    Automatic Emergency Stop
    1.1k
    • Sculpt Fabricatorundefined
      Sculpt Fabricator
      Duet WiFi + DueX5 3.3.0
      Printer has been running for weeks with no issues. We started a new print and shortly after starting the print we get,
      Emergency stop, attemping to reconnect...
      and then
      Cancelled printing file 0:/gcodes/trunk arm slots.gcode, print time was 0h 13m
      Emergency Stop! Reset the controller to continue.
      We tried printing a previous print to make sure it wasn't slicer related but got the same results.
      We are getting no faults or warnings, and we do not have any other emergency stop buttons connected. we just have the one on the duet touch screen.
      any help would be much appreciated, thank you
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Sculpt Fabricator
        @sculpt-fabricator can you post an output of M122 after the reset?
        also a sample file would be helpful
          Sculpt Fabricator
          9/13/2022, 6:59:40 AM m122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
          Board ID: 08DLM-996RU-N85T0-6J1D4-3SJ6K-TAVZR
          Used output buffers: 3 of 24 (24 max)
          Static ram: 23876
          Dynamic ram: 77308 of which 12 recycled
          Never used RAM 10364, free system stack 132 words
          Tasks: NETWORK(ready,14.2%,225) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,313) DUEX(notifyWait,0.0%,24) MAIN(running,85.7%,441) IDLE(ready,0.1%,29), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:30:38 ago, cause: software
          Last software reset at 2022-09-13 06:29, reason: User, GCodes spinning, available RAM 10364, slot 1
          Error status: 0x0c
          Aux0 errors 0,1,0
          Step timer max interval 0
          MCU temperature: min 34.6, current 35.0, max 36.9
          Supply voltage: min 22.7, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/14, heap memory allocated/used/recyclable 2048/246/16, gc cycles 0
          Driver 0: position 0, standstill, SG min/max 0/0
          Driver 1: position 57500, standstill, SG min/max 0/71
          Driver 2: position 13866, standstill, SG min/max not available
          Driver 5: position 0, standstill, SG min/max 0/0
          Driver 6: position 0, standstill, SG min/max 0/278
          Driver 7: position 0, standstill, SG min/max 0/339
          Driver 8: position 0, standstill, SG min/max 0/321
          Driver 9: position 0, standstill, SG min/max 0/283
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2022-09-13 06:59:39
          Slowest loop: 10.52ms; fastest: 0.18ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.9ms, write time 0.0ms, max retries 0
          DMs created 83, maxWait 3589ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 7, completed moves 7, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
          === AuxDDARing ===
          Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
          Heater 0 is on, I-accum = 0.2
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Filament sensors ===
          Extruder 0 sensor: no data received
          Extruder 1 sensor: no data received
          === DueX ===
          Read count 1, 0.03 reads/min
          === Network ===
          Slowest loop: 82.42ms; fastest: 0.00ms
          HTTP sessions: 2 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.26
            WiFi MAC address ec:fa:bc:5b:41:b9
            WiFi Vcc 3.38, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 24504
            WiFi IP address 192.168.5.101
            WiFi signal strength -64dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
            @sculpt-fabricator i would suggest upgrading to 3.4.1 and seeing if it happens again
            Sculpt Fabricatorundefined 1 Reply Last reply Reply Quote 0
              Sculpt Fabricator @jay_s_uk
              @jay_s_uk
              Ok upgrades to 3.4.1
              started a print, it made it 22 min into the print and it Emergency stopped
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.1 (2022-06-01 21:05:28) running on Duet WiFi 1.02 or later + DueX5
              Used output buffers: 10 of 26 (26 max)
              Static ram: 23860
              Dynamic ram: 77116 of which 12 recycled
              Never used RAM 8236, free system stack 174 words
              Tasks: NETWORK(ready,13.2%,242) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) DUEX(notifyWait,0.0%,24) MAIN(running,86.3%,440) IDLE(ready,0.4%,30), total 100.0%
              Last reset 00:03:14 ago, cause: software
              Last software reset at 2022-09-13 09:00, reason: User, GCodes spinning, available RAM 8236, slot 0
              Error status: 0x04
              Aux0 errors 0,0,0
              MCU temperature: min 33.0, current 33.6, max 34.3
              Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
              Heap OK, handles allocated/used 99/14, heap memory allocated/used/recyclable 2048/230/0, gc cycles 0
              Events: 0 queued, 0 completed
              Driver 0: standstill, SG min n/a
              Driver 1: standstill, SG min n/a
              Driver 2: standstill, SG min n/a
              Driver 3: standstill, SG min n/a
              Driver 4: standstill, SG min n/a
              Driver 5: standstill, SG min n/a
              Driver 6: standstill, SG min n/a
