Teaser for today - can you guess the answer?
@deckingman Would it give it away if we saw the 'wrong' homeall.g?
I've had all my printers set to centre origin for years, just seems more 'right'. I think it was after using deltas, and then Ultimakers for a while, which were always set up like that.
Here's a wiki page that covers it, too: https://docs.duet3d.com/User_manual/Tuning/Bed_originIan
@JoergS5 said in Teaser for today - can you guess the answer?:
A command which resets homing like M584, M18, M501, tool changes?
Nope
OK, I'll make it easy for you. Below is the offending homeall.g file with the error present.
I'd like to keep this "teaser" going for a little while longer so when you spot my mistake, reply with something like "found it in "n" seconds/minutes/hours".
Herewith the file...........
; homeall.g T0 P0; select a tool - any one will do - don't run tool change macros ; check if tool is hot, if not start to heat it to 140 deg C if sensors.analog[1].lastReading < 140 M568 P0 S140 M291 P"Hot end set to 140 deg C" R"Homing Macro" S1 T10 ; Lift Z (lower bed) relative to current position G91; relative G1 Z5 F600 ; move bed down 5mm ;check if X or Y endstops are already triggered if sensors.endstops[0].triggered G1 X10 F3600 ; if sensor tiggererd, move away 10mm relative then...... M400; wait for move to finish then....... if sensors.endstops[0].triggered; .....check again abort "X endstop already triggered after moving away from end stop - aborting" ; abort if still triggered. if sensors.endstops[1].triggered G1 Y-10 F3600 ; if sensor tiggererd, move away 10mm then...... M400; wait for move to finish then....... if sensors.endstops[1].triggered; .....check again abort "Y endstop already triggered after moving away from end stop - aborting" ; abort if still triggered. ; reduce motor currents to 25% for X and Y M400 ; wait for any moves to finish (shouldn't be any) M913 X25 Y25 G1 Y420 X-420 H1 F4800 ; move until one or other end stops trigger G1 Y 420 H1 F4800; course home Y G1 Y-10 F600; Go back a few mm G1 Y50 F360 H1 ; fine home Y G1 X-420 H1 F4800; course home X (80mm/sec) G1 X10 F600 ; Go back a few mm G1 X-40 F360 H1 ; fine home X ; fast move to centre G90; set to absolute coordinates M400 ; wait for any moves to finish (shouldn't be any) M913 X0 Y0; restore motor currents for fast move G1 X0 Y0 F5400; move to the centre of the bed ;***Now home Z**** M400 ; wait for moves to finish G91; back to relative ; now do homing at high speed until slotted opto triggers M98 P"0:/macros/FastJogZ.g" ; run macro which moves 80mm at high speed and repeats until trigger ; check if end stop already triggered if sensors.endstops[2].triggered ; if it is triggered..... G1 Z10 F300;... then move down 10mm....... M400; wait for move to finish, then ...... if sensors.endstops[2].triggered ; ........check again if it is triggered..... abort "Z endstop already triggered after moving away from stop - aborting"; ........and abort if it still is ; reduce motor currents to 50% for Z M400 ; wait for any moves to finish (shouldn't be any) M913 Z50 ; check agin if tool is still at or above 140 deg C, if not heat it if sensors.analog[1].lastReading < 140 M568 P0 S140 M291 P"Hot end below 140, so set to 140 deg C" R"Z Homing Macro" S1 T10 ; now wait for temp to get to 140 or above while sensors.analog[1].lastReading < 140 M291 P"Waiting for hot end to heat" R"Z Homing Macro" S1 T4 G4 S4 ; FAST home Z G1 Z-120 F300 H1 ; should be within about 80mm so 120mm more than enough M400 ; wait for moves to finish G1 Z5 F300 ; lower bed again ; SLOW home Z G1 Z-10 F60 H1 ; set offset G91 ; relative G1 Z{global.z_offset} ;slightly lower G4 P100; .1 sec delay G92 Z0 ; set new zero ; lower bed again G90 ;absolute G1 Z5 F300 M400 ; wait for moves to finish then restore motor currents to 100% for Z M913 Z100; restore Z motor current M568 P0 S0; set hot end temp back to zero
@deckingman found it (assuming my DM was correct) as I scrolled down the homeall
@deckingman #MeToo
There were some gcodes I'm not familiar with and had to read up -
@deckingman #methree ah yes, saw it pretty quickly once you’d posted the homeall.g.
In case anyone is still scratching their head, if one restores the motor current to zero instead of 100% ( M913 X0 Y0 instead of M913 X100 Y100 ), then any following G1 move will result in no physical movement of the motors. But the firmware doesn't "know" this and so reports the motor positions as being their latest commanded position -in this case 0,0 which is the centre of the bed although the print head remained in the left rear corner.
In my defence, the reason it took my about 10 minutes to find my error was that I changed the printer origin at the same time as I started to change my homing files from a CoreXYUV machine to a simple CoreXY. So "origin" was at the forefront of my limited mental capacity. That's my feeble excuse and I'm sticking to it.
@deckingman would that then constitute as a bug
@SJI said in Teaser for today - can you guess the answer?:
Only in the sense that the firmware isn't idiot proof - but then what is? I suppose one could make the case that the firmware shouldn't allow users to set zero motor current - maybe default to a pre-determined minimum. But who decides what that minimum should be and is there a minimum that would suit every machine? - probably not. There are other commands that would give zero motor current (e.g. M906) and yet more that would likely result in no motor movement when a G1 is sent, such as zero maximum speed (M203), zero acceleration (M201) etc. And one could also make a similar case for things like fans where setting the maximum speed to zero (M106 Pn X0) would result in the fan not turning when commanded to do so. So I'd say that once you start looking at making things idiot proof whilst allowing users to make changes to their configurations, you end up going down an infinitely deep and infinitely complex rabbit hole.
@deckingman IMHO M913 X0 should flag the axis as not homed, just like M84 X (disable motors) does.
But the examples you gave wouldn't risk loosing position. They only disable motion, like M92 X0. -
@o_lampe said in Teaser for today - can you guess the answer?:
@deckingman IMHO M913 X0 should flag the axis as not homed, just like M84 X (disable motors) does...............................
What about M913 X1? It's unlikely that 1% motor current would be sufficient to drive a motor (depending on a number of factors) so should that also flag any axes as not homed? If so then what about 2% current, or 3 or 4? You'd also need to apply the same criteria to M906 and probably M917. I think you can see where I'm going with this but I have more important things to think about right now.
@SJI no, its open loop control after all.
This post is deleted!
