    Setting up Eclipse to Develop Firmware
    Firmware developers
    5.7k
    • jmlundefined
      jml
      For reference, when changing it back to just gcc, I get the same error as before. Although from the above error, it looks like it was looking in /bin/sh. So maybe I should put the gcc file in a folder called sh?
      Building target: DuetWiFiFirmware.elf
      Invoking: Cross G++ Linker
      arm-none-eabi-gcc -L"/Users/John/eclipse-w … [ … ] … rc/ZProbeProgrammer.o -lCoreNG -Wl,--end-group -lm -gcc
      arm-none-eabi-gcc: error: : No such file or directory
      make: *** [DuetWiFiFirmware.elf] Error 1
      Interesting how the prior error was "command not found", but then this error is "No such file or directory."
      • jmlundefined
        jml
        Notice the lone colon in the error?
        Maybe it was looking for a file or directory that had no name? Or had a space in the name or something?
          @jml:
          Good catch! There is a "" after the -Wl,–start-group in your linker command line. When I'm in the office I'll see what should be there.
          • fmaundefined
            fma
            @jml:
            This is a common mistake, due to poor error messages: in the first case, this is sh which can't find gcc, in the second case, this is gcc which can't find a file. sh reports which file it can't find (gcc, here), but gcc does not report the missing file…
            I suspect a library path not setup correctly, so gcc can't find a .o to build something else.
            Frédéric
              Here is the link command I get:
              arm-none-eabi-gcc -L"C:\Eclipse\Firmware\CoreNG\SAM4E8E" -Os -Wl,–gc-sections -Wl,--fatal-warnings -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -TC:\Eclipse\Firmware\CoreNG\variants\duetNG\linker_scripts\gcc\flash.ld -Wl,-Map,C:\Eclipse\Firmware\RepRapFirmware\DuetWiFi/DuetWiFiFirmware.map -o "DuetWiFiFirmware.elf" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "C:\Eclipse\Firmware\CoreNG\SAM4E8E\cores\arduino\syscalls.o" ./src/Tools/Filament.o ./src/Tools/Tool.o ./src/Storage/CRC32.o ./src/Storage/FileStore.o ./src/Storage/MassStorage.o ./src/Movement/Kinematics/CartesianKinematics.o ./src/Movement/Kinematics/CoreBaseKinematics.o ./src/Movement/Kinematics/CoreXYKinematics.o ./src/Movement/Kinematics/CoreXYUKinematics.o ./src/Movement/Kinematics/CoreXZKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/PolarKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/Kinematics/ZLeadscrewKinematics.o ./src/Movement/BedProbing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o ./src/Movement/DDA.o ./src/Movement/DriveMovement.o ./src/Movement/Move.o ./src/Libraries/sha1/sha1.o ./src/Libraries/Math/Isqrt.o ./src/Libraries/General/IP4String.o ./src/Libraries/General/StringRef.o ./src/Libraries/Fatfs/ccsbcs.o ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Heating/Sensors/CpuTemperatureSensor.o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/DhtSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Sensors/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/ThermocoupleSensor31856.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o ./src/Heating/FOPDT.o ./src/Heating/Heat.o ./src/Heating/Pid.o ./src/Heating/TemperatureError.o ./src/GCodes/GCodeBuffer.o ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src/GCodes/GCodes2.o ./src/GCodes/RestorePoint.o ./src/FilamentSensors/Duet3DFilamentSensor.o ./src/FilamentSensors/FilamentSensor.o ./src/FilamentSensors/SimpleFilamentSensor.o ./src/DuetNG/DuetWiFi/Network.o ./src/DuetNG/DuetWiFi/Socket.o ./src/DuetNG/DuetWiFi/WifiFirmwareUploader.o ./src/DuetNG/DueXn.o ./src/DuetNG/FirmwareUpdater.o ./src/DuetNG/FtpResponder.o ./src/DuetNG/HttpResponder.o ./src/DuetNG/NetworkBuffer.o ./src/DuetNG/NetworkResponder.o ./src/DuetNG/SX1509.o ./src/DuetNG/TMC2660.o ./src/DuetNG/TelnetResponder.o ./src/Fan.o ./src/IoPort.o ./src/Logger.o ./src/OutputMemory.o ./src/Platform.o ./src/PortControl.o ./src/PrintMonitor.o ./src/RepRap.o ./src/RepRapFirmware.o ./src/Roland.o ./src/Scanner.o ./src/SoftTimer.o ./src/ZProbeProgrammer.o -lCoreNG -Wl,--end-group -lm -gcc
              So the file it's missing on your machine is, on my machine, "C:\Eclipse\Firmware\CoreNG\SAM4E8E\cores\arduino\syscalls.o". That should come from this "Command line pattern" setting in the Cross G++ Linker settings:
              ${COMMAND} ${FLAGS} ${OUTPUT_FLAG} ${OUTPUT_PREFIX}${OUTPUT} ${LINK_FLAGS_1} "${workspace_loc:/${CoreName}/SAM4E8E/cores/arduino/syscalls.o}" ${INPUTS} ${LINK_FLAGS_2}
              I've noticed before that if Eclipse can't find a file, it just omits it from the command line. If you built the SAM4E configuration of CoreNG before you built RRF, that file should be there.
