    Automatic Emergency Stop
    1.1k
      jay_s_uk @Sculpt Fabricator
      @sculpt-fabricator oh, and also your config.g
      Sculpt Fabricatorundefined 1 Reply Last reply Reply Quote 0
      • Sculpt Fabricatorundefined
        Sculpt Fabricator @jay_s_uk
        @jay_s_uk
        I can get you the step file If you want
        @dc24 I can reset it from the panel with the M999, rehome etc. and it back
        to normal
        jay_s_ukundefined 2 Replies Last reply Reply Quote 0
          @sculpt-fabricator the step file is no use, which is why i have asked for the gcode
            @jay_s_uk
            Config G -
            ; General preferences_________________________________________________________
            G21 														; dimentions in mm
            G90                                             			; for X,Y,Z     use absolute coordinate values
            M83                                             			; for E0,E1,etc use relative coordinate values
            M111 S0 													; Debug off
            M555 P2 													; Set output to look like Marlin
            M575 P0 B57600 S2              								; communication parameters for USB serial
            M575 P1 B57600 S1											; Set auxiliary serial port baud rate and require checksum (for PanelDue)
            ; Network_____________________________________________________________________
            M550 P"Big 60"                         						; set printer name
            M552 S1                                        				; enable (S1) networking (WiFi)
            M586 S1 P1 ;T0                 								; enable (S1) FTP    (P1) Disable TLS (T0)
            M586 S1 P2 ;T0                								; enable (S1) Telnet (P2) Disable TLS (T0)
            ; mode control variables _____________________________________________________
            global g_probe_z_trigger = 1.752                            ; default - set as appropriate for the Z probe
            global g_z_home            = 5                  ; can be used to always move Z to known height
            global g_z_datum_set       = false              ; can be used to prevent unneeded setting of Z=0 datum
            global g_map_mode          = "300 point"        ; determines which kind of height map is created/loaded
            global g_probe_mode        = "two consecutive"  ; determines if z proving used consecutive or averaging
            global g_level_mode        = "4 point"          ; determines if 3 or 4 points are used for leveling
            global g_print_beg_prime   = 10                 ; default - set desired in filament config.g
            global g_print_beg_retract = 0                  ; default - set desired in filament config.g
            global g_print_end_retract = 0                  ; default - set desired in filament config.g
            global g_print_end_mode    = "heat off"         ; determines if heaters are turned off when print is done
            ; Drives_________________________________________________________________________
            ;Main board______________________________________________________________________
            M569 P0 S0                                                          ; Physical drive 0 . X1
            M569 P1 S1                                                          ; Physical drive 1 . X2
            M569 P3 S0                                                       	; Physical drive 3 . Main Extruder
            M569 P4 S0                                                       	; Physical drive 4 . Secondary Extruder
            ;Duex5 board_____________________________________________________________________
            M569 P5 S0                                                       	; Physical drive 5 . Y
            M569 P6 S0                                                       	; Physical drive 6 . Z1 (-188 , 656.5)
            M569 P7 S0                                                       	; Physical drive 7 . Z2 (-188, -35.5)
            M569 P8 S0                                                       	; Physical drive 8 . Z3 (658.6 , -35.5)
            M569 P9 S0                                                       	; Physical drive 9 . Z4 (658.6, 656.5)
            ;Settings_________________________________________________________
            M584 X0:1 Y5 Z6:7:8:9  E3:4 P3								   	    ; Driver mapping
            ;___________________________________________________________________
            M350 X16 Y16 I1  		                            				; Configure microstepping with interpolation
            M350 Z16 E16:16 I0              		                			; Configure microstepping without interpolation
            M92 X100.00 Y100.00 Z2000.00 E425:300       				        ; Set steps per mm
            M566 X300 Y500 Z100.00 E120.00:120.00  P1               		    ; Set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z300.00 E1200.00:1200.00           		; Set maximum speeds (mm/min)
            M201 X1000 Y1000 Z120.00 E250.00:250.00                  			; Set accelerations (mm/s^2)
            M204 P500                                     			            ; Set print and travel accelerations  (mm/s^2)
            M906 X1800 Y1800.00 E1000:1000  I40 					        	; Set motor currents (mA) and motor idle factor in per cent (E1270 per dyze)
            M906 Z1800.00 I50 													; Set motor currents (mA) and motor idle factor in per cent
            M84 S100                                          					; Set idle timeout - 100 seconds
            M208 X0 Y0 Z-0.5 S1                               			 	    ; set axis minima
            M208 X585 Y575 Z630 S0                          					; set axis maxima 580;580
            M574 X1 S1 P"xstop + e0stop"                            	; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
            M574 Y2 S1 P"ystop"                            				; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
            ;M558 P9 C"^zprobe.in" H5 F120 T6000 A1 R1  				; set Z probe type to bltouch and the dive height + speeds
            ;M950 S0 C"duex.pwm5"										; set probe pin
            M98 P"config_probe.g"
            M556 S50 X0 Y0 Z0		                               		; set orthogonal axis compensation parameters woher kommt der test wie wurde der Winkel bestimmt Unklar!
