    Voron 2.4 new TAP - Z end stop or Z probe config ?
    3.4k
    • KCMARINEundefined
      KCMARINE
      Hello Gents,
      My Voron 2.4 x 350 is starting to move.
      Please can I ask for clarification on the correct config for the "TAP" Z end stop, and Z probe config settings?
      I tested and confirmed iT IS working correctly using M119
      In the current open position, M119 is - Endstops - X: not stopped, Y: not stopped, Z: no endstop, Z probe: not stopped.
      When I try to home Z the error immediately reported:
      "Failed to home axes ZG1: Failed to enable endstops"
      How can it be "Failed to enable"? I can not set Z end-stop and Z probe to the same C"io3.in"
      My config section is
      ;+++++Endstops
      M574 X2 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io1.in
      M574 Y2 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io2.in
      ;+++++Z-Probe
      M558 P1 C"io3.in" H5 F120 T6000  ; set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y25 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X40:260 Y40:260 S20 ; define mesh grid
      Firmware is all up-to-date:
      m115
      FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.5beta1 ELECTRONICS: Duet 3 MB6HC v1.01
      m122 B1
      Diagnostics for board 1:
      Duet EXP3HC rev 1.01 or earlier firmware version 3.5beta1 (2022-12-23 18:44:21)
      Bootloader ID: SAME5x bootloader version 2.3 (2021-01-26b1)
      Thanks in advance for your support
      Ken
      jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @KCMARINE
        @KCMARINE it should be setup as a probe.
        post the contents of homez.g and homeall.g
        edit:
        @KCMARINE said in Voron 2.4 new TAP - Z end stop or Z probe config ?:
        your Y offset it incorrect. It should be 0, not 25
          Phaedrux Moderator @KCMARINE
          It's failing because you're likely trying to use a G1 H1 Z endstop move when no Z endstop exists. As Jay says, the voron tap should be used as a probe, so instead of G1 H1 Z moves, you would need to use a G30 to initiate a Z probe movement.
          • KCMARINEundefined
            KCMARINE
            This post is deleted!
            • KCMARINEundefined
              KCMARINE
              Thanks for the help, moving forward with your advice I am now able to successfully home X - Y and Z using the G30 command in the homez.g file.
              The issue I am now facing is that once Z is homed, it will only move in the negative direction - I can not get it to move in the positive direction!
              How do I clarify that Z = 0 - my understanding is it thinks Z = 355mm?
              I also see my next mission is figuring out tramming the gantry and bed mesh calibration - any pointers greatly appreciated.
              Attaching the config and homing files below
              ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
              ;++++++General preferences
              M575 P1 S1 B57600                                  ; enable support for PanelDue
              M550 P"Harlod"                                     ; set printer name
              M669 K1                                            ; select CoreXY mode
              ; Thermal section ------------------------------------------------------------
              M308 S3 Y"mcu-temp" A"Board" ; Board thermal sensor
              M912 P0 S-2 ; MCU tempurature sensor correction (subtract 2°K)
              ;+++++Wait a moment for the CAN expansion boards to start
              G4 S2
              ; Drives ---------------------------------------------------------------------
              ; ----+---- Z-Drives
              ; | 2 | 3 |
              ; | 1 | 4 |
              ; Front
              M584 X0.4 Y0.5 Z0.0:0.1:0.2:0.3 E1.0				; set drive mapping +++ possible swap X and Y
              M569 P0.4 S1 										; A motor goes forwards
              M569 P0.5 S1 										; B motor goes forwards
              M569 P0.0 S1      									; Z0 motor FL goes forwards
              M569 P0.1 S0      									; Z1 motor RL goes backwards
              M569 P0.2 S1      									; Z2 motor RR goes forwards
              M569 P0.3 S0      									; Z3 motor FR goes backwards
              M569 P1.0 S0      									; E motor Extruder goes backwards
              M350 Z16 I0 										; configure microstepping without interpolation
              M350 X16 Y16 E16 I1 								; configure microstepping with interpolation
              M92 X162.222 Y161.298 Z805.721 E426 				; set steps per mm
              ;M566 X8000.00 Y8000.00 Z8000.00 E800.00 			; set maximum instantaneous speed changes (mm/min)
              ;M203 X12000.00 Y12000.00 Z12000.00 E1200.00 		; set maximum speeds (mm/min)
              ;M201 X6000.00 Y6000.00 Z4000.00 E1500.00            ; set accelerations (mm/s^2)
              M906 X1200 Y1200 Z1200 E600 I30                    	; set motor currents (mA) and motor idle factor in per cent
              M84 S10                                            	; Set idle timeout
              ; Axis Limits ----------------------------------------------------------------
              M208 X343 Y350 Z340 S0 ; set axis maxima
              ; Endstops -------------------------------------------------------------------
              M574 Z	S2
              ; notes
              ;When using the Z probe to home Z, M574 Z has no bearing on the probe setup or usage.
