    Compiling/Building PanelDue Firmware
    PanelDue
    1.4k
    • R006undefined
      R006
      hey,
      I am try to build customized PanelDue Firmware using Eclipes but it's gives the following error.
      C:\Users\rishita.butala\eclipse-workspace\Firmware\PanelDueFirmware\src/Library/Thumbnail.hpp:7:10: fatal error: qoi.h: No such file or directory
      7 | #include "qoi.h"
      compilation terminated.
      In file included from ../src/UI/UserInterface.hpp:12,
      from ../src/UI/MessageLog.cpp:9:
      In file included from ../src/ObjectModel/Axis.cpp:8:
      ../src/ObjectModel/Axis.hpp:12:10: fatal error: General/FreelistManager.h: No such file or directory
      12 | #include <General/FreelistManager.h>
      In file included from ../src/ObjectModel/BedOrChamber.cpp:8:
      ../src/ObjectModel/BedOrChamber.hpp:13:10: fatal error: General/FreelistManager.h: No such file or directory
      13 | #include <General/FreelistManager.h>
      In file included from ../src/ObjectModel/Spindle.cpp:8:
      ../src/ObjectModel/Spindle.hpp:12:10: fatal error: General/FreelistManager.h: No such file or directory
      src/UI/subdir.mk:30: recipe for target 'src/UI/UserInterface.o' failed
      make[1]: *** [src/UI/UserInterface.o] Error 1
      src/UI/subdir.mk:30: recipe for target 'src/UI/MessageLog.o' failed
      make[1]: *** Waiting for unfinished jobs....
      src/ObjectModel/subdir.mk:30: recipe for target 'src/ObjectModel/Axis.o' failed
      make[1]: *** [src/UI/MessageLog.o] Error 1
      src/ObjectModel/subdir.mk:30: recipe for target 'src/ObjectModel/BedOrChamber.o' failed
      make[1]: *** [src/ObjectModel/Axis.o] Error 1
      make[1]: *** [src/ObjectModel/BedOrChamber.o] Error 1
      src/ObjectModel/subdir.mk:30: recipe for target 'src/ObjectModel/Spindle.o' failed
      make[1]: *** [src/ObjectModel/Spindle.o] Error 1
      In file included from ../src/ObjectModel/Tool.hpp:12,
      from ../src/ObjectModel/Tool.cpp:8:
      src/ObjectModel/subdir.mk:30: recipe for target 'src/ObjectModel/Tool.o' failed
      make[1]: *** [src/ObjectModel/Tool.o] Error 1
      In file included from ../src/UI/Display.cpp:8:
      C:\Users\rishita.butala\eclipse-workspace\Firmware\PanelDueFirmware\src/UI/Display.hpp:738:10: fatal error: qoi.h: No such file or directory
      738 | #include "qoi.h"
      src/UI/subdir.mk:30: recipe for target 'src/UI/Display.o' failed
      make[1]: *** [src/UI/Display.o] Error 1
      In file included from C:\Users\rishita.butala\eclipse-workspace\Firmware\PanelDueFirmware\src/FlashData.hpp:8,
      from C:\Users\rishita.butala\eclipse-workspace\Firmware\PanelDueFirmware\src/UI/Popup.hpp:4,
      from ../src/UI/Popup.cpp:1:
      src/UI/subdir.mk:30: recipe for target 'src/UI/Popup.o' failed
      make[1]: *** [src/UI/Popup.o] Error 1
      makefile:75: recipe for target 'all' failed
      make: *** [all] Error 2
      "make -j8 all" terminated with exit code 2. Build might be incomplete.
      10:26:24 Build Failed. 27 errors, 0 warnings. (took 2s.944ms)
      i am try to add qoi.h file in given path it's not available in project.
      Any Suggestions? @Phaedrux
      • Phaedruxundefined Phaedrux moved this topic from General Discussion
        jay_s_uk @R006
        @R006 I know the QOI stuff is a submodule of the git repo and needs to be initialized correctly
        You must run two commands: git submodule init to initialize your local configuration file, and git submodule update to fetch all the data from that project and check out the appropriate commit listed in your superproject:
        • R006undefined
          R006
          @jay_s_uk it's not working.
            jay_s_uk @R006
            @R006 in what way isn't it working?
            • R006undefined
              R006
              @jay_s_uk giving same error
              nd plzz explain me how to build it in simple terms.
                dc42 administrators @R006
                @R006 it build for me, using the master branch of PanelDueFirmware and Eclipse. Tol fix the errors relating to including file "qoi.h" you need to pull in the qoi library source files like this:
                • Open a command prompt
                • cd to the lib/qoi folder within the project
                • Run the two git commands that @jay_s_uk listed in his reply
                To fix the errors relating to <General/FreelistManager.h> you need to add the RRFLibraries project to your workspace.
                • R006undefined
                  R006
                  @dc42 thank you for reply.
                  but it give the fatal error: not a git repository (or any of the parent directories): .git
                  and already add in workspace. but giving errors:
                  C:\Users\rishita.butala\eclipse-workspace\Firmware\RRFLibraries\src/General/FreelistManager.h:39:7: error: 'freelist' was not declared in this scope; did you mean 'Freelist'?
