    screen and bltouch problem with the 3.4.6 release
    • anderundefined
      ander
      Hi there everyone!
      i have a duet2 board and i just uploaded the 3.4.6 firmware.
      After doing so, my screen doesn´t show any info, and i can´t access to the gcodes stored on it using the screen.
      The machine connects perfectly to the wifi and i can connect to the printer using the computer but definately the screen doesn´t work. i can´t even move any axys, and is not showing any temp info either.
      i also now have an issue with the bltouch after the upload of the firmware. if i send a job using the computer, the bltouch goes crazy deploying the probe, starts a non stop cicle, in and out while heating the extruder.
      i´m going to add my config.g
      thanks in advance.
      config(3).g
      • fcwiltundefined
        fcwilt @ander
        @ander
        If you copy-and-paste your code using the <> tags then everyone can see the code without having to download it.
        Also, what "screen" are you talking about?
        anderundefined 1 Reply Last reply Reply Quote 0
        • anderundefined
          ander @fcwilt
          Hi there @fcwilt
          the Screen is panel due7 touchscreen.
          And the code is:
          Configuration file for Duet WiFi (firmware version 3)
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Jan 31 2020 09:39:11 GMT+0100 (hora estándar de Europa central)
          M550 P"Muxar 2.1" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm
          M566 X1200.00 Y1200.00 Z420.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X30000.00 Y30000.00 Z480.00 E12000.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z500.00 E2000.00 ; set accelerations (mm/s^2)
          M906 X800 Y1000 Z900 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X0 Y10 Z0 S1 ; set axis minima
          M208 X320 Y340 Z360 S0 ; set axis maxima
          M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
          M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
          M574 Z2 S2 ; configure Z-probe endstop for high end on Z
          M558 P9 C"zprobe.in+zprobe.mod" H4 F200 T6000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X15 Y25 Z1 ; set Z probe trigger value, offset and trigger height(CUANTO MAS NEGATIVO ESTE VALOR,MAS SE SEPARA EL EXTRUSOR)
          M557 X20:310 Y35:340 S96 ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
          M307 H0 R0.900 K0.388:0.000 D2.59 E1.35 S1.00 B0; enable bang-bang mode for the bed heater and set PWM limit
          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 ; configure sensor 1 as thermistor on pin e0temp
          M307 H1 R2.664 K0.489:0.000 D3.64 E1.35 S1.00 B0 V23.9 ; disable bang-bang mode for heater and set PWM limit
          T0 ; select first tool
          droftartsundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
            droftarts administrators @ander
            @ander add this to config.g:
            M575 P1 S1 B57600
            See https://docs.duet3d.com/en/User_manual/Connecting_hardware/Display_PanelDue#firmware-configuration
            anderundefined 1 Reply Last reply Reply Quote 1
            • fcwiltundefined
              fcwilt @ander
              Hi @ander,
              Just for future reference this is what happens when you copy-and-past using the <> tags, which you can select from just above the text box.
              • anderundefined
                ander @droftarts
                Hi @droftarts
                It worked beautifly! thanks!
                The bltouch seems ok too....i don´t know if has to do something with the screen but hey, it´s working!
