    Connection issue with 3.5-rc2
    sbc mode can bus connection
    589
    • e4dundefined
      e4d
      I have a connection issue with Duet 3 and SBC. My setup is : Duet 3 6HC (SBC mode with Raspberry Pi 4) and 3 3HC connected. All boards and software are in RRF 3.5-rc2.
      The image on Raspberry Pi is a Raspbian image made following the instructions in the docs.
      This configuration works on one of my printer perfectly since a few weeks. I know have to make multiple for customers and it now doesn't work anymore.
      I tried using the same image on the same setups 3 more times with new boards out of packages. I tried using the micro SD card on the machine that works on the others and it doesn't work. I tried disconnecting eveything on the Duets (steppers, heaters, sensors, IOs, etc) and still no connection.
      The browser is as follow :
      The ACT green LED on board 1 on the 3HC (board with address 1) blink regularly in sync with the EXT green LED on mainboard. Every board has the correct address and only the last jumpers are fitted on the CAN bus.
      The only way to make this works is to disconnect the 3HC extensions and just have the mainboard and Raspberry Pi connected. If I hot plug the CAN connector while it is running it then works. If I power off and the power back on it doesn't work.
      I am a bit lost as the exact same setup worked perfectly fine on the first R&D machine that I built. I have some very short deadlines with my customer and I'm out of solutions to solve this problem, do you have any idea ?
      • chrishammundefined
        chrishamm administrators @e4d
        @e4d If I get it right your machine is stuck in the "starting" state (i.e. while it is trying to execute config.g). You may find further details in the DCS log, see https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#troubleshooting
        Duet software engineer
        e4dundefined 1 Reply Last reply Reply Quote 0
        • e4dundefined
          e4d @chrishamm
          @chrishamm I don't see anything special in the log, I put them in debug mode
          Jan 26 11:01:26 4prime DuetControlServer[440]: [debug] Requesting update of key inputs, seq 9 -> 14
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] Updated key inputs
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] Requesting update of key move, seq 63 -> 72
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] Updated key move
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] Requesting update of key state, seq 11 -> 13
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] Updated key state
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#8, checking permissions...
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#9, checking permissions...
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] IPC#8: Granting full DSF permissions to external plugin
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] Command processor added for IPC#8
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] IPC#8: Received command CheckPassword
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] IPC#8: Received command AddUserSession
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] IPC#9: Granting full DSF permissions to external plugin
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] IPC#8: Connection closed
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] Command processor added for IPC#9
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] IPC#9: Received command CheckPassword
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] IPC#9: Received command AddUserSession
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] IPC#9: Connection closed
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#10, checking permissions...
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#11, checking permissions...
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] IPC#10: Granting full DSF permissions to external plugin
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] IPC#11: Granting full DSF permissions to external plugin
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] Subscription processor for IPC#11 registered in Patch mode
          Jan 26 11:01:27 4prime DuetControlServer[440]: [debug] Subscription processor for IPC#10 registered in Patch mode
          Jan 26 11:01:28 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#12, checking permissions...
          Jan 26 11:01:28 4prime DuetControlServer[440]: [debug] IPC#12: Granting full DSF permissions to external plugin
          Jan 26 11:01:28 4prime DuetControlServer[440]: [debug] Command processor added for IPC#12
          Jan 26 11:01:28 4prime DuetControlServer[440]: [debug] IPC#12: Received command ResolvePath
          Jan 26 11:01:28 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#13, checking permissions...
          Jan 26 11:01:28 4prime DuetControlServer[440]: [debug] IPC#12: Connection closed
          Jan 26 11:01:28 4prime DuetControlServer[440]: [debug] IPC#13: Granting full DSF permissions to external plugin
          Jan 26 11:01:28 4prime DuetControlServer[440]: [debug] Command processor added for IPC#13
          Jan 26 11:01:28 4prime DuetControlServer[440]: [debug] IPC#13: Received command ResolvePath
          Jan 26 11:01:28 4prime DuetControlServer[440]: [debug] IPC#13: Connection closed
          Jan 26 11:01:28 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#14, checking permissions...
