Bloob on print
@claustro not sure if applicable but a YouTuber was having the exact same problem with a different printing software and found that it was the resume after power loss feature causing the issue. Maybe give this a look? Video here about their problem
@sneakyferret that's not applicable to RepRapFirmware. Marlin needs to write the recovery info continuously because many boards don't have voltage monitoring. Duet boards have voltage monitoring and recovery info will only be written on a voltage drop.
@claustro looks like this happens on layer changes. We would need to know more about the machine (photos would be good), and see your config.g as well as a sample gcode file (or atl east like the first 100 lines).
@claustro
Do you use retract ? Please posr the settings. Is it a direct drive or bowden?
