    Laser filament monitor
    Filament Monitor
    73
    179
    41.7k
    • keyz182undefined
      keyz182 @dc42
      @dc42 said in Laser filament monitor:
      • Must have a functioning 3D printer and a supply of black PLA to print small parts with;
      • Must have enough experience of OpenSCAD to modify an existing design and preferably do new designs;
      • Preferably either be located in the UK or have experience of programming an attiny microcontroller e.g. with an AVRISP Mk2 or an Arduino running ArduinoISP + 6-pin programing connector.
      If there's still room on the list, I meet these criteria (aside from having black PLA, but that's just an Amazon prime order away).
      I also have an AVRISP MK2, and an ATMEL-ICE (I'd intended to have a go at developing on the RepRapFirmware, and doing on board debugging, at some point, but have been too busy with work).
      • Monster Deltaundefined
        Monster Delta
        Hi can you add me to the list please i believe i have the required skills and i have a large format delta capable of printing small parts and also very large parts some prints running for 3 weeks
        • auserundefined
          auser
          could you please add myself to the list of people interesed in a beta laser-filament-monitor?
          • designedby36undefined
            designedby36
            Can you add me to the list I have a print farm that i am converting over to duet's and filament monitoring is a must. Happy at the moment if it just detects a jam or filament out.
            • AS-3D Druckundefined
              AS-3D Druck
              I know it is realy hard to say but will this Sensor cost less than 50$ and will it be avaible at 2018?
              Best regards
              AS-3D Druck / Andre
              • T3P3Tonyundefined
                T3P3Tony administrators @AS-3D Druck
                @as-3d-druck yes and yes
                www.duet3d.com
                  AS-3D Druck
                  Nice thank you.
                  Best regards
                  AS-3D Druck / Andre
                  • Guyarosundefined
                    Guyaros
                    I am looking forward to purchasing Duet3D laser filament monitor when it will be out for sale.
                    Thanks,
                    • percarundefined
                      percar
                      when its for sale even beta version i would be interested in purchasing this monitor
                      • denkeundefined
                        denke
                        I would be interested too
                        • hedeonundefined
                          hedeon
                          Just woke up to another failed large print due to a jam. Please add me to your list. I am UK based, tinkerer, with some experience in programming Arduino and ESP microcontrollers.
                          • bazhipundefined
                            bazhip
                            Please throw me on there too @dc42
                              You've probably got more than enough, but I'd test it too.
                              • Qdeathstarundefined
                                Qdeathstar
                                looking forward to an eta
                                • timcurtis67undefined
                                  timcurtis67
                                  Any kind of ETA on these new filament monitors?
                                  • Biggsisundefined
                                    Biggsis
                                    I would be interested in testing one of those too, since I have several printers (CoreXY and Deltas, all with DUETs), use OpenSCAD myself and do Arduino Programming, I think I meet the conditions (Except living in Germany and not in the UK 🙂 )
                                    Hypercube Evolution User Group : https://www.facebook.com/groups/Hypercubeevolution/
                                    Kossel Delta XL / XXL User Group : [https://www.facebook.com/groups/KosselXXL/]
                                    • 3dmntbighkerundefined
                                      3dmntbighker
                                      No word in a month? Hoping to hear something soon dc42 🙂
                                      I'm putting in an end stop sensor based filament out sensor now in my CoreXY. Can anyone tell me if there is any point in a mechanical end stop board with a few support components and an LED, as opposed to just as simple switch? I find versions of both on Thingiverse. Does it matter with a Duet board?
                                      Scratch built CoreXY with Maestro
                                      Heavily modified Ender 3 with Maestro
                                      MPCNC work in progress with Duet WiFi
                                        Phaedrux Moderator @3dmntbighker
                                        @3dmntbighker The only thing that will matter between a simple switch and a switch with the LED is likely the high or low switching. For instance, I just installed a simple switch filament out sensor using a makerbot style endstop and it switches low. So you'll just need to set the relevant flag when you setup the command.
                                        3dmntbighkerundefined 1 Reply Last reply Reply Quote 0
                                          3dmntbighker @Phaedrux
                                          @phaedrux Thanks for the info. I wondered if a plain switch with no resisters anywhere could damage the Duet. Perhaps the inputs on the Duet are well protected and debounced?
                                            dc42 administrators @3dmntbighker
                                            @3dmntbighker said in Laser filament monitor:
                                            Yes, the endstop inputs are.
