    Paneldue getting frequent info popups, clogging the console
    PanelDue
    • ComedianTF2undefined
      ComedianTF2
      Having an interesting issue where the paneldue console is getting flooded by info status messages during a G32, reporting that status changed from connecting to busy, and then back from busy to connecting.
      I suspect this may have to do with the processing required during the G32, as it uses gcode meta commands, but I don't see anything from the M122 that would indicate per-se that this is the case.
      Is there anything that could be done to alleviate the frequent messages?
      Firmware version: RepRapFirmware 3.4.2
      Paneldue 3.4.1
      The M122 was executed during the G32 command
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.2 (2022-09-13 15:11:16) running on Duet WiFi 1.02 or later + DueX5
      Board ID: 08DLM-996RU-N8PS4-6J9D0-3S86R-KAU3N
      Used output buffers: 1 of 26 (20 max)
      Static ram: 23860
      Dynamic ram: 76640 of which 204 recycled
      Never used RAM 8376, free system stack 120 words
      Tasks: NETWORK(ready,13.9%,237) HEAT(notifyWait,0.0%,329) Move(notifyWait,0.0%,296) DUEX(notifyWait,0.0%,24) MAIN(running,86.0%,440) IDLE(ready,0.1%,30), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:29:57 ago, cause: power up
      Last software reset at 2022-09-21 18:37, reason: User, GCodes spinning, available RAM 8556, slot 0
      Error status: 0x00
      Aux0 errors 0,1,0
      Step timer max interval 0
      MCU temperature: min 13.8, current 23.7, max 24.0
      Supply voltage: min 23.8, current 23.9, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/92/48, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0
      Driver 1: standstill, SG min 0
      Driver 2: standstill, SG min n/a
      Driver 3: standstill, SG min n/a
      Driver 4: standstill, SG min n/a
      Driver 5: ok, SG min 0
      Driver 6: standstill, SG min 0
      Driver 7: standstill, SG min 0
      Driver 8: standstill, SG min 0
      Driver 9: standstill, SG min 0
      Driver 10:
      Driver 11:
      Date/time: 2022-09-23 10:57:41
      Slowest loop: 11.43ms; fastest: 0.16ms
      === Storage ===
      Free file entries: 8
      SD card longest read time 3.6ms, write time 2.1ms, max retries 0
      DMs created 83, segments created 6, maxWait 1619833ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 43, completed 42, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
      === AuxDDARing ===
      Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Segments left: 0
      Movement lock held by Aux
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 49 0 0, running macro
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === Filament sensors ===
      Extruder 0 sensor: no data received
      === DueX ===
      Read count 1, 0.03 reads/min
      === Network ===
      Slowest loop: 22.29ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      = WiFi =
      Network state is active
      WiFi firmware version 1.27
      WiFi MAC address ec:fa:bc:5b:3c:a9
      WiFi Vcc 3.37, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 21256
      WiFi IP address 192.168.178.33
      WiFi signal strength -51dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      bed.g
      M98 P"config_probe.g"   											; insure probe is using most recent configuration values
      M280 P0 S60 I1														; clear any probe errors
      G28 																; home all
      G29 S2                       										; cancel mesh bed compensation
      M290 R0 S0                   										; cancel baby stepping
      G90                          										; absolute moves
      G1 Z5 F99999                 										; insure Z starting position is high enough to avoid probing errors
      G1 X{move.axes[0].min+2} Y{move.axes[1].min+2} F6000 				; move to front left
      G30                          										; do single probe which sets Z to trigger height of Z probe
      ; --- level bed ---
      while true
      	G30 P0 X{move.axes[0].min + sensors.probes[0].offsets[0] + 2} Y{move.axes[1].min + sensors.probes[0].offsets[1] + 2} Z-99999	; Probe near front left leadscrew
      	G30 P1 X{move.axes[0].max + sensors.probes[0].offsets[0] - 2} Y{move.axes[1].min + sensors.probes[0].offsets[1] + 2} Z-99999	; Probe near front right leadscrew
      	G30 P2 X{move.axes[0].max + sensors.probes[0].offsets[0] - 2} Y{move.axes[1].max + sensors.probes[0].offsets[1] - 2} Z-99999	; Probe near rear right leadscrew
      	G30 P3 X{move.axes[0].min + sensors.probes[0].offsets[0] + 2} Y{move.axes[1].max + sensors.probes[0].offsets[1] - 2} Z-99999 S4	; Probe near rear left leadscrew
      	if move.calibration.initial.deviation < 0.01
      		echo "Your bed is within 0.01 mm between the corners. The difference was " ^ move.calibration.initial.deviation ^ "mm. You can proceed to print"
      		break
      	; check pass limit - abort if pass limit reached
      	if iterations = 10
      		M291 P"Bed Leveling Aborted" R"Pass Limit Reached"
      		abort "Bed Leveling Aborted - Pass Limit Reached"
      Config.g
      ; General preferences_________________________________________________________
      G90															; send absolute coordinates...
