    search for gcodes
    Documentation
    588
    • nikschaundefined
      nikscha
      Hi all,
      small rant about the search in the new wiki:
      I really dislike how when I search for a gcode on the wiki search, there's often other articles displayed before it. Say I forgot the gcode (or parameters) for setting motor current, and I search for "set motor current", then the right entry only shows up on the 3rd spot: (meaning I can't just press enter to open it)
      I wish there was a dedicated search for gcodes only.
      Also: The search engine can't deal with typos at all, and every single one of the words in the query has to match. How is this better than just using ctrl+f?
      I really like the new wiki, but please overhaul the search
      Stay in school
      deckingmanundefined 1 Reply Last reply Reply Quote 2
      • deckingmanundefined
        deckingman @nikscha
        @nikscha I find this useful for quickly finding gcodes. https://docs.duet3d.com/User_manual/Reference/Gcodes_by_function. (Setting motor currents comes under "Motion").
        The problem with searching on a text string is the same as not knowing the gcode number you want. Personally, I think it does a pretty good job because in your example, someone might want to set the base motor current (M906), someone else might want to set the standstill motor current reduction (M917) and someone else might want to know the command for setting the motor current as a percentage of normal current (M913). Even if the search result was limited to G (or M) codes, there are still 3 different "answers" for users who not might not know the exact terminology so only enter "motor current".
        Essentially, specific answers can only be given to specific questions.
        nikschaundefined 1 Reply Last reply Reply Quote 1
        • nikschaundefined
          nikscha @deckingman
          @deckingman Thank you for the link, that's indeed helpful.
          But I disgree with you on this:
          @deckingman said in search for gcodes:
          I know exactly what gcode I'm looking for, I just don't remember the number (Personally I just have a hard time with that). So for me it would be easier if I could just type the name of the command instad.
          And it doesn't excuse the issue with typos. I (non-native speaker) sometimes misspell english words, and it would be nice if the search engine would be a bit more forgiving.
          Stay in school
          • oliofundefined
            oliof @nikscha
            @nikscha if you search for "gcode set motor current" you get M916 as the first result
            So I would say @deckingman s point about precise searches yielding precise answers still holds true.
            As per "fuzzy matches" to searches, you already see that I get a number of matches that are not directly matching my search term. More than that and we get into the realm of the system sometimes helping too much, which is equally frustrating.
            nikschaundefined 1 Reply Last reply Reply Quote 0
            • nikschaundefined
              nikscha @oliof
              @oliof
              yeah that's not working so well...
              And what if I spell "address" wrong? Not a single result, and the "did you mean..." are also wrong:
              (what's exapansion?)
              Stay in school
              nikschaundefined droftartsundefined 2 Replies Last reply Reply Quote 0
              • nikschaundefined
                nikscha @nikscha
                @nikscha
                Just now I wanted to update the firmware for a can expansion board, but searching for "gcode can board update" doesn't yield the right (or any) gcode. I need to open an article first (not the first one btw) and do a ctrl+f for update to find the right gcode...
                But maybe I wasn't precise enough?
                Lets try a more precise query, surely it will yield the precise result:
                Nope, doesn't work.
                If I remove the word "board" from the query, it does work....
                This is the gcode I was looking for by the way:
                Maybe I'm just so spoiled from google search reading my mind that this seems overly frustrating...
                Stay in school
                  droftarts administrators @nikscha
                  @nikscha said in search for gcodes:
                  what's exapansion?
                  As it turns out, a typo on four wiki pages! Thanks for pointing this out, I've fixed them.
                  As for the search facility, at the moment it is all that is offered. Another option, as you have pointed out, is ctrl-f on the Gcode dictionary page. I'll talk to @T3P3Tony and see if it can be extended, or if wiki.js has any fuzzy search options.
                  nikschaundefined 1 Reply Last reply Reply Quote 2
                  • nikschaundefined
                    nikscha @droftarts
                    @droftarts
                    Welcome ^^
                    I hope I am not too negative, I really appreciate the work of the Duet team!
                    Stay in school
                      I know it's a bit of a cop out, but google search may work better for you.
                      11bad3ee-78c7-41cd-95cd-a8c82ba9c1b7-Screen Shot 2023-09-11 at 10.13.58 AM.png Screen Shot 2023-09-11 at 10.13.58 AM.png
                      A Former User? 1 Reply Last reply Reply Quote 1
                        @nikscha typing “dictionary” first, then being a bit looser with your search terms can also help. Eg “dictionary firmware update” brings up M997 first.
                        • A Former User?
                          A Former User @Phaedrux
                          This post is deleted!
                            As shown in @Phaedrux 's screen shot, if you're using google, you can use a site-specific search, which will return results from solely the specified website. I use this a lot to search the forum.
                            For the forum, start your search with site:https://forum.duet3d.com/ with your search terms after.
                            For the wiki, start your search with site:https://docs.duet3d.com/ , again with your search terms after.
                            • droftartsundefined droftarts marked this topic as a question
                            • droftartsundefined droftarts has marked this topic as solved
