Solved Part fans no spinning on T1 and T3 on new e3d Tool Changer
I have a new e3d Tool Changer using Duet 2 Wifi and duex5. I have fans wired and setup this way.
M950 F1 C"fan1"
M950 F2 C"fan2"
M950 F3 C"duex.fan3"
M950 F4 C"duex.fan4"
M950 F5 C"duex.fan5"
M950 F6 C"duex.fan6"
M950 F7 C"duex.fan7"
M950 F8 C"duex.fan8"M106 P1 S255 H1 T70 ; T0 HE
M106 P2 S0 ; T0 PCF
M106 P3 S255 H2 T70 ; T1 HE
M106 P4 S0 ; T1 PCF
M106 P5 S255 H3 T70 ; T2 HE
M106 P6 S0 ; T2 PCF
M106 P7 S255 H4 T70 ; T3 HE
M106 P8 S0 ; T3 PCF;M593 F42.2 ; cancel ringing at 42.2Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/)
M593 P"zvdd" F42.8
M376 H15 ; bed compensation taperAll is wired like this video @ 26.48 mark in video:
https://www.youtube.com/watch?v=2V_pB3WeeLA&list=PLg-PjJGb4u-IPordfd1h-RPx3y6trxZdm&index=7
Can you share your full config.g?
; Configuration file for Duet WiFi / Ethernet running RRF3 on E3D Tool Changer ; executed by the firmware on start-up ; General preferences M111 S0 ; Debugging off G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M555 P2 ; Set firmware compatibility to look like Marlin M667 S1 ; Select CoreXY mode ; Network M550 P"ToolChanger" ; Set machine name M552 S1 ; Enable Networking M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drive direction M569 P0 S0 ; Drive 0 X M569 P1 S0 ; Drive 1 Y M569 P2 S1 ; Drive 2 Z M569 P3 S0 ; Drive 3 E0 M569 P4 S0 ; Drive 4 E1 M569 P5 S0 ; Drive 5 E2 M569 P6 S0 ; Drive 6 E3 M569 P7 S0 ; Drive 7 COUPLER M569 P8 S0 ; Drive 8 UNUSED ;M569 P9 S0 ; Drive 9 See pebble extruder config at the bottom M584 X0 Y1 Z2 C7 E3:4:5:6 ; Apply custom drive mapping M208 X-35:328.5 Y-49:243 Z0:300 C-45:360 ; Set axis maxima & minima M92 X100 Y100 Z800 C91.022 E409:409:409:409 ; Set steps per mm assuming x16 microstepping M350 E16:16:16:16 I1 ; Configure microstepping with interpolation M350 C16 I10 ; Configure microstepping without interpolation M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation M566 X400 Y400 Z8 C2 E2:2:2:2 ; Set maximum instantaneous speed changes (mm/min) M203 X35000 Y35000 Z1200 C5000 E5000:5000:5000:5000 ; Set maximum speeds (mm/min) M201 X6000 Y6000 Z400 C500 E2500:2500:2500:2500 ; Set accelerations (mm/s^2) M906 X1800 Y1800 Z1330 I30 ; Idle motion motors to 30% M906 E1000:1000:1000:1000 C500 I10 ; Idle extruder motors to 10% ; Endstops M574 X1 Y1 S3 ; Set X / Y endstop stall detection M574 C0 Z0 ; No C Z endstop ; Z probe M558 P8 C"zstop" H3 F360 I0 T20000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds G31 P200 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height M557 X10:290 Y20:180 S40 ; Define mesh grid ;Stall Detection ;M915 X Y S3 F0 H400 R4700 ; X / Y Axes M915 X Y S3 F0 H400 R2 ; X / Y Axes ; Heaters M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4138 C0 ; Set thermistor M950 H0 C"bedheat" T0 ; Bed heater M143 H0 S225 ; Set temperature limit for heater 0 to 225C M140 H0 ; Bed heater is heater 0 M308 S1 P"e0temp" Y"thermistor" A"T0" T100000 B4725 C7.06e-8 ; Set thermistor M950 H1 C"e0heat" T1 ; Extruder 0 heater M143 H1 S305 ; Set temperature limit for heater 1 to 300C M308 S2 P"e1temp" Y"thermistor" A"T1" T100000 B4725 C7.06e-8 ; Set thermistor M950 H2 C"e1heat" T2 ; Extruder 0 heater M143 H2 S305 ; Set temperature limit for heater 2 to 300C M308 S3 P"e2temp" Y"thermistor" A"T2" T100000 B4725 C7.06e-8 ; Set thermistor M950 H3 C"duex.e2heat" T3 ; Extruder 0 heater M143 H3 S305 ; Set temperature limit for heater 3 to 300C M308 S4 P"e3temp" Y"thermistor" A"T3" T100000 B4725 C7.06e-8 ; Set thermistor M950 H4 C"duex.e3heat" T4 ; Extruder 0 heater M143 H4 S305 ; Set temperature limit for heater 4 to 300C ; Tools M563 P0 S"T0" D0 H1 F2 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Reset tool 0 axis offsets G10 P0 R0 S0 ; Reset initial tool 0 active and standby temperatures to 0C M563 P1 S"T1" D1 H2 F4 ; Define tool 1 G10 P1 X0 Y0 Z0 ; Reset tool 1 axis offsets G10 P1 R0 S0 ; Reset initial tool 1 active and standby