              ;A Z probe and a Z endstop can both be configured at the same time.
              ;G30 calling the probe setup with M558, and G1 H1 Z moves calling the endstop configured with M574 Z.
              ; Z-Probe --------------------------------------------------------------------
              G31 P500 X0 Y0 Z0 									; set Z probe trigger value, offset and trigger height
              ; Heaters --------------------------------------------------------------------
              ;-Hot Bed
              M308 S0 A"HOT-BED" P"temp0" Y"thermistor" T100000 B3950 		; configure sensor 0 as thermistor on pin temp0
              M950 H0 C"out0" T0                           					; create bed heater output on out0 and map it to sensor 0
              M307 H0 B1 S1.00                             					; enable bang-bang mode for the bed heater and set PWM limit
              M140 H0                                      					; map heated bed to heater 0
              M143 H0 S120                                 					; set temperature limit for heater 0 to 120C
              ;-Hot End
              M308 S1 A"HOT-END" P"temp1" Y"thermistor" T100000 B4138       	; configure sensor 1 as thermistor on pin temp1
              M950 H1 C"out1" T1                                 				; create nozzle heater output on out1 and map it to sensor 1
              M307 H1 B0 S1.00                                   				; disable bang-bang mode for heater  and set PWM limit
              M143 H1 S280                                       				; set temperature limit for heater 1 to 280C
              ;-Chamber Heater
              M308 S2 A"CHAMBER" P"temp2" Y"thermistor" T100000 B4138       	; configure sensor 2 as thermistor on pin temp2
              M950 H2 C"out3" T2                                 				; create nozzle heater output on out1 and map it to sensor 2
              M307 H2 B1 S1.00                                   				; disable bang-bang mode for heater  and set PWM limit
              M143 H2 S280                                        			; set temperature limit for heater 1 to 280C
              ; Fans -----------------------------------------------------------------------
              ;-Part Cooling Fan
              M950 F0 C"out7" Q500                              				; create fan 0 on pin out7 and set its frequency
              M106 P0 S0 H-1                                  				; set fan 0 value P0. Thermostatic control is turned off H-1
              ;-Hot End Fan set to start at 45 degrees
              M950 F1 C"out8" Q500                               				; create fan 1 on pin out8 and set its frequency
              M106 P1 S0 H1 T45                                 				; set fan 1 value P1. Thermostatic control is turned on H1
              ;-Hot Bed Fans
              M950 F2 C"out4" Q500											; create fan 2 on pin out4 and set its frequency
              M106 P2 S0 H1 T45												; set fan 2 value P2. Thermostatic control is turned off
              ; Tools ----------------------------------------------------------------------
              M563 P0 S"Stealth Burner " D0 H1 F0:1              ; define tool 0
              ; Custom settings are not defined --------------------------------------------
              M671 X-60: -60:357:357 Y-6:365:356:-6
              ;+++++Miscellaneous
              M501                                               ; load saved parameters from non-volatile memory
              T0                                                 ; select first tool
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool v3.3.15 on Thu Jan 19 2023 16:09:43 GMT+0800 (Australian Western Standard Time)
              G91                   ; relative positioning
              G1 H2 Z5 F6000        ; lift Z relative to current position
              G1 H1 X295 Y295 F1800 ; move quickly to X or Y endstop and stop there (first pass)
              G1 H1 X295            ; home X axis
              G1 H1 Y295            ; home Y axis
              G1 X-5 Y-5 F6000      ; go back a few mm
              G1 H1 X295 F360       ; move slowly to X axis endstop once more (second pass)
              G1 H1 Y295            ; then move slowly to Y axis endstop
              G1 H1 Z255 F360       ; move Z up stopping at the endstop
              G90                   ; absolute positioning
              G92 Z250              ; set Z position to axis maximum (you may want to adjust this)
              ;G91                  ; relative positioning
              ;G1 Z5 F100           ; lift Z relative to current position
