    height map off set to negative ?
    682
    • ap742undefined
      ap742
      hi guys I'm stuck. - running 3.4.4 duet 2 wifi - " printer Ender 5 plus "
      was fine till I did exoslide upgrade and exoslide hotend.
      pretty much moved my bltouch offset and stuff .
      so I started from scratch
      G31 P25 X-41 Y9.44 Z2.121
      M557 X-41:280 Y20:340 S38
      also added homeall because it wasn't compensating
      M558 F500 A1 ; probe once quickly
      G30
      M558 F120 A10 ; detailed probe
      G30
      so this is latest G29
      anyway no matter what the height map looks like - it'll print way to close to bed at the front of the bed
      if I understand correct compensation happens when numbers bit negative ? if so how do I adjust for the map to be bit below the grid ?
        Please post your config.g and homing files.
        Also please tell us where your endstops are located. It sounds like you may have your coordinate system misconfigured.
        Can you also confirm that -x moves to the left, +x to the right, -y to the front, +y to the back?
        ap742undefined 1 Reply Last reply Reply Quote 0
        • ap742undefined
          ap742 @Phaedrux
          @Phaedrux
          +x moves to the left from the end stop which is 0
          +y moves to the front from the end stop which is 0
          here's my config
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Apr 16 2021 19:18:05 GMT-0400 (Eastern Daylight Time)
          M550 P"E5" ; set printer name
          ;MCU temp
          M912 P0 S21 - 26
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P3 S0 ; physical drive 3 goes backwards
          M92 X80.00 Y80.00 Z800.00 E486.584 ; set steps per mm
          M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 E500.00 ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E1000 I30 ;Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X355 Y343 Z400 S0 ; set axis maxima x350 M208 X350 Y350 Z400 S0 <- hemera
          M574 Z0 ; configure Z-probe endstop on Z
          M591 P1 C"e0stop" S1 D0
          M558 P9 C"^zprobe.in" H2.5 F180 T6000 ; set Z probe type to bltouch and the dive height + speeds H2.5
          G31 P25 X-41 Y9.44 Z2.121 ; set Z probe trigger value, offset and trigger height
          M557 X-41:280 Y20:340 S38 ; define mesh grid
          ;M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp
          ;M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0
          ;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
          ;M140 H0 ; map heated bed to heater 0
          ;M143 H0 S120 ; set temperature limit for heater 0 to 120C
          ;M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp
          ;M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
          ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          ;M143 H1 S280 ; set temperature limit for heater 1 to 280C
          ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
          M308 S1 P"e0temp" Y"thermistor" A"Hotend" T100000 B4725 C7.06e-8 ;M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp
          M143 H1 S300 ; set temperature limit for heater 1 to 300C
          M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
          ; Custom settings
          ;591 D0 P2 C3 S1 ; Filament Run out sensor
          M307 H1 R2.896 C205.2:122.7 D7.66 S1.00 V24.2
          here's my homeall
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Apr 16 2021 19:18:06 GMT-0400 (Eastern Daylight Time)
          G91 ; relative positioning
          G1 H2 Z2.5 F6000 ; lift Z relative to current position
          G1 H1 X-360.5 Y-355 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F6000 ; go back a few mm
          G1 H1 X-360.5 Y-355 F360 ; move slowly to X and Y axis endstops once more (second pass)
          ;G1 H1 Z-405 F360 ; move Z down stopping at the endstop
          ;G90 ; absolute positioning
          ;G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
          ;G1 X220 Y175 F4000 ; Move probe to middle of bed
          G1 X140 Y160 F6000 ; go to first probe point
          G30
          G30
          Thank You
            Phaedrux Moderator @ap742
            @ap742 said in height map off set to negative ?:
            Ok that's fine. That just means your coordinates are rotated 180 degrees from standard, which isn't going to cause problems, though you may notice your prints coming out rotated from how the slicer preview shows.
            From your photo it looks like your probe offsets are reversed though.
            X-41 would mean the probe is closer to the low end of the axis to the right of the nozzle. Your photo shows the probe to the left, which in your case would be X+41. This would cause the heightmap to be incorrect.
