    Failed to write to file, error code 1. Card may be full.
    • CCS86undefined
      CCS86
      Just got this error out of the blue. I obviously figured I had filled the SD card, so I deleted a number of files and tried again. Same error.
      I power cycled the printer and the error persists.
      Plenty of free space:
      M122:
      	m122
      RepRapFirmware for Duet 2 Maestro version 3.5beta2 (2023-02-08 17:43:40) running on Duet Maestro 1.0
      Board ID: 08DJM-956DU-LLMS4-7J9F6-3SN6Q-KBM2Q
      Used output buffers: 1 of 26 (21 max)
      Static ram: 22148
      Dynamic ram: 70336 of which 0 recycled
      Never used RAM 20044, free system stack 216 words
      Tasks: NETWORK(ready,26.9%,253) ACCEL(notifyWait,0.0%,349) HEAT(notifyWait,0.1%,352) Move(notifyWait,0.0%,402) TMC(notifyWait,1.3%,116) MAIN(running,70.7%,532) IDLE(ready,1.0%,31), total 100.0%
      Owned mutexes:
      Last reset 00:03:25 ago, cause: power up
      Last software reset at 2023-01-28 08:45, reason: User, Gcodes spinning, available RAM 18740, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      Step timer max interval 1865
      MCU temperature: min 34.9, current 37.5, max 38.0
      Supply voltage: min 24.0, current 24.1, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/32/0, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, read errors 0, write errors 0, ifcnt 7, reads 34192, writes 7, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: standstill, read errors 0, write errors 0, ifcnt 7, reads 34192, writes 7, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: standstill, read errors 0, write errors 0, ifcnt 7, reads 34191, writes 7, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: standstill, read errors 0, write errors 0, ifcnt 7, reads 34191, writes 7, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: standstill, read errors 0, write errors 0, ifcnt 6, reads 34192, writes 6, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: not present
      Driver 6: not present
      Date/time: 2023-04-10 21:46:34
      Slowest loop: 880.86ms; fastest: 0.19ms
      === Storage ===
      Free file entries: 10
      SD card 0 detected, interface speed: 10.0MBytes/sec
      SD card longest read time 105.0ms, write time 2.0ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      no step interrupt scheduled
      === DDARing 0 ===
      Bed heaters 0 -1, chamber heaters -1 -1, ordering errs 0
      Heater 0 is on, I-accum = 0.3
      Heater 1 is on, I-accum = 0.0
      Movement locks held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Q0 segments left 0
      Code queue 0 is empty
      === Filament sensors ===
      Extruder 0 sensor: ok
      === Network ===
      Slowest loop: 880.71ms; fastest: 0.02ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      Interface state active, link 100Mbps full duplex
        I would suspect that the card may be failing and would backup and replace.
        CCS86undefined 1 Reply Last reply Reply Quote 0
        • CCS86undefined
          CCS86 @Phaedrux
          @Phaedrux said in Failed to write to file, error code 1. Card may be full.:
          Do you guys have any recommended cards?
          • oliofundefined
            oliof @CCS86
            @CCS86 sandisk extreme and/or industrial MLC disks.
            • CCS86undefined
              CCS86
              Thanks guys.
              I think this is probably the case, because shortly after I was able to upload the same file with no issue. In the process of backing up, I found an unexpected EOF error on a macro, so it seems like the SD was flaky.
              Using (the awesome) RFM I was able to pull almost every file off the card (even though windows wouldn't properly mount it), and push them all to a new card. Boom, up and running without missing a beat.
              Oddly, despite the DWC working on my local computer, when I try to load it from an external network, I get some errors in the console:
              It seems odd, since I don't know why it would be using different files. But, I'll reinstall DWC and see if that fixes it.
              • Fixed after reinstall
              • T3P3Tonyundefined T3P3Tony marked this topic as a question
              • T3P3Tonyundefined T3P3Tony has marked this topic as solved
