Toolboard 1LC V1.2 Accelerometer:none M122 output
Hi all,
I'm trying to setup the accelerometer on my new toolboard. At the end of my config.g, I have
G4 P1000 M955 P121.0 I10
When running M122 B121 I get this output, showing "accelerometer:none"
My firmware version is 3.4.5
From my understanding of the documentation, I should be seeing "Accelerometer detected: yes, status: 00".
Am I missing something here? Do I need to run some other commands to enable the accelerometer?
Thank you
@Surgikill can you confirm the version of the toolboard?
if its a 1.1, can you post a photo of the back of the board? -
@Surgikill one for @Phaedrux
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
Sorry for the inconvenience.
@Phaedrux Will do. Thanks.
Just FYI, I got a new board in and it seems to work fine. Accelerometer shows up and works.
@Surgikill great! one point, looking at the pictures before, its not clear that there are any standoffs between the toolboard and the hemera, but that may just be the pictures. I assume you have some standoffs to prevent any of the ends of the headers on the back of the toolboard touching the hemera?
@T3P3Tony Yea I had a stack of orings in there temporarily until I could get a mount drawn up. There was plenty of clearance between the contacts on the board and the hemera.
