    Control laser using Lightburn USB connection
    Laser Cutters
    790
    • goldentunaundefined
      goldentuna
      Using the Duet3 WiFi 6HC board, can I connect to my diode laser
      (on cnc) directly with USB and control it using LIghtburn functions instead of DWC?
      If so, is there anything I need to configure to do so?
      I've tried to search here, and Lightburn, and YouTube but haven't found how.
      jay_s_ukundefined CNCModellerundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @goldentuna
        @goldentuna I believe it should just work. Set the board up in lightburn as marlin
        • CNCModellerundefined
          CNCModeller @goldentuna
          @goldentuna said in Control laser using Lightburn USB connection:
          Any feedback you have on using lightburn with duet would be much appreciated. I've been using fusion for cutting but was looking for a decent way to do raster image engraving.
          Polar Duet3 Mini + 1HCL
          https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
          Wanhao D4S: Duet2
          https://forum.duet3d.com/post/296755
          K40 Laser, Duet2
          https://forum.duet3d.com/post/312082
          Wanhao D5S
          https://www.youtube.com/CNCModellerUK
          o_lampeundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
          • o_lampeundefined
            o_lampe @CNCModeller
            @CNCModeller there's the github page from @paulg4h you might find something there...
              jay_s_uk @CNCModeller
              @CNCModeller I use lightburn quite happily
              YYCSparksundefined 1 Reply Last reply Reply Quote 1
              • YYCSparksundefined
                YYCSparks @jay_s_uk
                @jay_s_uk could you describe your workflow for laser engraving with Duet and Lightburn? I am still working on getting my laser setup and working and would like a coles notes version of what getting a job setup and zeroed looks like.
                  jay_s_uk @YYCSparks
                  @YYCSparks I place the thing to be cut in the bottom left at 0,0.
                  With DWC in CNC mode (can be set in settings) and jog to the corner of the workpiece and then use the workplace coordinates to set X and Y to zero and then run the gcode.
                  YYCSparksundefined 1 Reply Last reply Reply Quote 0
                    YYCSparks @jay_s_uk
                    @jay_s_uk thank you. Sorry given the title was using Lightburn over USB I thought maybe you had a way to make that happen. Doing it all offline or not live in the software is okay but there are tools in the live software that would be handy for sure.
