    Passage de 3.1 au dernier soucis
    My Duet controlled machine
    guenteur@hotmail.com
    727
    • Thomas25undefined
      Thomas25
      Bonjour, J ai essayé de passé au dernier firmware mais la machine ne fonctionne plus, le wifi n est plus reconnu , J ai alors essayé de le faire via câble ethernet en remplaçant les fichiers firmware mais cela à empiré le problème.
      Puis repartir d un fichier complet de ma carte sd puis modifier mes config ?
      Ou pourrais je trouver ces fichiers ?
      Cordialement Thomas
      alankilianundefined HighFrequndefined 2 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @Thomas25
        @thomas25 THIS PAGE describes the steps you can take to replace the firmware.
        We can help more if you tell us what board you have and what version of firmware you had when it was working.
        Thomas25undefined 1 Reply Last reply Reply Quote 1
        • HighFrequndefined
          HighFreq @Thomas25
          @thomas25 The entire forum writes in english, could show some respect to all users that do not speak your language and write in english like everybody else if you really want some help. French grandeur i guess.
          alankilianundefined Phaedruxundefined 2 Replies Last reply Reply Quote -2
            alankilian @HighFreq
            @highfreq Oh please. It took me less time to translate it and try and help this person than it did for you to type in a complaint about language.
            I just spent 22 days driving thorough Europe and was able to speak English to almost everyone, and for the tiny amount where that didn't work, my terrible SwissGerman worked because the other person actually wanted to help a fellow human.
            So, give the person a break and use a little effort to communicate and help a fellow Duet user.
            HighFrequndefined 1 Reply Last reply Reply Quote 1
            • HighFrequndefined
              HighFreq @alankilian
              @alankilian,
              Scusa fammi capire devo tradurre io quello che scrive lui perchè lui non ha voglia di tradurlo per postare su un forum dove tutti parlano in inglese?
              E' anche una questione di rispetto.
              Se ognuno di noi che veniamo da 20 nazioni diverse scrive nel thread nella propria lingua immagina il casino che viene fuori.
              Ma se a te va bene così, non c'è problema, io mi limito a saltare i post non scritti in inglese.
              alankilianundefined 1 Reply Last reply Reply Quote -2
                @highfreq You just received a HUGE amount of help diagnosing an issue you were having and the author of the firmware created several test versions to help nail down your issue.
                It helped the firmware author fix a bug and it hopefully helps you get your system running.
                If you want to skip the issues of others because you don't want to translate, that's fine.
                However, in the spirit of community, I hope others don't skip your problems as well because of your attitude.
                HighFrequndefined 1 Reply Last reply Reply Quote 2
                  Phaedrux Moderator @HighFreq
                  @highfreq said in Passage de 3.1 au dernier soucis:
                  We aim to help all users here regardless of language barriers.
                  HighFrequndefined 1 Reply Last reply Reply Quote 0
                  • HighFrequndefined
                    @alankilian if in the thread were i received all that help (i tried to do my best to help too) i would have written in my own language people would never find it using search in case they have a similar problem.
                    If you are ok with it, i am not, just different point o view.
                    To solve my problem weren't issued several versions, i was asked to carry out some tests wich i did and developer nailed the prob on first attempt.
                    • HighFrequndefined
                      HighFreq @Phaedrux
                      @phaedrux to help a lazy one that doesn’t use google to translate you hide the content for all the others when using search function.
                      Phaedruxundefined A Former User? 2 Replies Last reply Reply Quote -2
                        Please leave this thread.
                        • Thomas25undefined
                          Thomas25 @alankilian
                          @alankilian bonjour, J ai une duet wifi 1.02, J avais mis le firmware 3.01 rc11. La carte pilote mon imprimante hypercube ngen, une core xy. Avant d avoir essayé de passé la dernière version de rff J arrivais à imprimer. Depuis elle de référence plus et le wifi ne fonctionne plus.
                          Falcounetundefined 1 Reply Last reply Reply Quote 1
                          • Falcounetundefined
                            Falcounet @Thomas25
                            @thomas25 There is some changes on the gcode configuration commands from RRF 3.0 to the current one.
                            I believe it may be faster to use the configurator to generate a new updated config
                            Note that you may also need to update the WiFi firmware (DuetWiFiServer.bin file) and to update DWC at the same version number of the board firmware.
                            • HighFrequndefined
                              HighFreq @Phaedrux
                              @phaedrux As you wish Mr. Mod
                              • Thomas25undefined
                                Thomas25 @Falcounet
                                @falcounet merci beaucoup pour votre aide.
                                alankilianundefined 1 Reply Last reply Reply Quote 0
                                • A Former User?
                                  A Former User @HighFreq
                                  This post is deleted!
                                    @thomas25 Yes, as @Falcounet says, you should go through the RRF configurator and generate files you can upload to the board to get it working again.
                                    BUT, since you do not have WiFi working, you will have to try some extra steps.
                                    You should use the instructions listed HERE under "Fallback #1".
                                    It's a lot of steps, and is complicated, so try them one at a time, and let us know where you get stuck, or if you have success!
