    Symetric Print on Y axis
    Using Duet Controllers
    348
    • Rodrigue Richallandundefined
      Rodrigue Richalland
      I've a little issue with my diy core XY printer. The prints pieces are symetrics on Y axis. I've try to switch the axis directions to move the origin frame in place. But it doesn't work. The slicer and printer frame origin is like this (attached picture) .
      Thanks for your help 🙂
        Check out this section of the corexy setup guide on testing motor movement.
        https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_coreXY#testing-motor-movement
        There are a few things to keep in mind.
        -X should move left, +X to the right.
        -Y to the front, +Y to the back
        The endstop position needs to be defined in M574
        The homing move direction is set in the homing files.
        With those things in mind, the motor tests will help you figure out what needs to change.
        Rodrigue Richallandundefined 1 Reply Last reply Reply Quote 0
          Rodrigue Richalland @Phaedrux
          @phaedrux
          I've work on this today. After fews hours and many stettings try, i always have this issue :
          The Y axis is not in the right derection (Y+ & Y- are swapped).
          But if I switch the Y direction only, the X axis is reverse as well due to the Core xy kinematic. Do you have an idee to fix it ?
          Thanks you so much,
          Rodrigue 🙂
            Did you do the motor tests?
              jay_s_uk @Rodrigue Richalland
              @rodrigue-richalland remap X and Y, i.e. M584 X1 Y0 then resetup
                Rodrigue Richalland @jay_s_uk
                @jay_s_uk
                @Phaedrux
                My -X move right & +X move left
                My -Y move front & +Y move back
                My -Z move top (to nozzle contact) & +Z move down
                So , the 3d prints pieces are always symetric as you can see on the attached pictures.
                  Rodrigue Richalland @Rodrigue Richalland
                  So I dont know how to place the x axis in right direction without z axis direction reverse. Thanks for your precious help 🙂
                  • deckingmanundefined
                    deckingman @Rodrigue Richalland
                    @rodrigue-richalland said in Symetric Print on Y axis:
                    Have you worked through the link that @Phaedrux posted? If so, did you also read this note - quote.........
                    "Important: make sure that you have chosen a right-hand axis system. That is, looking down on the printer the +Y direction should be 90 degrees anticlockwise from the +X direction. If instead it is 90 degrees clockwise, you have a left-hand axis system, which will give you mirror-image prints."
                      Rodrigue Richalland @deckingman
                      @deckingman
                      Yes i've work hard on the link that @Phaedrux posted. I 'm unable to place the frame in the right position. I've try to modify differents settings :
                      *G92 position in home x, y
                      • low end or high end Ends stop
                      • sense of rotation or X and Y motor
                      How it's possible to set "right hand" or "left hand " axis system ?
                        When standing in front of your printer, where are the endstops positioned?
                        Please post your config.g and your homing files.
                          @phaedrux
                          all work. it was the motor mapping. Thanks you so much for your help