            M376 H20													; stop z-leveling after 10 layers
            ; Heaters___________________________________________________________
            M140 H-1                                       				; disable heated bed (overrides default heater mapping)
            ;E0_________________________________________________________________
            M308 S0 P"spi.cs1" Y"rtd-max31865" A"Main Extruder"         ; create sensor number 1 as a PT100 sensor in first position daughterboard
            M950 H0 C"e0heat"   T0                       		        ; create nozzle heater output on e0heat and map it to sensor 0
            M307 H0 B0 R2.059 C461.5:461.5 D8.35 S1.00 V23.5            ; PID calibration
            ;M307 H0 B0 R6.167 C268.6:268.6 D4.07 S1.00 V23.5
            M143 H0 S1400                                    			; set temperature limit for heater 0 to 450C
            ;E1_________________________________________________________________
            M308 S1 P"spi.cs2" Y"rtd-max31865" A"Support Extruder"    	; create sensor number 2 as a PT100 sensor in sec position daughterboard
            ;E4_________________________________________________________________
            M308 S1 P"duex.e4temp" Y"thermistor" T100000 B4267   		; configure sensor 1 as thermistor on pin e1temp
            M950 H5 C"duex.e4heat" T1                            		; create nozzle heater output on e4heat and map it to sensor 4
            M143 H5 S120                                  			    ; set temperature limit for heater 1 to 120C
            ; Fans & LED___________________________________________________________
            M950 F0 C"fan0" Q500                            			; create fan 0 on pin fan0 and set its frequency
            M106 P0 S0 H-1                                  			; set fan 0 value. Thermostatic control is turned on
            M950 F1 C"fan1" Q500                            			; create fan 1 on pin fan1 and set its frequency
            M106 P1 S0 H-1                                  			; set fan 1 value. Thermostatic control is turned on
            M950 F2 C"fan2" Q500                            			; create air filter fan on fan 2 on pin fan2 and set its frequency
            M106 P2 S0 H-1                                  			; set fan 2 value. Thermostatic control is turned on
            M950 F7 C"!duex.fan7" Q500                            		; create LED on pin fan7 and set its frequency
            M106 P7 S0 H-1                               				; Disable fan channel for LED
            M106 P7 S255							                    ; remove ";" to set the LED to full brightness by default
            M950 F3 C"duex.fan3" Q500                       			; create fan 3 on pin fan3 and set its frequency
            M106 P3 S1 H-1                           					; set fan 3 value. Thermostatic control is turned on Bed relay to on
            ; Tools______________________________________________________________
            ;T0_________________________________________________________________
            M563 P0 S"E0 Main" D0 H0 F0                  				; define tool 0
            G10 P0 X0 Y0 Z0                                 			; set tool 0 axis offsets
            G10 P0 R0 S265                                  			; set initial tool 0 active and standby temperatures to 0C
            ;T1_________________________________________________________________
            M563 P1 S"E1 Support" D1 H1 F1                				; define tool 1
            G10 P1 X0 Y65 Z0                                			; set tool 1 axis offsets  Y-2 moves filament 2mm to back of machine     X-1 moves filament 1mm to the right
            G10 P1 R0 S265                                    			; set initial tool 1 active and standby temperatures to 0C
            ;T2____________________________________________________________________
            ;T3___________________________________________________________________
            M563 P3 S"CHAMBER TEMP" H5
            G10 P3 R0 S40
            ; Custom settings__________________________________________________
            M950 J0 C"exp.e2stop"
            M581 T1 P0 S0 R1
            M591 D0 P7 C"e1stop" S1 L4.2 E10 R10:1000
            M950 J1 C"exp.e3stop"
            M581 T1 P1 S0 R1
            M591 D1 P7 C"zstop" S1 L4.2 E10 R10:1000
            ;M591 D0 P1 C"duex.e2stop" S1								; Regular filament sensor for E0
            ;M591 D1 P1 C"duex.e3stop" S1								; Regular filament sensor for E1
            M950 J2 C"duex.e4stop"                                      ; create Input Pin 2 on Zstop for the M581 command.
