    Compiling/Building PanelDue Firmware
    PanelDue
    1.4k
      dc42 administrators @R006
      @R006 and is file arm-none-eabi-objcopy.exe in that folder?
      R006undefined 1 Reply Last reply Reply Quote 0
      • R006undefined
        R006 @dc42
        @dc42 yes
        but as per error c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/sh: /arm-none-eabi-objcopy: not found may be it's search in sh folder
        R006undefined oliofundefined 2 Replies Last reply Reply Quote 0
        • R006undefined
          R006 @R006
          This post is deleted!
          • oliofundefined
            oliof @R006
            @R006 remove /sh from the path
            • R006undefined
              R006 @oliof
              @dc42 thank you for support .
              now i am able to build it. and generating PanelDueFirmware.bin file successfully by changing the name of ArmGccPath.
              but after flashing successfully & restart panel, it was blank.
              Any Suggestions?@chrishamm
              • R006undefined
                R006 @R006
                @dc42 @chrishamm can any one try my build bin file of panelduefirmware & Check what's wrong in that file & check in your panel if it's working or not.
                Firmware varsion:3.4.beta3
                souce code of panel:https://github.com/Duet3D/PanelDueFirmware
                bin file:68a650ee-e619-4847-8f02-267908ce9181-PanelDueFirmware-v2-7.0.bin
                dc42undefined 2 Replies Last reply Reply Quote 0
                  @R006 where is your binary file, and which build configuration is it?
                  R006undefined 1 Reply Last reply Reply Quote 1
                  • R006undefined
                    R006 @dc42
                      @R006 I am away for a few days, but in any case I'm not sure I have a version 2 PanelDue board left. Perhaps @mfs12 can test your binary.
                      • R006undefined
                        R006 @dc42
                        @dc42 thank you for your support now it's working fine.
