Duet3 Mini 5+ CAN Setup - Drivers Erros
Hello Community, hi @dc42,
we have a setup with two duet 3 mini 5+ connected via CAN. The Z-axis and the extruder 0 are connected to board 1. After a print height of approx. 5mm, the extruder and the Z-axis no longer move and are without power. This is repeatable and has now occurred at least 5 times in a row.
M122 and M122 B1 deliver the following output and write errors on board 1:M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.4.5 (2022-11-30 19:41:16) running on Duet 3 Mini5plus WiFi (SBC mode) Board ID: 519ZB-DP6KL-K65J0-409NA-LUW1Z-HBBTZ Used output buffers: 1 of 40 (32 max) === RTOS === Static ram: 103652 Dynamic ram: 101084 of which 0 recycled Never used RAM 33304, free system stack 118 words Tasks: SBC(ready,2.0%,472) HEAT(notifyWait,0.0%,340) Move(notifyWait,2.0%,261) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.1%,326) CanClock(delaying,0.0%,341) TMC(notifyWait,0.7%,72) MAIN(running,94.3%,557) IDLE(ready,0.1%,30) AIN(delaying,0.8%,263), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:38:52 ago, cause: software Last software reset at 2023-05-25 13:39, reason: User, GCodes spinning, available RAM 33304, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 MCU revision 3, ADC conversions started 2332209, completed 2332209, timed out 0, errs 0 Step timer max interval 1491 MCU temperature: min 40.1, current 52.1, max 53.8 Supply voltage: min 23.3, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/14, heap memory allocated/used/recyclable 2048/704/518, gc cycles 0 Events: 1 queued, 1 completed Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 58, reads 57121, writes 15, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 56, reads 57122, writes 14, timeouts 0, DMA errors 0, CC errors 0 Driver 2: ok, SG min 0, read errors 0, write errors 1, ifcnt 58, reads 57120, writes 15, timeouts 0, DMA errors 0, CC errors 0 Driver 3: ok, SG min 0, read errors 0, write errors 1, ifcnt 58, reads 57120, writes 15, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 39, reads 57127, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-05-25 16:17:33 Cache data hit count 3750291069 Slowest loop: 322.10ms; fastest: 0.07ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 0.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 34, maxWait 244257ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 67394, completed 67354, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.1 Heater 1 is on, I-accum = 0.5 === GCodes === Segments left: 1 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet* is doing "G1 X172.184006 Y131.311996 E0.004710" in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause* is idle in state(s) 0 Code queue is empty === CAN === Messages queued 86930, received 24010, lost 0, boc 0 Longest wait 1ms for reply type 6018, peak Tx sync delay 39349, free buffers 18 (min 4), ts 11661/11657/0 Tx timeouts 12,0,3,0,0,2 last cancelled message type 4514 dest 127 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 27356/27356 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x0f190 Buffer RX/TX: 2904/120-4056, open files: 0 === Duet Control Server === Duet Control Server v3.4.5 Telnet: Buffered code: G1 X172.184 Y131.312 E0.00471 Buffered code: G1 X171.829 Y132.154 E0.02771 Buffered code: G1 X171.375 Y133.084 E0.03137 Buffered code: G1 X171.135 Y133.515 E0.01494 Buffered code: G1 X171.228 Y134.203 E0.02104 Buffered code: G1 X171.258 Y134.365 E0.00501 Buffered code: G1 X171.414 Y135.046 E0.02117 Buffered code: G1 X171.435 Y135.123 E0.00243 Buffered code: G1 X171.605 Y135.673 E0.01745 Buffered code: G1 X171.468 Y135.882 E0.00759 Buffered code: G1 X170.826 Y136.716 E0.03187 Buffered code: G1 X170.488 Y137.159 E0.0169 Buffered code: G1 X170.277 Y137.387 E0.00944 Buffered code: G1 X170.163 Y137.517 E0.00523 Buffered code: G1 X170.066 Y137.611 E0.0041 Buffered code: G1 X169.771 Y137.862 E0.01173 Buffered code: G1 X169.673 Y137.943 E0.00386 Buffered code: G1 X169.259 Y138.25 E0.01562 Buffered code: G1 X169.201 Y138.291 E0.00215 Buffered code: G1 X168.839 Y138.53 E0.01314 Buffered code: G1 X168.725 Y138.6 E0.00407 Buffered code: G1 X168.065 Y138.985 E0.02315 Buffered code: G1 X167.865 Y139.09 E0.00684 Buffered code: G1 X167.16 Y139.444 E0.02392 Buffered code: G1 X166.676 Y139.66 E0.01608 Buffered code: G1 X166.114 Y139.903 E0.01854 Buffered code: G1 X164.964 Y140.336 E0.03726 Buffered code: G1 X164.899 Y140.363 E0.00213 ==> 1344 bytes Code buffer space: 2784 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 39.88, max time between full transfers: 93.5ms, max pin wait times: 60.7ms/8.8ms Codes per second: 30.57 Maximum length of RX/TX data transfers: 8120/1128
M122 B1 Diagnostics for board 1: RepRapFirmware for Duet 3 Mini 5+ version 3.4.5 (2022-11-30 19:41:16) running on Duet 3 Mini5plus WiFi Last reset 00:17:22 ago, cause: software Driver 0: position 0, 80.0 steps/mm,, SG min 0, read errors 0, write errors 1, ifcnt 92, reads 54872, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 1: position 0, 80.0 steps/mm,, SG min 14, read errors 0, write errors 1, ifcnt 115, reads 54870, writes 11, timeouts 0, DMA errors 0, CC errors 0 Driver 2: position 0, 4000.0 steps/mm,, SG min 0, read errors 0, write errors 1, ifcnt 92, reads 54871, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 3: position 0, 80.0 steps/mm,, SG min 2, read errors 0, write errors 1, ifcnt 106, reads 54871, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 4: position 0, 80.0 steps/mm,, SG min 0, read errors 0, write errors 1, ifcnt 102, reads 54872, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 5: position 0, 80.0 steps/mm,, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 20, DMA errors 0, CC errors 0, failedOp 0x80 Driver 6: position 0, 80.0 steps/mm,, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 20, DMA errors 0, CC errors 0, failedOp 0x80 VIN: 23.9V, MCU temperature: min 41.4C, current 41.7C, max 47.0C Peak sync jitter -400/401, peak Rx sync delay 200, resyncs 0/0, next step interrupt due in 186764851 ticks, enabled
The same setup on another machine is running well!
Thank you in advance
@CR3D post your config too from both boards
and if possible a sample gcode file that causes this issue.
atm we tested the new BETA 3 Firmware and it runs...
I hope there will we a stable version soon
@CR3D b3 will have extrusion issues on certain move/retract combinations, supoosedly fixed in the upcoming b4 release.
@CR3D did you take the M122 reports one right after the other? The M122 report for the master board says it was reset 38 minutes ago, but the board 1 report says it reset 17 minutes ago. So perhaps board 1 had an unexpected reset. Unfortunately the M122 report for board 1 doesn't give the reset reason. However, next time it happens, if the M122 B1 report shows that board 1 has reset, you could connect to board 1 via USB so that you can send M122 directly to it and get the complete report.
OOH if the 3.5beta3 firmware is working well for you, then you can continue using it. We hope to release 3.5beta4 next week.
