    Duet Wifi - Accel
    1.6k
    • samu_87undefined
      samu_87 @Phaedrux
      @Phaedrux Sorry but now when I wake up the printer the tool 0 is active, I don't like this, it can be fix?
      ; generated by RepRapFirmware Configuration Tool v2 on Mon Mar 25 2019 12:03:15 GMT+0100 (CET)
      G90        ; Send absolute coordinates...
      M83        ; ...but relative extruder moves
      M665 R280.8 L515 B200 H572.95 X0.0 Y0.0 Z0.0							; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0.0 Y0.0 Z0.0 A0 B0        ; Put your endstop adjustments here, or let auto calibration find them
      M550 P"Delta"        ; Set machine name
      M551 P"samufree"        ; Set password
      M552 S1        ; Enable network
      M586 P0 S1        ; Enable HTTP
      M586 P1 S0        ; Disable FTP
      M586 P2 S0        ; Disable Telnet
      M569 P0 S1        ; Drive 0 goes forwards
      M569 P1 S1        ; Drive 1 goes forwards
      M569 P2 S1        ; Drive 2 goes forwards
      M569 P3 S1        ; Drive 3 goes forwards
      M584 X0 Y1 Z2 E3
      M350 X16 Y16 Z16 E16 I1        ; Configure microstepping without interpolation
      M92 X200.00 Y200.00 Z200.00 E432                               	                              	; Set steps per mm
      M566 X600 Y600 Z2800 E6000.00 P1                                               			; Set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E900.00                                                    	; Set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z3000.00 E5000.00                                                      	; Set accelerations (mm/s^2)
      M906 X1600.00 Y1600.00 Z1600.00 E1000.00 I30                                                    ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30        ; Set idle timeout
      M208 Z0 S1        ; Set minimum Z
      M574 X2 P"xstop" S1
      M574 Y2 P"ystop" S1
      M574 Z2 P"zstop" S1
      M558 P1 C"!zprobe.in" R0.4 F240 H10 T3600
      G31 X0 Y0 Z-0.1 P530
      M557 R190 S20        ; Define mesh grid
      M308 S0 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e1temp
      M950 H0 C"e1heat" T0                          ; create bed heater output on e1heat and map it to sensor 0
      M307 H0 B1 S1.00                              ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                       ; map heated bed to heater 0
      M143 H0 S120                                  ; set temperature limit for heater 0 to 120C
      M308 S1 P"spi.cs1" Y"rtd-max31865"            ; configure sensor 1 as PT100 on pin spi.cs1
      M950 H1 C"bedheat" T1                         ; create nozzle heater output on bedheat and map it to sensor 1
      M307 H1 B0 S1.00                              ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                  ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                          ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                ; set fan 0 value. Thermostatic control is turned off
      ;CPU Fan
      M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as on-chip MCU temperature sensor
      M950 F2 C"fan2" Q100 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 H3 T20:70 ; set fan 2 value
      M563 P0 S"tool1" H1 F0 D0						; define tool 1
      G10 P0 X0 Y0 Z0                               ; set tool 1 axis offsets
      G10 P0 R0 S0                                  ; set initial tool 1 active and standby temperatures to 0C
      M204 P1800
      M579 X1.004 Y1.01
      M591 D0 P1 C"e0stop" S1										;Sensore di Fine_Filo
      M572 D0 S0.05
      ;M955 P0 C"spi.cs4+spi.cs3"	;Accelerometer
      T0 ;Enable Extruder
      M501
        Do you actually have a PT100 and daughterboard on the hotend?
        I think you have your bed heater and hotend heater defined backwards.
        You have
        It should probably be this. Where exactly do you have the bed and hotend heaters connected?
        M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
        M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
        Heater 0 is typically the bed. Heater1 is typically the first tool heater.