              Driver 7: standstill, SG min n/a
              Driver 8: standstill, SG min n/a
              Driver 9: standstill, SG min n/a
              Driver 10:
              Driver 11:
              Date/time: 2022-09-13 09:03:54
              Slowest loop: 10.23ms; fastest: 0.20ms
              === Storage ===
              SD card longest read time 3.5ms, write time 0.0ms, max retries 0
              DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              === AuxDDARing ===
              Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
              Segments left: 0
              Code queue is empty
              === DueX ===
              Read count 1, 0.31 reads/min
              === Network ===
              Slowest loop: 79.94ms; fastest: 0.00ms
              - WiFi -
              WiFi flash size 4194304, free heap 24944
              WiFi signal strength -63dBm, mode 802.11n, reconnections 0, sleep mode modem
              jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                @sculpt-fabricator can you upload the print file?
                @dc42 any insight on the reset?
                  @jay_s_uk
                  I have tried three different print files one of them we printed yesterday. The other two are new files we have not printed.
                  jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                    @sculpt-fabricator but can you upload a gcode file please
                      @sculpt-fabricator oh, and also your config.g
                        @jay_s_uk
                        I can get you the step file If you want
                        @dc24 I can reset it from the panel with the M999, rehome etc. and it back
                        to normal
                          @sculpt-fabricator the step file is no use, which is why i have asked for the gcode
                            @jay_s_uk
                            Config G -
                            ; General preferences_________________________________________________________
                            G21 														; dimentions in mm
                            G90                                             			; for X,Y,Z     use absolute coordinate values
                            M83                                             			; for E0,E1,etc use relative coordinate values
                            M111 S0 													; Debug off
                            M555 P2 													; Set output to look like Marlin
                            M575 P0 B57600 S2              								; communication parameters for USB serial
                            M575 P1 B57600 S1											; Set auxiliary serial port baud rate and require checksum (for PanelDue)
                            ; Network_____________________________________________________________________
                            M550 P"Big 60"                         						; set printer name
                            M552 S1                                        				; enable (S1) networking (WiFi)
                            M586 S1 P1 ;T0                 								; enable (S1) FTP    (P1) Disable TLS (T0)
                            M586 S1 P2 ;T0                								; enable (S1) Telnet (P2) Disable TLS (T0)
                            ; mode control variables _____________________________________________________
                            global g_probe_z_trigger = 1.752                            ; default - set as appropriate for the Z probe
                            global g_z_home            = 5                  ; can be used to always move Z to known height
                            global g_z_datum_set       = false              ; can be used to prevent unneeded setting of Z=0 datum
                            global g_map_mode          = "300 point"        ; determines which kind of height map is created/loaded
                            global g_probe_mode        = "two consecutive"  ; determines if z proving used consecutive or averaging
                            global g_level_mode        = "4 point"          ; determines if 3 or 4 points are used for leveling
                            global g_print_beg_prime   = 10                 ; default - set desired in filament config.g
                            global g_print_beg_retract = 0                  ; default - set desired in filament config.g
                            global g_print_end_retract = 0                  ; default - set desired in filament config.g
                            global g_print_end_mode    = "heat off"         ; determines if heaters are turned off when print is done
                            ; Drives_________________________________________________________________________
                            ;Main board______________________________________________________________________
                            M569 P0 S0                                                          ; Physical drive 0 . X1
                            M569 P1 S1                                                          ; Physical drive 1 . X2
                            M569 P3 S0                                                       	; Physical drive 3 . Main Extruder
                            M569 P4 S0                                                       	; Physical drive 4 . Secondary Extruder