              ;G90                  ; absolute positioning
              ; homex.g
              ; called to home the X axis
              G1 H1 X355 F1800 ; move quickly to X axis endstop and stop there (first pass)
              G1 X-5 F6000     ; go back a few mm
              G1 H1 X355 F360  ; move slowly to X axis endstop once more (second pass)
              G1 H2 Z-5 F6000  ; lower Z again
              ; homey.g
              ; called to home the Y axis
              G1 H1 Y355 F1800 ; move quickly to Y axis endstop and stop there (first pass)
              G1 Y-5 F6000     ; go back a few mm
              G1 H1 Y355 F360  ; move slowly to Y axis endstop once more (second pass)
              ; homez.g
              ; called to home the Z axis
              G30 H2 Z0 F1800
              G92 Z350 F1800      ; set Z position to axis maximum (you may want to adjust this)
                It still doesn't look like you've changed your files.
                The G1 H1 move needs to be replaced with a G1 X Y move to position the print head, and then a G30 to use the probe.
                Then you must also remove the G92 Z250 command because that would override your probe result.
                  M574 Z S2
                  Also remove that from your config.g
                  • KCMARINEundefined
                    KCMARINE
                    Many thanks, @Phaedrux
                    I have updated as you advised
                    ; homez.g
                    G1 Z150 Y150 F6000  ; move to position
                    G30
                    and also removed the M574 Z S2 form config.g
                    G4 S2
                    ; | 2 | 3 |
                    ; | 1 | 4 |
                    ; Front
                    M208 X343 Y350 Z350 S0 ; set axis maxima
                    ; notes
                    ;-Hot Bed
                    ;-Hot End
                    ;-Chamber Heater
                    ;-Part Cooling Fan
                    ;-Hot Bed Fans
                    ;+++++Miscellaneous
                    I can home X and then Y, and when I home Z am immedetly getting the error message
                    Error: Failed to home axes ZG1: G0/G1: insufficient axes homed.
                    Must be missing something in the config ?
                      jay_s_uk @KCMARINE
                      @KCMARINE you need to make the same changes to homeall
                      • KCMARINEundefined
                        KCMARINE
                        The homeall.g file
                        ; homeall.g
                        G1 H1 X355 Y355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                        G1 H1 X355            ; home X axis
                        G1 H1 Y355            ; home Y axis
                        G1 H1 Y355            ; then move slowly to Y axis endstop
                        G30
                        Doing either Home Z or Home all gets the error
                        Proschi3Dundefined 1 Reply Last reply Reply Quote 0
                        • Proschi3Dundefined
                          Proschi3D @KCMARINE
                          no H2
                          17 G1  Z5 F6000   	; lift Z relative to current position
                          H2 only for movements of an axis that is not homed
                          Love my Duet 3 Mini.
                          https://www.instagram.com/proschi3d
                          https://youtube.com/@proschi3d
                          https://www.proschi3d.de
                            Remove that from home all.
                            You would get insufficient axis homed error in home z if you try and run it without the x and y axis already being homed.
                            • KCMARINEundefined
                              KCMARINE
                              Thank you for your help Gents,
                              I managed to now get X Y and Z homed - for any other people facing this problem in the future, this is the code that worked for me:
                              ; homeall.g
                              G30			; Sets the Z coordinate to the probe trigger height
                              ; homez.g
                              G30				; Sets the Z coordinate to the probe trigger heightG30
                              Now I am onto gantry tramming/bed leveling/height mapping so I am sure to have more questions
                              Thanks again
                                You may want to add a G1 X Y move before the G30 to position the print head where you want to probe. Typically the center of the bed is used.
