    Scanning Z probe support in RRF 3.5
    Beta Firmware
    23
    128
    10.3k
      dc42 administrators @lparnell34
      @lparnell34 initially yes, however that gave a large Y offset between the coil and the Z probe switch; so I extended the cover towards the switch.
        dc42 administrators @dc42
        Here's a blog entry with more details about this scanning probe: https://www.duet3d.com/blog/scanning-z-probe-for-reprapfirmware-and-Duet.
        samlogan87undefined 1 Reply Last reply Reply Quote 4
        • JoergS5undefined
          JoergS5
          This post is deleted!
          • samlogan87undefined
            samlogan87 @dc42
            @dc42 do you guys think you will release a new version of the tool board where you put the i2c bus to a plug? Had another look tonight and there is no way I would be able to solder that 🤣
            Custom Core-XY
              dc42 administrators @samlogan87
              @JoergS5 I'm not sure why you deleted your post, however I had the same idea yesterday!
              JoergS5undefined 1 Reply Last reply Reply Quote 0
              • JoergS5undefined
                JoergS5 @dc42
                @dc42 I deleted it because I doubt whether the BL Touch is necessary in the future *). But to repeat my idea:
                is it possible to bore a hole into the middle of the Grove coil and assemble it together with the BL Touch so the pin of the BL Touch goes through the coil hole. Then both have the same XY offset.
                *) I thought about using a gauge block at a bed edge as Z0 reference.
                Gauge blocks of class 0 have a precision of 0.1 micrometers. This could even be used with the LDC1612 measuring the angle of a rotated bed => 5 axis AC calibration, by measuring multiple points on the gauge block.
                The next idea was, if I don't use the BLTouch, I could use the bored coil to assemble it around the nozzle, so it has true X0Y0 position. The PCB needs to have enough distance to the heated nozzle... => the aluminium heatblock will disturb measurement
                  dc42 administrators @JoergS5
                  @JoergS5 my feeling at the moment is that because of the sensitivity of inductive sensors to temperature, and to allow a wider choice of bed surfaces including interchangeable beds, it's better to use a conventional touch probe or nozzle contact probe to establish Z=0 and perhaps to do bed tramming too. Then the scanning probe can be calibrated immediately before scanning, and its temperature sensitivity won't matter.
                  As you can see from the pictures at https://coolcomponents.co.uk/products/grove-2-channel-inductive-sensor-ldc1612 there is a blank area in the centre of the coil, so drilling a hole there would be possible.
                  We're designing a solution based on the LDC1612 at present and although we will be using a smaller sense coil than the Grove one, it's likely that we will include a hole in the centre and design a printable adapter to attach it to a BLTouch.
                  CNCModellerundefined DeadNewbieundefined JoergS5undefined 3 Replies Last reply Reply Quote 0
                  • CNCModellerundefined
                    CNCModeller @dc42
                    @dc42 said in Scanning Z probe support in RRF 3.5:
                    @dc42 Wouldn't the inductive probe pick up the metal in the bltouch? I've assumed this was basically a small metal detector hence you'd need to keep any other metal outside of the coils sense area, or is that not the case?
                    Polar Duet3 Mini + 1HCL
                    https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                    Wanhao D4S: Duet2
                    https://forum.duet3d.com/post/296755
                    K40 Laser, Duet2
                    https://forum.duet3d.com/post/312082
                    Wanhao D5S
                    https://www.youtube.com/CNCModellerUK
                      dc42 administrators @CNCModeller
                      @CNCModeller a small amount of metal in a fixed location relative to the coil shouldn't matter. In any case, the larger metal parts of the BLTouch are at the top so about 26mm away for where the coil would be.
                        CNCModeller
                        @dc42 is it fair to say that this type of probe wouldn't be much use scanning a flexible magnetic build sheet like this ? Due to the varying magnetic field?
                        Wanhao D4S: Duet2
                        K40 Laser, Duet2
                        Wanhao D5S
                          @CNCModeller I am using the probe with a flexible magnetic sheet. I was expecting the magnets underneath it to show up in the height map, but they don't. However, the instructions for the Beacon probe say you need to avoid strong magnets.
                          CNCModellerundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                            CNCModeller @dc42
                            @dc42 In your experience, does the height map reference to the magnetic sheet surface or the underlying metal bed?
                            Wanhao D4S: Duet2
                            K40 Laser, Duet2
                            Wanhao D5S
                              @CNCModeller I can's say because I don't use one without the other. However, the fact that the probe doesn't see the magnets suggests to me that it is sensing the sheet.
                              For reference I am using this bed https://mandalaroseworks.com/products/magbed-for-e3d-toolchanger and this sheet https://whambam3d.com/collections/build-surfaces/products/flexi-plate-with-pre-installed-pex-build-surface?variant=39372386566242.
                              CNCModellerundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                                CNCModeller @dc42
                                @dc42 I'm using the type that looks like flexible rubber fridge magnets so we'll see how that compares. The flux is in long lines spaced at about 10mm pitch.
                                Wanhao D4S: Duet2
                                K40 Laser, Duet2
                                Wanhao D5S
                                • T3P3Tonyundefined
                                  T3P3Tony administrators @dc42
                                  That mandalaroseworks bed does have pretty darn strong magnets in it!
                                  @dc42 why not do a bed scan without the flex sheet installed just for comparison.
                                  www.duet3d.com
                                    dc42 administrators @T3P3Tony
                                    @T3P3Tony OK, here it is.
                                    T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                    • T3P3Tonyundefined
                                      @dc42 cool, you can clearly see the magnets!
                                      One other interesting test would be to put a thin shim in the middle under the flexi build plate (say a couple of M4 washers and see how accurately it picks up the deformation of the flex plate.
                                      www.duet3d.com
                                        Here's the scan with the bed plate, for comparison. It looks to me that the magnets are being picked up very slightly.
                                          @T3P3Tony as you wish:
                                          One 0.8mm M4 washer in each of two locations.
                                          T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
                                          • T3P3Tonyundefined
                                            @dc42 definitively confirms its picking up the flex plate and not the underlying bed/magnets
                                            www.duet3d.com
                                            CNCModellerundefined 1 Reply Last reply Reply Quote 0