          Jan 26 11:01:28 4prime DuetControlServer[440]: [debug] IPC#14: Granting full DSF permissions to external plugin
          Jan 26 11:01:28 4prime DuetControlServer[440]: [debug] Command processor added for IPC#14
          Jan 26 11:01:28 4prime DuetControlServer[440]: [debug] IPC#14: Received command ResolvePath
          Jan 26 11:01:28 4prime DuetControlServer[440]: [debug] IPC#14: Connection closed
          Jan 26 11:01:33 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#15, checking permissions...
          Jan 26 11:01:33 4prime DuetControlServer[440]: [debug] IPC#15: Granting full DSF permissions to external plugin
          Jan 26 11:01:33 4prime DuetControlServer[440]: [debug] Command processor added for IPC#15
          Jan 26 11:01:33 4prime DuetControlServer[440]: [debug] IPC#15: Received command SimpleCode
          Jan 26 11:01:33 4prime DuetControlServer[440]: [debug] HTTP: Starting code M292 R{4} S1
          Jan 26 11:01:33 4prime DuetControlServer[440]: [debug] Processing M292 R{4} S1
          Jan 26 11:01:33 4prime DuetControlServer[440]: [debug] HTTP: Sent M292 R{4} S1, remaining space 1492, needed 44
          Jan 26 11:01:33 4prime DuetControlServer[440]: [debug] Trigger: Message acknowledged
          Jan 26 11:01:33 4prime DuetControlServer[440]: [debug] Trigger: Finished code M291 S4 R"Configuration outils" P"Blocs presents" K{"Bloc 0 : "^{global.bloc_0},"Bloc 1 : "^{global.bloc_1},"Bloc 2 : "^{global.bloc_2},"Bloc 3 : "^{global.bloc_3}, " OK"}
          Jan 26 11:01:33 4prime DuetControlServer[440]: [debug] Trigger: ==> Unfinished starting code: M291 S4 R"Configuration outils" P"Blocs presents" K{"Bloc 0 : "^{global.bloc_0},"Bloc 1 : "^{global.bloc_1},"Bloc 2 : "^{global.bloc_2},"Bloc 3 : "^{global.bloc_3}, " OK"}
          Jan 26 11:01:33 4prime DuetControlServer[440]: [debug] HTTP: Finished code M292 R{4} S1 =>
          Jan 26 11:01:33 4prime DuetControlServer[440]: [debug] Finished codes from macro file config.g
          Jan 26 11:01:33 4prime DuetControlServer[440]: [info] Finished macro file config.g
          Jan 26 11:01:33 4prime DuetControlServer[440]: [debug] IPC#15: Connection closed
          Jan 26 11:01:34 4prime DuetControlServer[440]: [debug] Trigger: Disposing macro file config.g
          Jan 26 11:01:34 4prime DuetControlServer[440]: [debug] Requesting update of key inputs, seq 14 -> 18
          Jan 26 11:01:34 4prime DuetControlServer[440]: [debug] Updated key inputs
          Jan 26 11:01:34 4prime DuetControlServer[440]: [debug] Requesting update of key state, seq 13 -> 14
          Jan 26 11:01:34 4prime DuetControlServer[440]: [debug] Updated key state
          Jan 26 11:01:35 4prime DuetControlServer[440]: [debug] Requesting update of key inputs, seq 18 -> 20
          Jan 26 11:01:35 4prime DuetControlServer[440]: [debug] Updated key inputs
          Jan 26 11:01:35 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#16, checking permissions...
          Jan 26 11:01:35 4prime DuetControlServer[440]: [debug] IPC#16: Granting full DSF permissions to external plugin
          Jan 26 11:01:35 4prime DuetControlServer[440]: [debug] Command processor added for IPC#16
          Jan 26 11:01:35 4prime DuetControlServer[440]: [debug] IPC#16: Received command CheckPassword
          Jan 26 11:01:35 4prime DuetControlServer[440]: [debug] IPC#16: Received command AddUserSession
          Jan 26 11:01:35 4prime DuetControlServer[440]: [debug] IPC#16: Connection closed
          Jan 26 11:01:35 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#17, checking permissions...
