driver
                  M569 P0 S1 ; physical drive 0.0 goes forwards - extruder driver
                  M584 X1 Y2 Z4:3 E0 ; set drive mapping
                                                     ; ================ Drives settings ================
                  M92 X200.00 Y200.00 Z800.00 E693.55 ; set steps per mm - for Matrix extruder:E324.214
                  M566 X500 Y500 Z800 E600 ; Set maximum instantaneous speed changes (Jerk) (mm/min)
                  M203 X20000 Y20000 Z600 E3600 ; Set maximum speeds (mm/min)
                  M201 X1000 Y1000 Z100 E600 ; Set accelerations (mm/s^2)
                  M906 X1350 Y1350 Z1200 E700 I10 ; Set motor currents (mA) and motor idle factor in per cent
                  M84 S60 ; Set idle timeout
                                               ; ================ Independent Z leveling (original 2 z-axis) =================
                  M671 X-45.0:364.0 Y165.0:165.0 S5.0 ;bed compensation
                                                  ; ================ Axis Limits ====================
                  M208 X-3.50 Y0 Z0 S1 ; Set axis minima
                  M208 X330 Y320 Z350 S0 ; Set axis maxima
                                               ; ================ Endstops =======================
                  M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
                  M574 Y2 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in
                  M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                                                 ; ================ Z-Probe ========================
                  ;M558 P8 C"io2.in" A5 H5 F120 T15000 ; set Z probe type to unmodulated and the dive height + speeds (for Mini IR sensor M558 P8 C"io2.in" A2 H5 F120 T15000)
                  ;M558 K0 P5 C"io8.in" H8 F300 60 T9000 A3 S0.01
                  M558 K0 P5 C"^io2.in" H8 F300 60 T9000 A3 S0.01 ;
                  ;M558 K0 P5 C"^io2.in" H8 F300 T9000 A3 S0.01 ; K0 for probe 0, P5 for NC switch, C for input pin,
                  ;G31 P50 X-1 Y-20 Z1.444 ; Set Z probe trigger value, offset and trigger height
                  G31 K0 P500 X-27.955 Y-18.716 Z1.033 ; CHECK for LOOSE things first! set Z probe trigger
                  M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
                  M557 X20:270 Y20:270 P3 ; Define mesh grid
                                                    ; ================ Heaters ==============================================
                  M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
                  M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 (if NOT using SSR - delete Q10)
                  M307 H0 R0.312 K0.313:0.000 D13.50 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
                  M143 H0 S100 ; set temperature limit for heater 0 to 100C
                  M308 S1 P"temp1" Y"thermistor" A"Hotend" T107537 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                  M950 H1 C"out2" T1 ; create nozzle heater output on out1 and map it to sensor 1
                  M307 H1 R2.451 K0.445:0.102 D5.36 E1.35 S1.00 B0 V24.1 ; disable bang-bang mode for heater and set PWM limit
                                             ; ================ Fans & Lights ==================
                  M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                  M106 P0 S0 H1 T35 ; set fan 0 value. Thermostatic control is turned on
                  M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
                  M106 P1 S0 H-1 C"Layers Fan" ; set fan 1 value. Thermostatic control is turned off
                  M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency (lights)
                  M106 P2 S0.2 H-1 C"Lights" ; set fan 2 value. Thermostatic control is turned off (lights)
                                                    ; ================ Tools ==========================
                  M563 P0 D0 H1 F1 ; define tool 0
                                              ; ===================== Custom settings ====================
                  M572 D0 S0.05 ;pressure advance Set bowden extruder elasticity compensation for E0
                  M207 S1.5 F3600 Z0.01 ; Set firmware retraction parameters
                  M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons
                  ; ================ Miscellaneous ==================
                  ;M575 P1 S1 B57600 ; enable support for PanelDue
                  • A Former User?
                    there is something that I did not understand guys is that I must put the command m 401 and m 402 in deploy and retract or in home z and bed?
                      @sgk you should only need to use M401 at the start of bed.g and M402 at the end. That will pick up the probe once and put it down once only, instead before/after every probe point. Also they are useful for testing pickup and release of the probe.