      M83															; ...but relative extruder moves
      M555 P2														; Set output to look like Marlin
      M575 P1 B57600 S1											; Set auxiliary serial port baud rate and require checksum (for PanelDue)
      ; Network_____________________________________________________________________
      M550 P"Big 40"												; set printer name
      M552 S1														; enable network
      ; Drives_________________________________________________________________________
      ;Main board______________________________________________________________________
      M569 P0 S0													; Physical drive 0 . X1
      M569 P1 S1													; Physical drive 1 . X2
      M569 P2 R-1													; Physical drive 2 . Canceled
      M569 P3 S0													; Physical drive 3 . Main Extruder
      M569 P4 S0													; Physical drive 4 . Secondary Extruder
      ;Duex5 board_____________________________________________________________________
      M569 P5 S0													; Physical drive 5 . Y
      M569 P6 S0													; Physical drive 6 . Z1 (0,400)
      M569 P7 S0													; Physical drive 7 . Z2 (0,0)
      M569 P8 S0													; Physical drive 8 . Z3 (400,0)
      M569 P9 S0													; Physical drive 9 . Z4 (400,400)
      ;Settings_________________________________________________________
      M584 X0:1 Y5 Z6:7:8:9 E3:4 P3								; Driver mapping
      M671 X-185:-185:468:468 Y468:-46:-46:468 S30    			; Anticlockwise
      ;___________________________________________________________________
      M350 X16 Y16 Z16 E16:16 I1									; Configure microstepping with interpolation
      M92 X100 Y100 Z2000 E418.5:418.5							; Set steps per mm
      M566 X360 Y360 Z120 E3600:3600 P1							; Set maximum instantaneous speed changes (mm/min)
      M203 X9000 Y9000 Z200 E12000:12000							; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z120 E1000:1000							; Set accelerations (mm/s^2)
      M204 P500													; Set print and travel accelerations  (mm/s^2)
      M906 X1800 Y1800 E1000:1000 I50								; Set motor currents (mA) and motor idle factor in per cent
      M906 Z1800 I50												; set Z motor currents
      M84 S100													; Set idle timeout - 100 seconds
      M208 X0 Y0 Z-2 S1                               			; set axis minima
      M208 X400 Y400 Z800 S0                          			; set axis maxima
      M574 X1 S1 P"xstop + e0stop"                            	; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y2 S1 P"ystop"                            				; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M558 P9 C"zprobe.in" H5 F120 T6000 A1 R0.7					; BLTouch probing settings
      M950 S0 C"duex.pwm5"										; sets the BLTouch probe
      M376 H100			                						; Height (mm) over which to taper off the bed compensation
      G31 P500 X-25.5 Y26.9                         				; BLTouch X and Y offset from nozzle
      M557 X{move.axes[0].min + sensors.probes[0].offsets[0] + 1, move.axes[0].max + sensors.probes[0].offsets[0] - 1} Y{move.axes[1].min + sensors.probes[0].offsets[1] + 1, move.axes[1].max + sensors.probes[0].offsets[1] - 1} P8:8
      ; Heaters___________________________________________________________
      M140 H-1                                       				; disable heated bed (overrides default heater mapping)
      ;E0_________________________________________________________________
      ;M308 S0 P"e0temp" Y"thermistor" T100000 B4725   			; configure sensor 0 as thermistor on pin e0temp
      ;M308 S0 P"spi.cs1" Y"rtd-max31865"							; Configure sensor 0 as PT100 via the daughterboard
      M308 S0 P"e0temp" Y"pt1000"									; Configure sensor 0 as PT1000 on pin e0temp
