    PT100 DAUGHTER BOARD, Reading 2000 c for Heat Bed
    • ScaraManundefined
      ScaraMan
      Hi
      I recently purchased the PT100 Daughterboard latest version with jumpers.
      I have some issues.
      The reason why I bought this board, was to connect the Ultimaker 2 heatbed to the Duet wifi.
      That’s all, but when I connect it reads 2000 C for the Bed, I am using rep rap firmware2.x
      I followed the instructions on the web on how to configure firmware.
      The 2 wires for power go to heatbed connector on Duet wifi , and the other 2 wires I have connected to PT 100 motherboard (2 and 3 on the first connector )
      The jumpers are there on both connectors.
      I am only using 1 connector for the heatbed only, not for my hotend ( since that is a e3d v6 no pt100 sensor )
      Can you please tell me how to fix this issue ??
      How to properly configure ??
      Currently under the Heater section in config file I have this
      M305 P0 X200 ; set thermistor + ADC parameters for heater 0
      M143 H0 S65 ; set temperature limit for heater 0 to 80C
      M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M143 H1 S260 ; set temperature limit for heater 1 to 260C
      jay_s_ukundefined Norderundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @ScaraMan
        @ScaraMan can you post a photo of your wiring?
        can you also post an output of M122
        ScaraManundefined 1 Reply Last reply Reply Quote 0
        • Norderundefined
          Norder @ScaraMan
          @ScaraMan Hi,
          Please post some information about the heating mat used on the print bed... which thermistor is installed there?
          Then I would strongly recommend you to update to the latest firmware.
          DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
          Thingiverse
          • ScaraManundefined
            ScaraMan @jay_s_uk
              Can you post your full config.g and the results of M122 and M98 P"config.g"?
              Can you check this troubleshooting step please?
              https://docs.duet3d.com/User_manual/Connecting_hardware/Temperature_connecting_PT100#troubleshooting