                            ;Duex5 board_____________________________________________________________________
                            M569 P5 S0                                                       	; Physical drive 5 . Y
                            M569 P6 S0                                                       	; Physical drive 6 . Z1 (-188 , 656.5)
                            M569 P7 S0                                                       	; Physical drive 7 . Z2 (-188, -35.5)
                            M569 P8 S0                                                       	; Physical drive 8 . Z3 (658.6 , -35.5)
                            M569 P9 S0                                                       	; Physical drive 9 . Z4 (658.6, 656.5)
                            ;Settings_________________________________________________________
                            M584 X0:1 Y5 Z6:7:8:9  E3:4 P3								   	    ; Driver mapping
                            ;___________________________________________________________________
                            M350 X16 Y16 I1  		                            				; Configure microstepping with interpolation
                            M350 Z16 E16:16 I0              		                			; Configure microstepping without interpolation
                            M92 X100.00 Y100.00 Z2000.00 E425:300       				        ; Set steps per mm
                            M566 X300 Y500 Z100.00 E120.00:120.00  P1               		    ; Set maximum instantaneous speed changes (mm/min)
                            M203 X18000.00 Y18000.00 Z300.00 E1200.00:1200.00           		; Set maximum speeds (mm/min)
                            M201 X1000 Y1000 Z120.00 E250.00:250.00                  			; Set accelerations (mm/s^2)
                            M204 P500                                     			            ; Set print and travel accelerations  (mm/s^2)
                            M906 X1800 Y1800.00 E1000:1000  I40 					        	; Set motor currents (mA) and motor idle factor in per cent (E1270 per dyze)
                            M906 Z1800.00 I50 													; Set motor currents (mA) and motor idle factor in per cent
                            M84 S100                                          					; Set idle timeout - 100 seconds
                            M208 X0 Y0 Z-0.5 S1                               			 	    ; set axis minima
                            M208 X585 Y575 Z630 S0                          					; set axis maxima 580;580
                            M574 X1 S1 P"xstop + e0stop"                            	; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                            M574 Y2 S1 P"ystop"                            				; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                            ;M558 P9 C"^zprobe.in" H5 F120 T6000 A1 R1  				; set Z probe type to bltouch and the dive height + speeds
                            ;M950 S0 C"duex.pwm5"										; set probe pin
                            M98 P"config_probe.g"
                            M556 S50 X0 Y0 Z0		                               		; set orthogonal axis compensation parameters woher kommt der test wie wurde der Winkel bestimmt Unklar!
                            M376 H20													; stop z-leveling after 10 layers
                            ; Heaters___________________________________________________________
                            M140 H-1                                       				; disable heated bed (overrides default heater mapping)
                            ;E0_________________________________________________________________
                            M308 S0 P"spi.cs1" Y"rtd-max31865" A"Main Extruder"         ; create sensor number 1 as a PT100 sensor in first position daughterboard
                            M950 H0 C"e0heat"   T0                       		        ; create nozzle heater output on e0heat and map it to sensor 0
                            M307 H0 B0 R2.059 C461.5:461.5 D8.35 S1.00 V23.5            ; PID calibration
                            ;M307 H0 B0 R6.167 C268.6:268.6 D4.07 S1.00 V23.5
                            M143 H0 S1400                                    			; set temperature limit for heater 0 to 450C
                            ;E1_________________________________________________________________
                            M308 S1 P"spi.cs2" Y"rtd-max31865" A"Support Extruder"    	; create sensor number 2 as a PT100 sensor in sec position daughterboard
                            ;E4_________________________________________________________________
                            M308 S1 P"duex.e4temp" Y"thermistor" T100000 B4267   		; configure sensor 1 as thermistor on pin e1temp
                            M950 H5 C"duex.e4heat" T1                            		; create nozzle heater output on e4heat and map it to sensor 4
                            M143 H5 S120                                  			    ; set temperature limit for heater 1 to 120C
                            ; Fans & LED___________________________________________________________
                            M950 F0 C"fan0" Q500                            			; create fan 0 on pin fan0 and set its frequency
                            M106 P0 S0 H-1                                  			; set fan 0 value. Thermostatic control is turned on
