    Smart effector adapter 80mm
    677
    • Falkiaundefined
      Falkia
      Going to use 80mm rod spacing. Design and manufactured an adapter for the smart effector. CNC milled aluminum, weight 38grams. The plan is to use an Orbiter 2.0 extruder.
      Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
      tecnoundefined 1 Reply Last reply Reply Quote 3
      • tecnoundefined
        tecno @Falkia
        @Falkia
        How is the top done?
        Falkiaundefined 1 Reply Last reply Reply Quote 0
        • Falkiaundefined
          Falkia @tecno
          @tecno Which top do you mean?
          tecnoundefined 1 Reply Last reply Reply Quote 0
          • tecnoundefined
            tecno @Falkia
            @Falkia
            Top end of rods
            • Falkiaundefined
              Falkia @tecno
              @tecno The carriage adapter is my own design (CNC milled) that fit on a Hiwin linear block. The rail is mounted inside the tower (C-Beam extrusion). The ends of the belt are clamped on the carriage adapter.
              • tecnoundefined
                tecno @Falkia
                @Falkia
                Nice work
                Snyggt jobbat, var i landet håller du hus?
                /Bengt
                • Falkiaundefined
                  Falkia @tecno
                  @tecno Thanks, near Falköping.
                  • apakundefined
                    apak
                    nice work...would you share files?
                    • Falkiaundefined
                      Falkia @apak
                      @apak Yes, Do you want the holes to be with modeled threads or just holes, I guess that M3 holes are not going to be well printed?
                      apakundefined 1 Reply Last reply Reply Quote 0
                      • apakundefined
                        apak @Falkia
                        @Falkia If I would 3dprinter I would use brass inserts or regular m3 nuts from the opposite side of the screws so It is stronger.
                        If I would cnc it I would tap the screws holes
                        • Falkiaundefined
                          Falkia @apak
                          @apak Please check this Thingiverse.