            M581 P2 T0 S0 R0                                            ; Crash Detector  [Add-On]
            M42 P2 S255 												; Start up air filter
            ; Automatic power saving____________________________________________
            M911 S21 R29.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"              ; Set voltage thresholds and actions to run on power loss. Power Failure Pause
              @sculpt-fabricator also, does it reset if you simulate the job?
                @sculpt-fabricator and have you always used global variables or have you only recently started to use them?
                  @jay_s_uk I have never run a job simulate. I don't know how to do that ?
                    @sculpt-fabricator right click on the job and simulate
                      @jay_s_uk
                      I haven't changed any g-code or any setting in 4 months, printer was working
                      perfectly sense 3.3 update and getting all the code dialed in. Machine has been
                      running 24/7 for 4 weeks
                        @jay_s_uk
                        It made it 100% thought simulation.
                          @sculpt-fabricator not much we can do now until the reset map is looked at.
                            droftarts administrators @Sculpt Fabricator
                            @sculpt-fabricator said in Automatic Emergency Stop:
                            Error status: 0x04
                            Error 0x04 = Output buffer starvation, I think. I'd guess that your SD card is either full or damaged. Please check your SD card by running the commands here: https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#troubleshooting-sd-card-issues
                            Sculpt Fabricatorundefined 1 Reply Last reply Reply Quote 1
                              Sculpt Fabricator @droftarts
                              @droftarts
                              The SD card was really full we deleted everything out of it. I will look into
                              that more
                                @sculpt-fabricator probably file fragmentation on the SD card slowing down read time, then.
                                  @droftarts
                                  I ran the tests from the documentation, It all seems to be fine -
                                  M39
                                  SD card in slot 0: capacity 7.95Gb, partition size 7.94Gb, free space 7.82Gb, speed 20.00MBytes/sec, cluster size 64kb```
                                  SD read speed for 10.0Mbyte file was 1.36Mbytes/sec
                                  SD write speed for 10.0Mbyte file was 2.34Mbytes/sec
                                  Testing SD card read speed...
                                  M122 P104 S10
                                  Testing SD card write speed...
                                  M22
                                  SD card 0 may now be removed
                                  M21
                                  SDHC card mounted in slot 0, capacity 7.95Gb
                                    dc42 administrators @Sculpt Fabricator
                                    @sculpt-fabricator some questions:
                                    • Do you have any M581 triggers configured?
                                    • Do you have a PanelDue connected? If so, does the PanelDue cable run close to any stepper motor cables?
                                      Sculpt Fabricator @dc42
                                      @dc42 We 3 M581, two for filament sensor and one for crash detector
                                      M581 T1 P0 S0 R1
                                      M581 T1 P1 S0 R1
                                      We also have a front X motor which wires run along the same path as the PanelDue
                                        Sculpt Fabricator
                                        Found the problem, the Modix crash detector is a magnetic sensor and when
                                        triggered it sends the same Emergency Stop that we were getting mid print. Even the one 20 min into the print. My guess is a faulty crash sensor, running
                                        like normal now that it is temp. bypassed.
                                        Phaedruxundefined ComedianTF2undefined 2 Replies Last reply Reply Quote 2
                                          Phaedrux Moderator @Sculpt Fabricator
                                          @sculpt-fabricator You may want to feed that back to Modix.
                                          @ComedianTF2
                                          • ComedianTF2undefined
                                            ComedianTF2 @Sculpt Fabricator
                                            @sculpt-fabricator Send a mail to support@modix3d.com with your information and we'll send you a replacement sensor.
                                            I can also see you're running an interesting config file, we've done a fair few updates to the config/macro files, so look at the latest ones at https://github.com/Modix3D/Modix-V3-configuration-and-Macro-files/releases