                            M950 F1 C"fan1" Q500                            			; create fan 1 on pin fan1 and set its frequency
                            M106 P1 S0 H-1                                  			; set fan 1 value. Thermostatic control is turned on
                            M950 F2 C"fan2" Q500                            			; create air filter fan on fan 2 on pin fan2 and set its frequency
                            M106 P2 S0 H-1                                  			; set fan 2 value. Thermostatic control is turned on
                            M950 F7 C"!duex.fan7" Q500                            		; create LED on pin fan7 and set its frequency
                            M106 P7 S0 H-1                               				; Disable fan channel for LED
                            M106 P7 S255							                    ; remove ";" to set the LED to full brightness by default
                            M950 F3 C"duex.fan3" Q500                       			; create fan 3 on pin fan3 and set its frequency
                            M106 P3 S1 H-1                           					; set fan 3 value. Thermostatic control is turned on Bed relay to on
                            ; Tools______________________________________________________________
                            ;T0_________________________________________________________________
                            M563 P0 S"E0 Main" D0 H0 F0                  				; define tool 0
                            G10 P0 X0 Y0 Z0                                 			; set tool 0 axis offsets
                            G10 P0 R0 S265                                  			; set initial tool 0 active and standby temperatures to 0C
                            ;T1_________________________________________________________________
                            M563 P1 S"E1 Support" D1 H1 F1                				; define tool 1
                            G10 P1 X0 Y65 Z0                                			; set tool 1 axis offsets  Y-2 moves filament 2mm to back of machine     X-1 moves filament 1mm to the right
                            G10 P1 R0 S265                                    			; set initial tool 1 active and standby temperatures to 0C
                            ;T2____________________________________________________________________
                            ;T3___________________________________________________________________
                            M563 P3 S"CHAMBER TEMP" H5
                            G10 P3 R0 S40
                            ; Custom settings__________________________________________________
                            M950 J0 C"exp.e2stop"
                            M581 T1 P0 S0 R1
                            M591 D0 P7 C"e1stop" S1 L4.2 E10 R10:1000
                            M950 J1 C"exp.e3stop"
                            M581 T1 P1 S0 R1
                            M591 D1 P7 C"zstop" S1 L4.2 E10 R10:1000
                            ;M591 D0 P1 C"duex.e2stop" S1								; Regular filament sensor for E0
                            ;M591 D1 P1 C"duex.e3stop" S1								; Regular filament sensor for E1
                            M950 J2 C"duex.e4stop"                                      ; create Input Pin 2 on Zstop for the M581 command.
                            M581 P2 T0 S0 R0                                            ; Crash Detector  [Add-On]
                            M42 P2 S255 												; Start up air filter
                            ; Automatic power saving____________________________________________
                            M911 S21 R29.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"              ; Set voltage thresholds and actions to run on power loss. Power Failure Pause
                              @sculpt-fabricator also, does it reset if you simulate the job?
                                @sculpt-fabricator and have you always used global variables or have you only recently started to use them?
                                  @jay_s_uk I have never run a job simulate. I don't know how to do that ?
                                    @sculpt-fabricator right click on the job and simulate
                                      @jay_s_uk
                                      I haven't changed any g-code or any setting in 4 months, printer was working
                                      perfectly sense 3.3 update and getting all the code dialed in. Machine has been
                                      running 24/7 for 4 weeks
                                        @jay_s_uk
                                        It made it 100% thought simulation.
                                          @sculpt-fabricator not much we can do now until the reset map is looked at.
                                            droftarts administrators @Sculpt Fabricator
                                            @sculpt-fabricator said in Automatic Emergency Stop:
                                            Error status: 0x04
                                            Error 0x04 = Output buffer starvation, I think. I'd guess that your SD card is either full or damaged. Please check your SD card by running the commands here: https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#troubleshooting-sd-card-issues
                                            Sculpt Fabricatorundefined 1 Reply Last reply Reply Quote 1