              HTH David
              • jmlundefined
                jml
                Ok we are getting closer to a solution.
                I found the missing file here:
                /Users/John/eclipse-workspace/CoreNG/SAM4E8E/cores/arduino/syscalls.o
                [it appears there with a bunch of other files after building CoreNG]
                In the RRF Cross G++ Linker "Command line pattern" box, I see this written:
                Its the same as yours, so seems like its not a problem.
                Maybe the problem is with how I build CoreNG and RRF:
                • First I right click CoreNG, Build Configurations > Clean All.
                • Repeat for RepRapFirmware folder
                • Right click CoreNG, Build Configurations > Build Selected… then I select SAM4E8E and hit ok.
                • Wait for build to finish (8 seconds)
                • Repeat for RepRapFirmware folder, but select DuetWiFi and hit ok.
                • Error
                Should I build it differently?
                  That's the correct build order.
                  In Properties -> C/C++ Build -> Build Variables, do you have CoreName defined as CoreNG ?
                  • jmlundefined
                    jml
                    For the RepRapFirmware folder, yes it is there. Name: CoreName || Type: String || Value: CoreNG
                    For the CoreNG folder, nothing is listed in the list. Should it be there?
                    • jmlundefined
                      jml
                      I really just need to make some small firmware changes and some custom g-code commands.
                      I purchased the DuetWifi, PanelDue, and am waiting for the Duex5. Hoping to have it solved by the time it arrives! If I can't get it to work on Mac or Windows, I may just uninstall everything and try again when firmware version 1.2 is out.
                      Thanks for all the help you've provided so far!
                      • fmaundefined
                        fma
                        I had no problem installing/compiling under linux. You may try to install a linux system in a Virtualbox env, and compile from there.
                        Frédéric
                        • jmlundefined
                          jml
                          Ok, I will try. I'm using a decently powered Mac using Parallels to run windows and I assume I can put Linux on here too. Which Linux OS/distribution do you recommend? Ubuntu? I have limited experience with Linux, but I can learn!
                          • jmlundefined
                            jml
                            So strange though. It seems like the only thing I need to fix is these empty quotation marks and it will fix everything:
                            -Wl,–start-group ""
                            The file it is looking for is 100% in the right folder. And the command line pattern is exactly how dc42's is.
                            • fmaundefined
                              fma
                              I run debian, but I think ubuntu is fine too (all dev libs exist).
                              About the missing path, you can try to replace:
                              ${CoreName}
                              by
                              CoreNG
                              or ${workspace_loc:/${CoreName}
                              by
                              to see if it fixes the problem.
                              Frédéric
                              • jmlundefined
                                jml
                                LOL, I literally just tried it before reading your post AND IT WORKED!!!!!!
                                Just in case someone in the future has this problem, this is what I changed:
                                changed it to:
                                ${COMMAND} ${FLAGS} ${OUTPUT_FLAG} ${OUTPUT_PREFIX}${OUTPUT} ${LINK_FLAGS_1} "/Users/John/eclipse-workspace/CoreNG/SAM4E8E/cores/arduino/syscalls.o" ${INPUTS} ${LINK_FLAGS_2}
                                (make sure the quotes are there but the curly brackets and dollar signs removed).
                                Thanks everyone!
                                • jmlundefined
                                  jml
                                  I'm so happy
                                  • fmaundefined
                                    fma
                                    Good!
                                    But I think I found the issue. The string:
                                    should be :
                                    "${workspace_loc}:/${CoreName}/SAM4E8E/cores/arduino/syscalls.o}"
                                    There where a missing bracket at the end of the workspace_loc var…
                                    Can you confirm?
                                    Frédéric
                                    • jmlundefined
                                      jml
                                      When I browse around in the settings, the way that all of the Includes are is like this:
                                      "${workspace_loc:/${CoreName}/asf/common/utils}"
                                      So I don't think that was the issue.
                                      • jmlundefined
                                        jml
                                        Eg. when you write it like this:
                                        you have an extra curly bracket because there is one on the far right 2nd last to the end.
                                        • fmaundefined
                                          fma
                                          Mmm, you're right, they are all defined this way… Strange.
                                          Frédéric
                                          • vschundefined
                                            vsch
                                            If it is of any help, I was getting the exact same error because I made the mistake of having the projects not under the workspace directory.
                                            When I created the workspace in the parent directory of the project sources (CoreNG and RepRapFirmware directories) the error went away as expected. The ${workspace_loc:} is expecting them to be under the workspace directory.
                                            However, I am getting undefined reference errors during linking for: lprintf, sqrtf, floorf, etc.
                                            I am running under OS X with gcc-arm-none-eabi-6-2017-q2-update tools. Is there a library missing from the linker options that the IDE should include based on dependencies?
