    PanelDue compilation fail
    PanelDue
    475
    • g.bielundefined
      g.biel
      Hello.
      I have an Ender5 printer with duo 2 wifi and paneldue for 3 years.
      A few days ago I installed new printer firmware. everything went smoothly. But now I have a problem with paneldue, there I had modified software.
      The problem is that on the second computer I can't generate software for paneldue.3.4.1 no matter what Eclipse IDE I use I get the same errors and the compilation stops.
      any help please...
      20:04:17 **** Build of configuration Release-v3-7.0 for project PanelDue ****
      make -j4 all
      Building file: ../src/UI/ColourSchemes.cpp
      Building file: ../src/UI/Display.cpp
      Building file: ../src/UI/MessageLog.cpp
      Building file: ../src/UI/Popup.cpp
      Invoking: Cross G++ Compiler
      arm-none-eabi-g++ -std=gnu++17 -DNDEBUG -D__SAM4S4B__ -DBOARD=USER_BOARD -DARM_MATH_CM4=true -DSCREEN_70 -I"C:\Eclipse\oki\RRFLibraries" -I"C:\Eclipse\oki\PanelDue\src\config" -I"C:\Eclipse\oki\PanelDue\src\ASF\thirdparty\CMSIS\Lib\GCC" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\cmsis\sam4s\include" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\utils" -I"C:\Eclipse\oki\PanelDue\src" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\cmsis\sam4s\source\templates" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\preprocessor" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\boards" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\header_files" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\boards\user_board" -I"C:\Eclipse\oki\PanelDue\src\ASF\thirdparty\CMSIS\Include" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\pio" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\pmc" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\services\clock" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\services\delay" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\wdt" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\pwm" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\uart" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\matrix" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\efc" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\services\flash_efc" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\rstc" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\chipid" -I"C:\Eclipse\oki\RRFLibraries\src" -Os -Wall -c -mthumb -MD -MP -mcpu=cortex-m4 -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -nostdlib --param max-inline-insns-single=500 -mlong-calls -Wno-expansion-to-defined -MMD -MP -MF"src/UI/ColourSchemes.d" -MT"src/UI/ColourSchemes.o" -o "src/UI/ColourSchemes.o" "../src/UI/ColourSchemes.cpp"
      arm-none-eabi-g++ -std=gnu++17 -DNDEBUG -D__SAM4S4B__ -DBOARD=USER_BOARD -DARM_MATH_CM4=true -DSCREEN_70 -I"C:\Eclipse\oki\RRFLibraries" -I"C:\Eclipse\oki\PanelDue\src\config" -I"C:\Eclipse\oki\PanelDue\src\ASF\thirdparty\CMSIS\Lib\GCC" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\cmsis\sam4s\include" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\utils" -I"C:\Eclipse\oki\PanelDue\src" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\cmsis\sam4s\source\templates" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\preprocessor" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\boards" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\header_files" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\boards\user_board" -I"C:\Eclipse\oki\PanelDue\src\ASF\thirdparty\CMSIS\Include" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\pio" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\pmc" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\services\clock" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\services\delay" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\wdt" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\pwm" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\uart" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\matrix" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\efc" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\services\flash_efc" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\rstc" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\chipid" -I"C:\Eclipse\oki\RRFLibraries\src" -Os -Wall -c -mthumb -MD -MP -mcpu=cortex-m4 -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -nostdlib --param max-inline-insns-single=500 -mlong-calls -Wno-expansion-to-defined -MMD -MP -MF"src/UI/Display.d" -MT"src/UI/Display.o" -o "src/UI/Display.o" "../src/UI/Display.cpp"
