    Config Settings for AWD voron 2.4 - coreXY
    709
    • michaelr123undefined
      michaelr123
      Planning an upgrade to my Voron 2.4 with a duet 2 board, quick question on the config for this setup.
      Here's a link to the mod: https://docs.atinyshellscript.com/v2.4/awd/#nema14-bearing-idler-stacks
      This requires 2x X drives and 2x Y drives. I haven't found any exact examples of how this would look in config, my guess it it would look something like this:
      M569 P10 S1 ; physical drive 10 goes forwards A1
      M569 P12 S1 ; physical drive 12 goes forwards A2
      M569 P11 S1 ; physical drive 11 goes forwards B1
      M569 P13 S1 ; physical drive 13 goes forwards B2
      M569 P0 S1 ; physical drive 0 goes forwards Z1
      M569 P1 S0 ; physical drive 1 goes backwards Z2
      M569 P2 S1 ; physical drive 2 goes forwards Z3
      M569 P3 S0 ; physical drive 3 goes backwards Z4
      M569 P4 S1 ; physical drive 4 goes forwards E0
      M584 X11:12 Y10:13 Z0:1:2:3 E4 ; set drive mapping AABB + 4 z motors + 1 extruder
      M350 X16 Y16 I1 ; turn interpolation off for AB axes
      I know I'll have to patch in 2 more stepper drivers, I already added 2 more for the AB motors in the first place, so no big deal there. Does this look correct?
      Thanks!
      -Michael
        yes theoretically that's how you would add additional motors to an axis, though I've not seen it used with corexy before.
        jay_s_ukundefined deckingmanundefined Mr Yodundefined 3 Replies Last reply Reply Quote 0
          jay_s_uk @Phaedrux
          @Phaedrux I can run my vzbot on RRF with 2x X and 2x Y and that's coreXY
          3Ddrifterundefined 1 Reply Last reply Reply Quote 1
          • Mr Yodundefined
            Mr Yod
            I haven't made an AWD system yet, but I have 3 Z and they are configured like you did (Z1.0:1.1:1.2 on a Duet3), so I'd say it's the same for XY.
            What I don't get is your "wiring":
            With this you are mapping A2B1 and A1B2, maybe it's correct and I just got confused with your comment.
            Besides: you have to synchronize the steppers in AWD configuration (it's hardware, not software), so remember to do that.
            michaelr123undefined 1 Reply Last reply Reply Quote 0
              michaelr123 @Mr Yod
              @Mr-Yod
              I'm just patching in stand alone stepper drivers to add extra drives to the duet 2 rather than using expansion boards as I couldn't get a hold of one stateside at this point. You just borrow spare pins for step, dir, enable and create additional drive channels. when I bought my voron kit I got a full klipper setup with standalone stepper chips so I'm just using those because I have them. Requires a bit of wiring but it's not too much work.
              Mr Yodundefined 1 Reply Last reply Reply Quote 0
              • Mr Yodundefined
                Mr Yod @michaelr123
                @michaelr123
                No, what I meant is:
                your As are 10 and 12, while your Bs are 11 and 13, so I assumed A and B are your X and Y, that was in conflict with your M584 where Xs are 11 and 12 while Ys are 10 and 13.
                But that's more a naming problem: maybe you named them based on the side of the printer, so X is A2B1 and Y is A1B2 in a cross configuration.
                As for synchronization: you need to unscrew the pulley's set screws, move a bit the belts and then screw them again (I think, IIRC).
                michaelr123undefined 1 Reply Last reply Reply Quote 1
                  michaelr123 @Mr Yod
                  @Mr-Yod
                  good catch, yeah I need align the naming convention. And yep will do on the hardware synchronization. Thanks for double checking, everything's ordered so I'll start working on this in a week or so.
                  • 3Ddrifterundefined
                    3Ddrifter @jay_s_uk
                    @jay_s_uk I’m building a vzbot with a duet 3 do you have a config file I can have with lc1 tool board?
                      jay_s_uk @3Ddrifter
                      @3Ddrifter I have it without a toolboard using a super8pro but it'll give you a starter for 10. I'll post it once I'm home
                      • deckingmanundefined
                        deckingman @Phaedrux
                        @Phaedrux said in Config Settings for AWD voron 2.4 - coreXY:
                        Yes you have. My CoreXYUVAB only split the axes for homing. After homing, the drives were re-mapped such that there were 3 Alpha motors and 3 Beta motors making it a "simple" CoreXY.
                        Phaedruxundefined 1 Reply Last reply Reply Quote 1
                          Phaedrux Moderator @deckingman
                          @deckingman said in Config Settings for AWD voron 2.4 - coreXY:
                          HA! so I have.
                          • Mr Yodundefined
                            Mr Yod @Phaedrux
                            HA! so I have.
                            Look at HevORT, too. 😃
