    OM based "virtual triggers"
    Firmware wishlist
    476
    • oliofundefined
      oliof
      This is an idea to run gcode based on certain OM values, as an alternative to looping in daemon.g
      Basically, use the triggers functionality, but instead of tying the trigger to a pin, tie it to an object model entry and a condition (i.e. value matches X or exceeds Y).
      I guess there is a good reason we have daemon.g instead of that, but I wanted to note this idea here anyways.
      moth4017undefined deckingmanundefined jay_s_ukundefined 3 Replies Last reply Reply Quote 5
      • moth4017undefined
        moth4017 @oliof
        @oliof I like that idea would be good so i can integrate my drybox and spool weight , im using the object Model more and more these days , thanks to minty trebor 🙂
        • deckingmanundefined
          deckingman @oliof
          @oliof I like that idea. I haven't used daemon.g but if I understand correctly, it runs ever "n" seconds so there would be a delay between something happening and the response to that event. Whereas a trigger would not suffer that loop delay. It also has "built in conditions" for any time or only while a print is running which is one less thing to check.
          o_lampeundefined 1 Reply Last reply Reply Quote 1
          • o_lampeundefined
            o_lampe @deckingman
            @deckingman ...what you said
            • and it doesn't read the SD-card everytime it runs.
            • o_lampeundefined
              o_lampe
              ...just wondering how many virtual triggers (and perhaps followed by macros) the main loop can handle without extrusion defects/stuttering motion.
              There's also a priority issue, I guess.
                jay_s_uk @oliof
                @oliof i also definitely like the idea of OM based triggers.
                ideally something along the lines of triggering a file on value change or variation from a set point.
                MintyTreborundefined 1 Reply Last reply Reply Quote 0
                • MintyTreborundefined
                  MintyTrebor @jay_s_uk
                  @oliof (& more) I Agree - I like the idea - I have a hunch it could get quite computationally expensive though, especially if you factor in conditionality like delta's or if a value is only considered "changed" if it over a threshold for a set amount of time (to account for noise etc)... Lot's of variables to keep track of, and the OM is quite large to be parsing/extracting values every cycle. I expect it would have be limited to a fixed number of available triggers to keep it lightweight.
                  NodeDSF - Native Node-Red integration with Duet boards.
                  BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
                  ReleaseMgr - Duet update info inside DWC.
                  Repo
                  • o_lampeundefined
                    o_lampe @MintyTrebor
                    @MintyTrebor I'm not sure if it's based on OM values, but the undervoltage emergency shutdown is already implemented
                    To me it's obvious, that it should only be used with similar high priority problems.
                    • oliofundefined
                      oliof @o_lampe
                      @o_lampe undervoltage is based on an analogue sensor triggering an interrupt (conceptually speaking, please don't crucify me for technical imprecision). So that's computationally cheap.
                      @MintyTrebor I agree that its going to come at a cost (mostly RAM, and of course the actual checking). I don't think you need to check the whole OM when having triggers. And limiting the amount of available triggers to a small number (I think 3 would be sufficient for many setups when used with caution and 5 may hit that 90% spot where the outliers would have the skills to build their own firmware, but of course there will be people who want to do everything with the new thing (-: ).
                      chrishammundefined 1 Reply Last reply Reply Quote 1
                      • chrishammundefined
                        chrishamm administrators @oliof
                        @oliof It's pretty straight-forward to write an SBC plugin for this purpose, although I understand some folks will stark shouting "and what about the standalone users?" once I finish this sentence. For the latter daemon.g + global vars may be a reasonable fallback.
                        Duet software engineer
                        • oliofundefined
                          oliof @chrishamm
                          The point is to avoid daemon.g and globals due to the side effects (SD card wear and delayed reaction to changes).
                          An SBC plugin would be an interesting first approach. It might even be one where I would consider SBC mode useful ...