          Jan 26 11:01:35 4prime DuetControlServer[440]: [debug] IPC#17: Granting full DSF permissions to external plugin
          Jan 26 11:01:35 4prime DuetControlServer[440]: [debug] Command processor added for IPC#17
          Jan 26 11:01:35 4prime DuetControlServer[440]: [debug] IPC#17: Received command CheckPassword
          Jan 26 11:01:35 4prime DuetControlServer[440]: [debug] IPC#17: Received command AddUserSession
          Jan 26 11:01:35 4prime DuetControlServer[440]: [debug] IPC#17: Received command GetObjectModel
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#18, checking permissions...
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#19, checking permissions...
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] IPC#18: Granting full DSF permissions to external plugin
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] IPC#19: Granting full DSF permissions to external plugin
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] Command processor added for IPC#18
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] Command processor added for IPC#19
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] IPC#18: Received command RemoveUserSession
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] IPC#19: Received command RemoveUserSession
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] IPC#18: Connection closed
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] IPC#19: Connection closed
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] IPC#17: Connection closed
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#20, checking permissions...
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] IPC#20: Granting full DSF permissions to external plugin
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] Command processor added for IPC#20
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] IPC#20: Received command CheckPassword
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] IPC#20: Received command AddUserSession
          Jan 26 11:01:36 4prime DuetControlServer[440]: [debug] IPC#20: Connection closed
          Jan 26 11:01:37 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#21, checking permissions...
          Jan 26 11:01:37 4prime DuetControlServer[440]: [debug] IPC#21: Granting full DSF permissions to external plugin
          Jan 26 11:01:37 4prime DuetControlServer[440]: [debug] Subscription processor for IPC#21 registered in Patch mode
          Jan 26 11:01:37 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#22, checking permissions...
          Jan 26 11:01:37 4prime DuetControlServer[440]: [debug] IPC#22: Granting full DSF permissions to external plugin
          Jan 26 11:01:37 4prime DuetControlServer[440]: [debug] Command processor added for IPC#22
          Jan 26 11:01:37 4prime DuetControlServer[440]: [debug] IPC#22: Received command ResolvePath
          Jan 26 11:01:37 4prime DuetControlServer[440]: [debug] IPC#22: Connection closed
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#23, checking permissions...
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#24, checking permissions...
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] IPC#23: Granting full DSF permissions to external plugin
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] IPC#24: Granting full DSF permissions to external plugin
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] Command processor added for IPC#23
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] IPC#23: Received command RemoveUserSession
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] Command processor added for IPC#24
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] IPC#23: Connection closed
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] IPC#24: Received command RemoveUserSession
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] IPC#24: Connection closed
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#25, checking permissions...
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] IPC#25: Granting full DSF permissions to external plugin
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] Command processor added for IPC#25
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] IPC#25: Received command CheckPassword
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] IPC#25: Received command AddUserSession
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] IPC#25: Connection closed
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#26, checking permissions...
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] IPC#26: Granting full DSF permissions to external plugin
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] Command processor added for IPC#26
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] IPC#26: Received command RemoveUserSession
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] IPC#26: Connection closed
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] IPC#11: Subscription processor unregistered
          Jan 26 11:02:06 4prime DuetControlServer[440]: [debug] IPC#11: Connection closed
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#27, checking permissions...
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] IPC#27: Granting full DSF permissions to external plugin
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] Command processor added for IPC#27
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] IPC#27: Received command CheckPassword
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] IPC#27: Received command AddUserSession
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] IPC#27: Received command GetObjectModel
          Jan 26 11:02:07 4prime DuetControlServer[440]: [info] System time has been changed
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] Trigger: Starting code M905 P"2024-01-26" S"11:02:07"
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] Trigger: Sent M905 P"2024-01-26" S"11:02:07", remaining space 1476, needed 60
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] Trigger: Finished code M905 P"2024-01-26" S"11:02:07" =>
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] IPC#27: Connection closed
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#28, checking permissions...