      arm-none-eabi-g++ -std=gnu++17 -DNDEBUG -D__SAM4S4B__ -DBOARD=USER_BOARD -DARM_MATH_CM4=true -DSCREEN_70 -I"C:\Eclipse\oki\RRFLibraries" -I"C:\Eclipse\oki\PanelDue\src\config" -I"C:\Eclipse\oki\PanelDue\src\ASF\thirdparty\CMSIS\Lib\GCC" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\cmsis\sam4s\include" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\utils" -I"C:\Eclipse\oki\PanelDue\src" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\cmsis\sam4s\source\templates" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\preprocessor" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\boards" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\header_files" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\boards\user_board" -I"C:\Eclipse\oki\PanelDue\src\ASF\thirdparty\CMSIS\Include" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\pio" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\pmc" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\services\clock" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\services\delay" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\wdt" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\pwm" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\uart" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\matrix" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\efc" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\services\flash_efc" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\rstc" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\chipid" -I"C:\Eclipse\oki\RRFLibraries\src" -Os -Wall -c -mthumb -MD -MP -mcpu=cortex-m4 -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -nostdlib --param max-inline-insns-single=500 -mlong-calls -Wno-expansion-to-defined -MMD -MP -MF"src/UI/MessageLog.d" -MT"src/UI/MessageLog.o" -o "src/UI/MessageLog.o" "../src/UI/MessageLog.cpp"
      arm-none-eabi-g++ -std=gnu++17 -DNDEBUG -D__SAM4S4B__ -DBOARD=USER_BOARD -DARM_MATH_CM4=true -DSCREEN_70 -I"C:\Eclipse\oki\RRFLibraries" -I"C:\Eclipse\oki\PanelDue\src\config" -I"C:\Eclipse\oki\PanelDue\src\ASF\thirdparty\CMSIS\Lib\GCC" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\cmsis\sam4s\include" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\utils" -I"C:\Eclipse\oki\PanelDue\src" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\cmsis\sam4s\source\templates" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\preprocessor" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\boards" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\utils\header_files" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\boards\user_board" -I"C:\Eclipse\oki\PanelDue\src\ASF\thirdparty\CMSIS\Include" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\pio" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\pmc" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\services\clock" -I"C:\Eclipse\oki\PanelDue\src\ASF\common\services\delay" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\wdt" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\pwm" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\uart" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\matrix" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\efc" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\services\flash_efc" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\rstc" -I"C:\Eclipse\oki\PanelDue\src\ASF\sam\drivers\chipid" -I"C:\Eclipse\oki\RRFLibraries\src" -Os -Wall -c -mthumb -MD -MP -mcpu=cortex-m4 -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -nostdlib --param max-inline-insns-single=500 -mlong-calls -Wno-expansion-to-defined -MMD -MP -MF"src/UI/Popup.d" -MT"src/UI/Popup.o" -o "src/UI/Popup.o" "../src/UI/Popup.cpp"
      In file included from ../src/UI/UserInterface.hpp:12,
                       from ../src/UI/MessageLog.cpp:9:
      C:\Eclipse\oki\PanelDue\src/Library/Thumbnail.hpp:7:10: fatal error: qoi.h: No such file or directory
       #include "qoi.h"
      compilation terminated.
      src/UI/subdir.mk:30: recipe for target 'src/UI/MessageLog.o' failed
      make[1]: *** [src/UI/MessageLog.o] Error 1
      make[1]: *** Waiting for unfinished jobs....
      In file included from C:\Eclipse\oki\PanelDue\src/FlashData.hpp:8,
                       from C:\Eclipse\oki\PanelDue\src/UI/Popup.hpp:4,
                       from ../src/UI/Popup.cpp:1:
      C:\Eclipse\oki\PanelDue\src/UI/Display.hpp:738:10: fatal error: qoi.h: No such file or directory
       #include "qoi.h"
      In file included from ../src/UI/Display.cpp:8:
       #include "qoi.h"
      src/UI/subdir.mk:30: recipe for target 'src/UI/Popup.o' failed
      make[1]: *** [src/UI/Popup.o] Error 1
      make[1]: *** [src/UI/Display.o] Error 1
      src/UI/subdir.mk:30: recipe for target 'src/UI/Display.o' failed
      Finished building: ../src/UI/ColourSchemes.cpp
      makefile:75: recipe for target 'all' failed
      make: *** [all] Error 2
      "make -j4 all" terminated with exit code 2. Build might be incomplete.
