    48V in and 24V out? (Duet 3 Main Board 6HC)
    voltage board electronic questions connection 24volt
    768
    • tklnundefined
      tkln
      I want to feed the board with 48v to drive the stepper motors with 48v. But I want to operate the rest of the electronics like hotend, fan, etc. with 24V. Can I connect 48V to the HC6 and turn the other ports down to 24V?
      Or can I connect both 48V (only for motor) and 24V to the HC6?
      Best regards
      Tim
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @tkln
        @tkln you can't do either directly with the 6HC v1.02. You can only feed 48v into the board itself.
        You can however use a separate 24v PSU and supply 24v to each of the fans and heaters and then connect the negative side of the heaters and fans to the negative on each of the corresponding connections on the board.
        All duet boards switch on the negative supply on the board.
        Make sure you tie the grounds of the 24v and 48v PSU's together.
        tklnundefined 1 Reply Last reply Reply Quote 1
        • tklnundefined
          tkln @jay_s_uk
          @jay_s_uk
          Hey Thanks for your quick response.
          Is it correct as shown in the picture?
          Best Regards
          Tim
          jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @tkln
            @tkln yes, that looks correct
              dc42 administrators @tkln
              @tkln if your hot ends take standard heater cartridges then it's possible to buy 48V cartridges - but not yet for smaller hot ends that don't use cartridges.
              • tklnundefined tkln has marked this topic as solved
                droftarts administrators @tkln
                @tkln The wiring diagram is a 3HC, but you were asking about a 6HC. If you are doing this to a 3HC, again make sure you have the v1.02 board revision, which is 48V-capable. Previous versions are only 32V-capable. The 3HC expansion board can run at a different voltage from the mainboard (6HC?).
                • tklnundefined
                  tkln @droftarts
                  @droftarts Thanks for the reply.
                  Of course I meant the hc6 just used the wrong picture. But the procedure is the same for both the hc6 and the hc3 expansion board, right?
                    @tkln said in 48V in and 24V out? (Duet 3 Main Board 6HC):
                    Yes
                    • woodyundefined
                      woody
                      Hi guys, did you ever resolve this? I'm going through a similar issue. Thinking of running 24V to my 6HC and 48V to the expansion board (3HC). Will this work? New topic posted here:
                      https://forum.duet3d.com/topic/36953/duet6hc-24v-and-48v-psu-s-for-different-components/8?_=1731730867239
                      Thanks 🙂