                      • A Former User?
                        A Former User @dc42
                        OK i understand thank you 😀👍
                        jumpedwithbothfeetundefined Nurgelrotundefined 2 Replies Last reply Reply Quote 0
                        • jumpedwithbothfeetundefined
                          jumpedwithbothfeet @A Former User
                          @sgk can you post your Homeall.g, homez.g, deployprobe.g, retractprobe.g, and bed.g put these in quotes (thats the little </> button above the reply box) I suspect your using a mish mash of different configurations which is causing the issue as @DC42 is alluding too.
                          6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                          • A Former User?
                            A Former User @jumpedwithbothfeet
                            @jumpedwithbothfeet
                            hello it's true that I'm a little lost. thank you all for your patience and your help.
                            retractprobe.g homez.g homeall.g deployprobe.g config.g bed.g
                            sinned6915undefined jumpedwithbothfeetundefined 2 Replies Last reply Reply Quote 0
                            • sinned6915undefined
                              sinned6915 @A Former User
                              @sgk all of this is pretty well addressed in the Euclid docs.
                              https://euclidprobe.github.io/06_macros_overview.html
                              there are annotated picures and macro files.
                              if you need more help, the euclid discord might be faster, i dont come here often.
                              and just so you know, Euclid does not like it when you call it klicky 😉
                              • Nurgelrotundefined
                                Nurgelrot @A Former User
                                This post is deleted!
                                  @sgk in bed.g comment out M401 and M402 just like below and try it again 🙂
                                  ; bed.g
                                  ; generated by Ben Levi - BLV developer as a basic version
                                  M561 												; clear any bed transform
                                  G1 H2 Z5 F6000   									; lift Z relative to current position
                                  G28 												; home all
                                  ;G30 P0 X10 Y175 Z-99999 							; probe near a leadscrew, half way along Y axis
                                  ;G30 P1 X330 Y175 Z-99999 S2 						; probe near a leadscrew and calibrate 2 motors
                                  G29 S0                                              ; probe the bed and enable compensation
                                  M291 P"Leveling finished !" R"Probing.." S1 T2
                                  G1 Y8.5 F6000 ; Pick Up Klicky
                                  G1 X20 F2000 ;
                                  G1 X0 F1000 ; Pick Up Klicky
                                  G1 Y30 F1000 ;
                                  G1 Y50 F6000 ; Pick Up Klicky
                                  ;M401 ; deploy Z probe (omit if using bltouch)
                                  ;M402 ; retract probe (omit if using bltouch)
                                  G1 Y250 F6000 ; Drop Klicky
                                  G1 X0 F6000 ; Drop Klicky
                                  G1 Y8.5 F6000 ; Drop Klicky
                                  G1 X170 F6000 ; Drop Klicky
                                  G1 Y170 F6000 ;
                                  • A Former User?
                                    @jumpedwithbothfeet Ha OK I will modify and I will let you know thank you😀👍
                                    jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                                      @sgk I have just realised you should also move the M291 to the bottom of the file and also comment G29 S0 out, just like this -
                                      ; bed.g
                                      G28 												; home all
                                      ;G29 S0                                              ; probe the bed and enable compensation
                                      ;M291 P"Leveling started!" R"Probing.." S1 T2
                                      G1 X20 F2000 ;
                                      G1 Y30 F1000 ;
                                      G1 Y170 F6000 ;
                                      A Former User? 2 Replies Last reply Reply Quote 0
                                      • A Former User?
                                        @jumpedwithbothfeet yes OK 👍😀thank you
                                        • A Former User?
                                          @jumpedwithbothfeet The m 401 and m 402 I have to leave like this with [;]Screenshot_20220914_123858.jpg
                                            @sgk yes that’s the quickest way to get you up and running, but it’s not the conventional way, it all depends on how you what to use your Euclid probe, I think most people would use M401 and M402 in which case you would need to remove the G1 codes from bed.g, homeall.g, and homez.g, see how you get on, the best thing about rrf is it’s flexible, there are multiple ways of achieving the same thing. 😁
