    New Z Sensor?
    13
    857
    • BlueDustundefined
      BlueDust
      Is it possible to get something like this working on the Duet Board?
      https://www.youtube.com/watch?v=Gs6UC2xK5t0
      Fun, that 3 letter word with "u" in the middle.
        jay_s_uk @BlueDust
        @BlueDust the beacon currently doesn't work with RRF
        BlueDustundefined 1 Reply Last reply Reply Quote 1
        • BlueDustundefined
          BlueDust @jay_s_uk
          @jay_s_uk
          Thanks for the quick feedback!
            dc42 administrators @BlueDust
            @BlueDust the fact that it connects via USB is the biggest issue. A version that connected via serial, an analog connection or even I2C would be reasonably straightforward to support.
            • BlueDustundefined
              BlueDust @dc42
              Understood. My thought was that if supported, it would require a Duet3 and using an SBC.
                @BlueDust I have plans for a scanning sensor that doesn't need USB and connects via CAN bus.
                weed2allundefined 1 Reply Last reply Reply Quote 6
                • weed2allundefined
                  weed2all @dc42
                  @dc42 tell us more please!
                  https://www.thingiverse.com/weed2all/designs
                    dc42 administrators @weed2all
                    @weed2all said in New Z Sensor?:
                    Well, the code to support scanning Z probes is almost complete in RRF 3.5.0-beta.3. (see new Z probe type 12). We still need to add the calibration function, which will most likely be a new M-command.
                    As for the probes, our IR sensor with different firmware on the ATTiny could be used, but it would need a bed that is visually uniform to work well. So I've been prototyping an inductive sensor using a head much smaller than the Beacon. I think it's important to use a small head, because it allows a small offset from the nozzle to be used (which is important, because nozzle offset has a different effect depending on whether the probe is compensating for bed un-evenness or gantry sag/skew), and it allows a finer mesh resolution (a large sense head will average over the whole area that the coil covers, and then some; so it makes little sense to make the mesh smaller than the coil diameter).
                    I hope to take this further next month. Don't hold your breath; we still have a lot of testing and more prototyping to do before we can consider putting a sensor into production.
                    oozeBotundefined Proschi3Dundefined 2 Replies Last reply Reply Quote 3
                    • oozeBotundefined
                      oozeBot @dc42
                      @dc42 let us know how we can assist with prototyping / testing. We are very interested..
                      • Proschi3Dundefined
                        Proschi3D @dc42
                        @dc42 wow I would like to offer myself as a beta tester
                        Love my Duet 3 Mini.
                        https://www.instagram.com/proschi3d
                        https://youtube.com/@proschi3d
                        https://www.proschi3d.de
                        • Jrowundefined
                          Jrow
                          It seems irrelevant to me whether or not the sensor can be implemented on the Duet, if it can record data on an external device, then transfer that data to the Duet.
                          BTW, an FYI for the others in this thread. I started a discussion about another sensor option being discussed by the PrintNC community; https://forum.duet3d.com/topic/32134/a-potential-highly-accurate-sensor-for-levelling
                          • oliofundefined
                            oliof @Jrow
                            @Jrow the measured data needs to be tracking with position precisely or you get an offset mesh which is worth squat. Quite difficult to do with offdevice storage (but not impossible!).
                            • DeadNewbieundefined
                              DeadNewbie
                              I am so eagerly waiting to here more on this, I run 2 Duet3s with bltouch, and I am running out of spare tips 😊