        @samu_87 said in Duet Wifi - Accel:
        I don't Sundstrand why when the axes are not homed x=0 Y=0 and Z is max hight and why the preset selected on T0 is -273,1
        I don't know what you mean by this. The axis are only homed after running homeall. When the motors lose power they lose position and need to be rehomed.
        Active just means that it is the currently selected tool. If you don't want it active at startup you must remember to activate it manually by clicking on the tool or sending T0 in the slicer start gcode.
        samu_87undefined 3 Replies Last reply Reply Quote 0
        • samu_87undefined
          samu_87 @Phaedrux
          @Phaedrux Yes I have the hotend wired in that way:
          • power on bedheat pin
          • control with MAX on daughter board
          Heated Bed:
          • Power on e1
          • sensor on e1
          This because i have a powerful heat cartiage on the extruder and a mosfet to control heated bed so i invert this because the bed mosfet on duet wifi handle more current.
          Maybe is useless but I hope that don't make a problema,I've been using this for about 4 years.
          When i power on the printer I find the heater 1 active and not off like the bed, see this image:
          • samu_87undefined
            samu_87 @Phaedrux
            @Phaedrux said in Duet Wifi - Accel:
            Now I have understand what do you mean, I'm used to the old graphics and every time I enable the Tool manually. I delete T0 in config.g and I'm okay 🙂
            • samu_87undefined
              samu_87 @Phaedrux
              @Phaedrux
              Hello, Thanks a lot because all work well now.
              The heated bed sometimes give me this:
              I'm sure that the wiring etc is all okay, I have a big heated bed with low power so it spend a lot of time to heating up.
              how I can modify that to give them more time?
              M307 H0 R0.186 K0.226:0.000 D1.09 E1.35 S1.00 B1
              Thanks!!!
              samu_87undefined 1 Reply Last reply Reply Quote 0
                What is the fault error that you're getting in the console?
                Can you send M308 S0 after you get a fault and report back with that message it gives you?
                What does the heater graph look like when it faults?
                • samu_87undefined
                  samu_87 @Phaedrux
                  @Phaedrux As soon as the error occurs again I will give you the necessary data.
                  It usually comes back early in the morning when it's cold, I have a lot of mass to heat up so it takes a little longer than usual and gives an error. For now, thank you very much!
                  • samu_87undefined
                    samu_87 @samu_87
                    @samu_87
                    M308 S0
                    Sensor 0 type Thermistor using pin e1temp, reading 82.2, last error: sensor not ready, T:100000.0 B:4138.0 C:0.00e+0 R:4700.0 L:0 H:0
                    Here the error... in a cold day the temperature rise slowly and the error appear.
                    Many thanks!
                      Can you try changing the R and D values in your M307 command to match this?
                      M307 H0 R0.25 K0.226:0.000 D2 E1.35 S1.00 B1
                      • samu_87undefined
                        samu_87 @Phaedrux
                        @Phaedrux
                        Yes I will try! What change R and D?
                        Thanks!
                          https://docs.duet3d.com/en/User_manual/Connecting_hardware/Heaters_tuning#manual-adjustments-to-the-heater-model-parameters
                          • samu_87undefined
                            samu_87 @Phaedrux
                            @Phaedrux Here we are, in this cold morning give me this error:
                            Which parameter is better to tweak?
                            Thanks!
                              Phaedrux Moderator @samu_87
                              Is this error with my previous suggestion?
                              • samu_87undefined
                                samu_87 @Phaedrux
                                @Phaedrux
                                Yes, I put R = 0,15 and I think is better, because my bed I think it has a low warm up rate.
                                Can have any sense?
                                Thansk!
                                  Please try this method to try and determine your R parameter.
                                  Measuring the heating rate (M307 R parameter)
                                  Turn the heater on from cold, wait a few seconds for the temperature to start rising, then time how long it takes for the temperature to rise by a further amount e.g. 10C (for a slow bed heater you might wish to use a smaller amount e.g. 5C). Divide that temperature rise by the time in seconds to get the heating rate.
