Stealthburner Extruder for Troodon 2.0 used with Duet boards
Is it possible to use the Stealthburner Extruders with the Duet boards? I have a Railcore 2 system and wanted to see if I could use a Stealthburner Extruder.
@ObiWan2Print Yes, it's been done numerous times (why shouldn't it work by the way? ).
A 1LC toolboard won't fit any stock mounts or covers though, if you mean to go that route.
@Exerqtor other toolboards like the fly rrf36 have been made to fit with some creativity. A two part toolboard that's rrf compatible has not been made available as of yet (and it's not clear whether there will be).
@oliof said in Stealthburner Extruder for Troodon 2.0 used with Duet boards:
fly rrf36
Thanks for the replies and info. Just to clarify I am using the Duet 3 MB 6HC board and want to know if I can just plug the extruder/hotend control board output from the Stealthburner into the Duet 3 MB and control the extruder this way. If not is it possible to use the extruder with modifications?
@Exerqtor Thanks for the replies and info. Just to clarify I am using the Duet 3 MB 6HC board and want to know if I can just plug the extruder/hotend control board output from the Stealthburner into the Duet 3 MB and control the extruder this way. If not is it possible to use the extruder with modifications?
This post is deleted! -
@ObiWan2Print I don't know the stealthburner board. Is it just an endpoint for an umbilical, or a CAN/USB based toolboard with it's own stepper driver etc.? If the former you should be able to connect the wires if you know what goes where; if the latter then it's not possible to reuse it
the SB board is just a breakout board and does not use USB or CAN