      M950 H0 C"e0heat" T0                            			; create nozzle heater output on e0heat and map it to sensor 0
      M98 P"PID_tune_E0.g" R1										; PID calibration
      M143 H0 S285                                    			; set temperature limit for heater 0 to 285C
      ; Fans______________________________________________________________
      M950 F0 C"fan0" Q500                            			; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1 C"Primary blower fan"						; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"fan1" Q500                            			; create fan 1 on pin fan1 and set its frequency
      M106 P1 S0 H-1 C"Secondary blower fan"						; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"duex.fan7" Q500                            		; create LED on pin fan2 and set its frequency
      M106 P2 S0 H-1 C"LED"                              			; Disable fan channel for LED
      M106 P2 S255												; LED on by default
      M950 F3 C"duex.fan5" Q500                       			; create fan 3 on pin fan1 and set its frequency
      M106 P3 S255 H0 T45                             			; set fan 3 value. Thermostatic control is turned on
      M950 F4 C"duex.fan6" Q500                       			; create fan 4 on pin fan1 and set its frequency
      M106 P4 S255 H1 T45                             			; set fan 4 value. Thermostatic control is turned on
      ; Tools______________________________________________________________
      ;T0_________________________________________________________________
      M563 P0 S"E0 Primary" D0 H0 F0                  			; define tool 0
      G10 P0 X0 Y0 Z0                                 			; set tool 0 axis offsets
      G10 P0 R0 S210                                  			; set initial tool 0 active and standby temperatures to 0C
      ; Automatic power saving____________________________________________
      M911 S22.5 R29.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"     	; Set voltage thresholds and actions to run on power loss. Power Failure Pause
      ; Primary hotend Clog detector__________________________________________________
      M950 J0 C"duex.e2stop" 									; create Input Pin 0 on pin E2 to for M581 Command.
      M581 T1 P0 S0 R1 											; Runout switch for E0 As External Trigger
      M591 D0 P7 C"e1stop" S1 L4.2 E10 R10:1000					; Clog Detector E0 [Add-On]
      ; Crash detector__________________________________________________
      M950 J2 C"duex.e4stop" 									; create Input Pin 2 on pin E4 to for M581 Command.
      M581 P2 T0 S0 R0											; Crash Detector   [Add-On]
      ; Emergency stop button__________________________________________________
      M950 J3 C"duex.e6stop" 									; create Input Pin 2 on pin E4 to for M581 Command.
      ;M581 P3 T0 S1 R0 											; Emergency stop [Add-On]
      M581 P3 T1 S1 R1											; Emergency stop, pause the print [Add-On]
      ;M581 P3 T1 S1 R0 											; Emergency stop, pause always [Add-On]
      ; Automatic Z Offset Calibration____________________________________
      M574 Z1 S1 P"!zstop"									; configure switch-type for Automatic z-offset
      • mfs12undefined
        mfs12
        A message every minute is frequent? Not really. 😉
        Visit me on github at https://github.com/mfs12/
          How long is the cable run? Does it run near motor cables?
          ComedianTF2undefined 2 Replies Last reply Reply Quote 1
            ComedianTF2 @Phaedrux
            @phaedrux It's about 70cm, and does indeed run next to a motor cable, will need to test it seperated away
              @phaedrux I've tested it by moving the cable away, so that it no longer runs near motor cables, but sadly the info messages remain.