            I can't quite tell if the probe is in front or behind the nozzle though. But the same rule applies, if it's closer to the low end, the value would be negative.
            • ap742undefined
              ap742 @Phaedrux
              @Phaedrux
              Thank You for that
              so I got that changed
              G31 P25 X41 Y-9.44 Z2.121
              how about define the mesh
              M557 X41:280 Y20:340 S38 if I do this it doesn't probe high end all the way
                That's because you're telling it to only probe between x41 and x280.
                The easiest way to define the heightmap size is just to make it equal to your actual bed size. Then it will use the probe offsets in G31 to only probe the areas it can actually reach. Just make sure your G31 offsets are correct first.
                • ap742undefined
                  ap742 @Phaedrux
                  @Phaedrux
                  Thank you 🙂
                  so I'm going to lean towards mechanical stuff . because its doing exactly the same thing as it did before
                  my starting gcode loads G29 S1 - assuming it should compensate
                  M106 S0 ; turn off cooling fan
                  G28
                  G29 S1
                  G92 E0 ; Reset Extruder
                  G1 Z10.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
                  G1 X344.5 Y300 Z0.28 F5000.0 ;Move to start position
                  G1 X344.5 Y90.0 Z0.28 F1500.0 E15 ;Draw the first line
                  G1 X344.7 Y90.0 Z0.28 F5000.0 ;Move to side a little
                  G1 X344.7 Y300 Z0.28 F1500.0 E30 ;Draw the second line
                  G92 E0 ; reset extrusion distance
                  G1 Z15.0 F6000 ;Move the nozzle up 15mm
                  G92 E0 ; Reset the extruder's origin
                    What does your heightmap look like now?
                    What does the resulting print look like?
                    If the heightmap isn't correcting as expected, that usually means there is some tilt or the print head that changes at different XY positions, or there is some skew in the XY motion plane.
                    • ap742undefined
                      ap742 @Phaedrux
                      @Phaedrux
                      so before I tear down and re check all the bearings and stuff " all new but we all know there's always chance "
                      here's what map looks like not perfect but.....
                      this is the front of the bed between 275 & 300
                      this one is the back between 50 and 75
                      Thank You
                        Can you describe your Z axis?
                        Do you do automatic or manual bed leveling?
                        Do you use bed.g?
                        • ap742undefined
                          ap742 @Phaedrux
                          @Phaedrux
                          Z is typical ender 5 plus config nothing really changed there.
                          its 2mm pitch 4mm lead
                          10mm linear rods all lubed with synthetic lube
                          z is pretty smooth
                          driven by two steppers 0.8A 1.8 degree
                          here's my bed config
                          ; bed.g
                          G29 ; probe the bed and enable compensation
                          so the way do it is
                          home all use 0.1 mm spacer to to get nozzle down to bed.
                          and repeat all this few times around all corners and center
                          than I run G31 S-1 few times to get average number for G31
                          after that I run G29
                          Adamfilipundefined 1 Reply Last reply Reply Quote 0
                          • Adamfilipundefined
                            Adamfilip @ap742
                            I have run into this before myself with portions being in the negative. what I did was basically try and home (if probing) to the low spot on the bed. making that area = 0 and the rest is just higher.
                            not a fix really but it worked for me lol
                            • ap742undefined
                              ap742 @Adamfilip
                              @Adamfilip
                              what do you mean make that area 0? how?
                              did you just edit heghtmap.csv and correct the numbers?
                                Adamfilip @ap742
                                @ap742 no. for example
                                if i do a mesh, and an area at X50 and Y50 is reading the lowest point at Z-1
                                I will set my Z probe to home at X50 and Y50, that way it will set the lowest part of the bed to be the zero point and everything else should be higher, when I remeasure the mesh
                                  Phaedrux Moderator @Adamfilip
                                  @Adamfilip It shouldn't really matter since the compensation can go up or down, but it can help to match the Z homing G30 point to one of the probe points of the mesh.
