    How to install the Duet Accelerometer on Voron 2.4 with Revo?
    590
    • zaptaundefined
      zapta
      I placed an order for a Duet Accelerometer but then realized that it may not fit my Voron 2.4 / Revo. The pictures below show the recommended way to install on Revo and the bottom of my hotend, with the nozzle removed.
      1. Is the accelerometer supposed to fit there, above the heater? Do I need to remove the front panel with the two fans or anything else?
      2. If not, can it be fitted below the heater where I have more clearance on the sides?
      BTW, It seems to be a well designed product at a good price, especially with almost zero hassle installation on a Revo hotend, if it will just work.
        jay_s_uk @zapta
        @zapta I created a little spacer that can slide between the top of the heater core and the underside of the heatsink, allowing the accelerometer to be installed between the nozzle and the heater core. Seems to work fine
        Revo Accelerometer Spacer.STL
        zaptaundefined 1 Reply Last reply Reply Quote 1
        • zaptaundefined
          zapta @jay_s_uk
          Thanks @jay_s_uk. This is very useful.
          1. What is the purpose of the spacer, preventing the spring from compressing?
          2. Did you use any washers above or below the board?
          3. How did you orient the board?
            jay_s_uk @zapta
            @zapta
            1. Yep, to make it solid.
            2. No washers
            3. I did it on a dragon burner hotend and mounted the board with the connector at the front and the connector facing down
            zaptaundefined 3 Replies Last reply Reply Quote 0
            • zaptaundefined
              zapta @jay_s_uk
              Thanks @jay_s_uk, I will give it a try once the accelerometer arrives.
              • zaptaundefined
                zapta @zapta
                For the record, this is the spacer that @jay_s_uk posted.
                • zaptaundefined
                  zapta @jay_s_uk
                  This post is deleted!
                  • zaptaundefined zapta marked this topic as a question
                  • zaptaundefined zapta has marked this topic as solved
                  • zaptaundefined
                    zapta @jay_s_uk
                    @dc42, Is it possible to run the x/ input shaping plugin in X/Y directions while homing only in X/Y ?
                    It will make it easier to install the accelerometer on my 'stock' V2.4 without having the Revo nozzle heating the bed before the Clicky sensor.
                    zaptaundefined 1 Reply Last reply Reply Quote 0
                    • zaptaundefined zapta has marked this topic as unsolved
                    • zaptaundefined
                      zapta @zapta
                      Since I have hard time to fit the accelerometer while still homing in Z, I removed the connector to have stuffiest clearance. That connector is bulky and increase significantly the free volume necessary to fit the accelerometer.
                      T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
                      • T3P3Tonyundefined
                        T3P3Tony administrators @zapta
                        @zapta thanks for the feedback. We used that connector to match the other end on the board. Can you show it mounted on you printer?
                        www.duet3d.com
                        • zaptaundefined
                          zapta @T3P3Tony
                          Hi @T3P3Tony,
                          Thoughts in random order...
                          1. I presume that the intention behind the Duet3d accelerator is to measure directly the vibrations at the nozzle so I made sure that the board doesn't touch the plastic housing. Is it so?
                          2. I used a plastic spacer between the heater and the board as you can see in the picture.
                          3. The input shaping plugin forces Z homing even though it's not really needed for X/Y movements. Without it, I could install the stock accelerometer board, with the large connector facing down, below the line of the Clicky sensor.
                          4. There are a few input shaping boards for Kliper and Voron 2.4 and they are installed at the front of the printing head with longer screws. If this attachment method provides good enough results, it may be easier than the nozzle method since it doesn't interferer with the Z homing and is just as easy to install. E.g.
                          https://www.amazon.com/Upgraded-Printer-Accelerometer-Portable-Printer/dp/B0BLNX1SF1
                          https://www.aliexpress.us/item/3256804788296496.html
                          Tony, if you have further questions please let me know.
                          Installation with a plastic spacer between the Revo heater and the board.
                          The printing head without the accelerometer.
                            dc42 administrators @zapta
                            @zapta you could get round the Z homing issue by homing X and Y and then sending G92 Z0. But I take your point, the connector is too deep for the accelerometer to fit the right way up on some hot end assemblies.
