    Resume APF not working
    1.3k
      Ideally the latest stable, but what I'm saying about power resume from the secondary panel due SD card is that the feature isn't supported in any firmware at the moment.
      R006undefined 1 Reply Last reply Reply Quote 0
      • R006undefined
        R006 @Phaedrux
        @Phaedrux So when we get updated firmware its causing problems at customer end.
          Phaedrux Moderator @R006
          @R006 said in Resume APF not working:
          Can you be more specific?
          • R006undefined
            R006 @Phaedrux
            @Phaedrux
            In what context?
            Sometimes they use PanelDue SD card for printing
              I don't have a time frame on that, sorry. Thank you for bringing it to our attention though. Secondary SD card printing is fairly uncommon.
              • R006undefined
                R006 @Phaedrux
                @Phaedrux okay,
                Any suggestions on how I can update this from my end?
                  Update what?
                  • R006undefined
                    R006 @Phaedrux
                    @Phaedrux
                    If I want to fix this problem which firmware should be update panel or mainboard?
                      It likely doesn't work in any current firmware.
                      • R006undefined
                        R006 @Phaedrux
                        @Phaedrux
                        Ok.
                        Thank you for your support.
                        And waiting for update in firmware.
                          dc42 administrators @R006
                          @R006 I think the issue may be that the SD card in PanelDue was not mounted when you ran M916. Try viewing the contents of that SD card before you run M916. Alternatively, add command M21 P1 to your resurrect-prologue.g file.
                          • R006undefined
                            R006 @dc42
                            @dc42 thank you it's working.
                              @R006 thanks, I've logged https://github.com/Duet3D/RepRapFirmware/issues/912/
                              dc42 created this issue in Duet3D/RepRapFirmware
                              open Resume after power fail when print is from external SD card (standalone mode) #912
                              • dc42undefined dc42 marked this topic as a question