                  39 | if (freelist != nullptr)
                  | Freelist
                  C:\Users\rishita.butala\eclipse-workspace\Firmware\RRFLibraries\src/General/FreelistManager.h: In static member function 'static void FreelistManager::Freelist<Sz>::ReleaseItem(void*)':
                  C:\Users\rishita.butala\eclipse-workspace\Firmware\RRFLibraries\src/General/FreelistManager.h:54:35: error: 'freelist' was not declared in this scope; did you mean 'Freelist'?
                  54 | *reinterpret_cast<void *>(p) = freelist;
                  | Freelist
                  | Freelist
                  54 | *reinterpret_cast<void **>(p) = freelist;
                  | Freelist
                  Any Suggestions? @jay_s_uk
                  R006undefined 1 Reply Last reply Reply Quote 0
                  • mfs12undefined
                    mfs12
                    @R006 check the readme file in the repo.
                    https://github.com/Duet3D/PanelDueFirmware/blob/master/Readme.md#setup-repository
                    Visit me on github at https://github.com/mfs12/
                    • R006undefined
                      R006 @R006
                      @dc42 qoi.h error resolved by adding that file into that particular folder.
                      but now freelistManagment.h file giving error.
                      I am building RRF 3.4.4.
                      C:\Users\rishita.butala\eclipse-workspace\Firmware\RRFLibraries\src/General/FreelistManager.h:31:33: error: expected initializer before 'Freelist'
                      31 | template<size_t Sz> void null Freelist<Sz>::freelist = nullptr;
                      FreelistManager::Freelist<Sz>::AllocateItem()':
                      | Freelist
                      | Freelist
                      Finished building: ../src/UI/ColourSchemes.cpp
                      so any suggestions? i am waiting your reply.
                        @R006 which version of RRFLibraries do you have in your workspace?
                        • R006undefined
                          R006 @dc42
                          @dc42 RRFLibraries 3.4.4 version
                            @R006 I have PanelDueFirmware master and RRFLibraries master in my PanelDue build workspace, and it builds for me. It sounds to me that you may be using RRFLibraries 3.4-dev branch.
                            • R006undefined
                              R006 @dc42
                              @dc42 hi, sorry for late reply.
                              i am build panel FM as per you mentioned but when i am flashing it's paneldue screen was blank.
                              and getting this error:Generating binary
                              "/arm-none-eabi-objcopy" -O binary "C:\Users\rishita.butala\eclipse-workspace\Firmware\PanelDueFirmware\Release-7.0/PanelDueFirmware-v2-7.0.elf" "C:\Users\rishita.butala\eclipse-workspace\Firmware\PanelDueFirmware\Release-7.0/PanelDueFirmware-v2-7.0.bin" && cat "C:/Users/rishita.butala/eclipse-workspace/Firmware/PanelDueFirmware/Release-7.0/PanelDueFirmware-v2-7.0.bin" "C:/Users/rishita.butala/eclipse-workspace/Firmware/PanelDueFirmware/SplashScreens/SplashScreen-Duet3D-800x480.bin" >"C:/Users/rishita.butala/eclipse-workspace/Firmware/PanelDueFirmware/Release-7.0/PanelDueFirmware-v2-7.0-logo.bin"
                              c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/sh: /arm-none-eabi-objcopy: not found
                              makefile:101: recipe for target 'post-build' failed
                              make[1]: [post-build] Error 127 (ignored)
                              but i am go through this topic:https://forum.duet3d.com/topic/22876/solved-paneldue-firmware-compile-error/10
                              and try to generating .bin file so .bin file was generated. but it's blank.
                              i am waiting for your reply @dc42
                              • R006undefined
                                R006 @R006
                                @dc42 i am waiting for your reply
                                  @R006 looks like you haven't defined variable ArmGccPath in Window->Preferences->C/C++->Build->Build Variables. It need to be defined as the path to the folder where the C++ compiler and related tools (including arm-none-eabi-objcopy) live. This is what mine is set to, although a more recent version of the compiler than that should also work.
                                  • R006undefined
                                    R006 @dc42
                                    @dc42 it's already defined.
                                      If you look at the Command box in the above image, you can see that it tries to invoke "${ArmGccPath}/arm-none-eabi-objcopy". As it's trying to invoke"/arm-none-eabi-objcopy" according to the error message you posted, there must be something wrong with your definition of that build variable, or else the post build step command line in your system doesn't match mine.
                                      • R006undefined
                                        R006 @dc42
                                        Post-build steps in my eclipse.
                                        "${ArmGccPath}/arm-none-eabi-objcopy" -O binary "${workspace_loc:/${ProjName}/${ConfigName}}/${BuildArtifactFileBaseName}.elf" "${workspace_loc:/${ProjName}/${ConfigName}}/${BuildArtifactFileBaseName}.bin" && cat "${ProjDirPath}/${ConfigName}/${BuildArtifactFileBaseName}.bin" "${ProjDirPath}/SplashScreens/SplashScreen-Duet3D-800x480.bin" >"${ProjDirPath}/${ConfigName}/${BuildArtifactFileBaseName}-logo.bin"
                                          @R006 and how have you set ArmGccPath ?
                                          R006undefined 1 Reply Last reply Reply Quote 1
                                          • R006undefined
                                            R006 @dc42
                                            @dc42 ArmGccPath is C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\bin