      20:04:19 Build Failed. 12 errors, 0 warnings. (took 2s.239ms)
      PanelDue1.2.4 builds correctly:
      Generating binary
      arm-none-eabi-objcopy -O binary "C:/Eclipse/PanelDue1.24.1/PanelDue/Release-v3-7.0/PanelDue-v3-7.0.elf" "C:/Eclipse/PanelDue1.24.1/PanelDue/Release-v3-7.0/PanelDue-v3-7.0-nologo.bin" && cat "C:/Eclipse/PanelDue1.24.1/PanelDue/Release-v3-7.0/PanelDue-v3-7.0-nologo.bin" "C:/Eclipse/PanelDue1.24.1/PanelDue/SplashScreens/SplashScreen-Duet3D-800x480.bin" >"C:/Eclipse/PanelDue1.24.1/PanelDue/Release-v3-7.0/PanelDue-v3-7.0.bin"
      20:00:42 Build Finished. 0 errors, 0 warnings. (took 15s.781ms)
        dc42 administrators @g.biel
        @g-biel PanelDueFirmware is now built using Cmake, not Eclipse. See the Readme file in the PanelDueFirmware github repository.
        g.bielundefined mfs12undefined 2 Replies Last reply Reply Quote 0
        • g.bielundefined
          g.biel @dc42
          Try . Only now I have another problem:
          ok@Ultrabook:~$ git clone git@github.com:Duet3D/PanelDueFirmware.git
          Cloning into 'PanelDueFirmware'...
          The authenticity of host 'github.com (140.82.121.3)' can't be established.
          ED25519 key fingerprint is SHA256:+DiY3wvvV6TuJJhbpZisF/zLDA0zPMSvHdkr4UvCOqU.
          This key is not known by any other names
          Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
          Warning: Permanently added 'github.com' (ED25519) to the list of known hosts.
          git@github.com: Permission denied (publickey).
          fatal: Could not read from remote repository.
          Please make sure you have the correct access rights
          and the repository exists.
          Or maybe someone will tell you how to do this step from Windows 10.
          dc42undefined 2 Replies Last reply Reply Quote 0
            @g-biel we are looking into this.
            • mfs12undefined
              mfs12 @dc42
              @dc42 said in PanelDue compilation fail:
              There's an easy way to import the project into eclipse to have a seamless experience. Please refer to the readme file in PanelDueFirmware repository.
              Visit me on github at https://github.com/mfs12/
              • mfs12undefined
                mfs12
                alternatively you can try to use
                git clone https://github.com/Duet3D/PanelDueFirmware.git
                cd PanelDueFirmware
                git submodule update --init
                for cloning. this doesn't need any authentication in contrast to ssh.
                  @g-biel we have fixed this so please update the PanelDueFirmware project and try again. Also I have updated the Eclipse project files, so you can now build under Eclipse as an alternative to Cmake.
                  • g.bielundefined
                    g.biel
                    Eclipse build still doesn't work.
                    On Ubuntu WSL went further, but there are still errors and it doesn't complete the compilation.
                    I tried on another computer and same errors.
                    • g.bielundefined
                      g.biel
                      Was this change necessary? : link text
                      Ubuntu WSL.
                      There is some progress. I removed the "-Wl,--no-warn-rwx-segments" from the CMakeLists.txt file and it generated the files probably correctly. I didn't make any changes for the test. I haven't uploaded yet because my file is 171KB and on Git there is PanelDueFirmware-3.4.1-v3-7.0.bin with a size of 167KB.
                      Are my files correct?
                        @g-biel regarding your Eclipse build, the error message is that file qoi.h wasn't found. There are a couple of causes for this that I can think of:
                        1. You have not updated the PanelDueFirmware project to my latest commit that includes an updated .cproject file. In that commit I added additional include paths to the folder that contains this file.
                        2. The qoi submodule within the PanelDueFirmware project has not been populated. Check whether file qoi.h is present in PanelDueFirmware/lib/qoi:
                        If it is not present then either you didn't run git submodule update or it didn't work.
                        Regarding the Ubuntu build, my guess is that you are using an older version of the arm-none-eabi build of gcc and related development tools. This could account for both the error message when you don't remove that linker option, and the larger (less optimised) binary.
                        g.bielundefined 1 Reply Last reply Reply Quote 0
                        • g.bielundefined
                          g.biel @dc42
                          OK.
                          I give up . Maybe I'll come back to the topic when a new version comes out. Maybe someone will be more determined to run it on Eclipse.
                          For now, I'm staying on version 1.24.1. (This still compiles without errors)
                          Regards.
                          • g.bielundefined
                            g.biel
                            Finally it worked. 😄
                            I found the solution here: https://forum.duet3d.com/post/227278
                            Regards, you can close the thread.
                            • T3P3Tonyundefined T3P3Tony marked this topic as a question
                            • T3P3Tonyundefined T3P3Tony has marked this topic as solved
