    Duet2 Eth Klipper Firmware issues
    Firmware installation
    1.8k
    • dtmcnamaraundefined
      dtmcnamara @droftarts
      @droftarts totally understand. I figured with the little klipper content on here this was probably going to be the case. The flash speed seems right, as far as all the other content I have seen about flashing klipper on the Duet. Most tutorials show between 47-50 pages, and it taking no more than 2 seconds.
      Everything else I just followed the instructions from others online so there is no reason for doing it any way.
      I did revert back to ensure the board was functional, and everything still works when back on the original firmware.
      If I find a solution I will update this post, just in case someone else stumbles across it. Thanks
      dc42undefined droftartsundefined matthew 81undefined 3 Replies Last reply Reply Quote 1
        dc42 administrators @dtmcnamara
        @dtmcnamara it might be worth asking @Luke-sLaboratory if he has any ideas about this one.
        • oliofundefined
          oliof @droftarts
          @droftarts said in Duet2 Eth Klipper Firmware issues:
          I'm also not sure about using /dev/serial/by-id/ as the port.
          Thats normal under klipper because /dev/ttyACM* is not reliable to be stable across boots (USB enumeration can change with kernel and/or klipper formware updates), and you may have multiple boards (displays, toolboards, multiple control boards for larger numbers of drivers or additional IO). Configuring by id gives you a stable identifier.
            droftarts administrators @dtmcnamara
            @dtmcnamara Ah, yes, the binary is much smaller, so would flash faster. That makes sense. I still think using both the port name and the U parameter might cause conflicts. Did you try without the U parameter?
            @oliof Thanks for the info! Another Linux-command-line thing I didn't know about. Unfortunately it doesn't seem to have made it into macOS, where devices can't be connected to by id.
            • apakundefined
              apak @dtmcnamara
              @dtmcnamara need to use raspbian BUSTER (version 10)
              Raspbian bullseye (version 11) has a bug whan flashing klipper onto duet boards, and does a semibrick of the board.
              Lately it´s been said that flashing the LITE version of raspbian, and right after that using KIAUH you could flash it with both versions (buster and bullseye).
              I have a SD with buster that flashed successfully duet3 mini5 and duet2 wifi
              • oliofundefined
                oliof @apak
                @apak what does semibrick mean, and do you know how to recover?
                apakundefined 1 Reply Last reply Reply Quote 0
                • apakundefined
                  apak @oliof
                  @oliof when you flash klipper fw it doesn´t finish quite well, and board does not respond.
                  Just reflash RRF again and it works fine.
                  That´s a semibrick...board not working but you are able to recover it by regular procedure.
                  oliofundefined 1 Reply Last reply Reply Quote 1
                  • oliofundefined
                    oliof @apak
                    @apak is that captured in a bug on the klipper side? I worry that the conspiracy theorists talk about Duet3D "locking" the board.
                    apakundefined Luke'sLaboratoryundefined 2 Replies Last reply Reply Quote 0
                    • apakundefined
                      apak @oliof
                      @oliof nothing to do with klipper or duet, it´s a debian or bossa bug....
                      • Luke'sLaboratoryundefined
                        Luke'sLaboratory @oliof
                        @oliof its 100% a debian or bossa bug. Duet has been nothing but awesome in their quest for true open source.
                        Have you got it working? I've definitely run across that annoying bug 😞
                        Luke
                        http://lukeslab.online
                        • oliofundefined
                          oliof @Luke'sLaboratory
                          @Luke-sLaboratory I havent tried, I just like to be on the up and up (-:
                          • matthew 81undefined
                            matthew 81 @dtmcnamara
                            @dtmcnamara it took me several minutes to flash 100 pages or so on duet 2 upgrading the firmware,perhaps that is different