temperatures to 0C M563 P2 S"T2" D2 H3 F6 ; Define tool 2 G10 P2 X0 Y0 Z0 ; Reset tool 2 axis offsets G10 P2 R0 S0 ; Reset initial tool 2 active and standby temperatures to 0C M563 P3 S"T3" D3 H4 F8 ; Define tool 3 G10 P3 X0 Y0 Z0 ; Reset tool 3 axis offsets G10 P3 R0 S0 ; Reset initial tool 3 active and standby temperatures to 0C ; Fans M950 F1 C"fan1" M950 F2 C"fan2" M950 F3 C"duex.fan3" M950 F4 C"duex.fan4" M950 F5 C"duex.fan5" M950 F6 C"duex.fan6" M950 F7 C"duex.fan7" M950 F8 C"duex.fan8" M106 P1 S255 H1 T70 ; T0 HE M106 P2 S0 ; T0 PCF M106 P3 S255 H2 T70 ; T1 HE M106 P4 S0 ; T1 PCF M106 P5 S255 H3 T70 ; T2 HE M106 P6 S0 ; T2 PCF M106 P7 S255 H4 T70 ; T3 HE M106 P8 S0 ; T3 PCF ;M593 F42.2 ; cancel ringing at 42.2Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/) M593 P"zvdd" F42.8 M376 H15 ; bed compensation taper ;tool offsets ; !ESTIMATED! offsets for: ; V6-tool: X-9 Y39 Z-5 ; Volcano-tool: X-9 Y39 Z-13.5 ; Hemera-tool: X20 Y43.5 Z-6 G10 P0 X20.00 Y43.5 Z-5.78 ; T0 G10 P1 X17.614 Y44.549 Z-5.36 ; T1 G10 P2 X18.603 Y43.967 Z-5.69 ; T2 G10 P3 X20.0 Y43.58 Z-5.80 ; T3 ;M572 D0 S0.2 ; pressure advance T0 ;M572 D1 S0.2 ; pressure advance T1 ;M572 D2 S0.2 ; pressure advance T2 ;M572 D3 S0.2 ; pressure advance T3 ; Pebble wiper config M569 P9 S1 D2 ; Drive 9 direction | A M584 A9 ; Axis to driver mapping M208 A0:58 ; Set axis software limits and min/max switch-triggering positions M350 A16 I1 ; Configure microstepping with interpolation M906 A600 I5 ; Set motor currents (mA) and idle percent A400 M203 A6000 ; Max speeds (mm/min) M201 A1200 ; Max Accelerations (mm/s^2) M566 A360 ; Max jerk (mm/min) M92 A360 ; Steps/mm M915 A S5 F0 H200 R0 ; A Stall Detection M950 F9 C"^duex.pwm5" Q333 ; Wipe Servo M106 P9 C"Wipe" ; Wipe Servo ; End of Config M575 P1 S1 B57600 ; Enable LCD G29 S2 ; disable mesh T-1 ; deselect tools M501 ; load config-override.g
You're defining your tools before you're defining the fans. This may be the cause.
You can also send M98 P"config.g" to check for any syntax errors.
@Phaedrux that is the config from e3d site. Interesting. I will try that in a few. Running single color print right now.
I'm not sure it makes a difference, but it stood out to me.
@Phaedrux No errors. Didn't change anything.
Do the fans start if you manually send M106 P2 S1?
Probably worth mentioning all the steps taken from the discussion from the E3D discord.
Such as, replacing fans and that the fans do work on the other tools, but as far as I'm aware you were testing if a metal washer between the fan and motor fixes the issue as experienced by other users. Or simply moving the fan 6-8" away from the Hemera and testing again.
@Phaedrux said in Part fans no spinning on T1 and T3 on new e3d Tool Changer:
M106 P2 S1
That starts T0 fan and it spins.
How would I verify if Duex 5 works? I am starting to think might be issue with board.
@rmilyard said in Part fans no spinning on T1 and T3 on new e3d Tool Changer:
M106 P2 S1
And for the other fans? Change P2 to match the fan number. Do the rest work?
If the fans work when manually sending the commands there is likely a slicer configuration issue.
@Phaedrux Nope. Fans for T1 and T3 don't work. Others 2 do.
Can you test those fans on a working fan port to see if the fans themselves work?
M106 P2 S1
Did the washer thing and didn't work. Also took fan as far as I can from extruder and still not working.
What is the washer thing?
Did you connect them to an always on fan port?
@Phaedrux was told to try put steel washer between fan and extruder.
For wiring done way shows in René Jurack's youtube video.
@Phaedrux The "washer thing" is a possible solution to the problem described here: https://forum.e3d-online.com/threads/issue-with-print-cooling-fan-on-hemera-tool.3980/ you may recognise the author of that post!
Ok, but I'm asking if the fan has been tested connected directly to voltage.
Work been crazy today so haven't been able to mess with this. I will try more tomorrow or weekend.