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] IPC#28: Granting full DSF permissions to external plugin
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] Command processor added for IPC#28
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] IPC#28: Received command CheckPassword
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] IPC#28: Received command AddUserSession
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] IPC#28: Connection closed
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#29, checking permissions...
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] IPC#29: Granting full DSF permissions to external plugin
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] Subscription processor for IPC#29 registered in Patch mode
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#30, checking permissions...
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] IPC#30: Granting full DSF permissions to external plugin
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] Command processor added for IPC#30
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] IPC#30: Received command ResolvePath
          Jan 26 11:02:07 4prime DuetControlServer[440]: [debug] IPC#30: Connection closed
          Jan 26 11:02:08 4prime DuetControlServer[440]: [debug] Requesting update of key inputs, seq 20 -> 22
          Jan 26 11:02:08 4prime DuetControlServer[440]: [debug] Updated key inputs
          Jan 26 11:02:09 4prime DuetControlServer[440]: [debug] Requesting update of key boards, seq 471 -> 472
          Jan 26 11:02:09 4prime DuetControlServer[440]: [debug] Updated key boards
          Jan 26 11:02:09 4prime DuetControlServer[440]: [debug] Requesting update of key boards, seq 472 -> 474
          Jan 26 11:02:11 4prime DuetControlServer[440]: [debug] Requesting update of key boards, seq 474 -> 475
          Jan 26 11:02:11 4prime DuetControlServer[440]: [debug] Updated key boards
          Jan 26 11:02:12 4prime DuetControlServer[440]: [debug] Requesting update of key boards, seq 475 -> 476
          Jan 26 11:02:12 4prime DuetControlServer[440]: [debug] Updated key boards
          Jan 26 11:02:14 4prime DuetControlServer[440]: [debug] Requesting update of key boards, seq 476 -> 479
          Jan 26 11:02:14 4prime DuetControlServer[440]: [debug] Updated key boards
          Jan 26 11:02:16 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#31, checking permissions...
          Jan 26 11:02:16 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#32, checking permissions...
          Jan 26 11:02:16 4prime DuetControlServer[440]: [debug] IPC#32: Granting full DSF permissions to external plugin
          Jan 26 11:02:16 4prime DuetControlServer[440]: [debug] IPC#31: Granting full DSF permissions to external plugin
          Jan 26 11:02:16 4prime DuetControlServer[440]: [debug] Command processor added for IPC#32
          Jan 26 11:02:16 4prime DuetControlServer[440]: [debug] Command processor added for IPC#31
          Jan 26 11:02:16 4prime DuetControlServer[440]: [debug] IPC#32: Received command RemoveUserSession
          Jan 26 11:02:16 4prime DuetControlServer[440]: [debug] IPC#31: Received command RemoveUserSession
          Jan 26 11:02:16 4prime DuetControlServer[440]: [debug] IPC#32: Connection closed
          Jan 26 11:02:16 4prime DuetControlServer[440]: [debug] IPC#31: Connection closed
          Jan 26 11:02:16 4prime DuetControlServer[440]: [debug] Requesting update of key boards, seq 479 -> 480
          Jan 26 11:02:16 4prime DuetControlServer[440]: [debug] Updated key boards
          Jan 26 11:02:18 4prime DuetControlServer[440]: [debug] Requesting update of key boards, seq 480 -> 481
          Jan 26 11:02:18 4prime DuetControlServer[440]: [debug] Updated key boards
          Jan 26 11:02:18 4prime DuetControlServer[440]: [debug] Requesting update of key inputs, seq 22 -> 24
          Jan 26 11:02:18 4prime DuetControlServer[440]: [debug] Updated key inputs
          Jan 26 11:02:25 4prime DuetControlServer[440]: [debug] Requesting update of key boards, seq 481 -> 487
          Jan 26 11:02:25 4prime DuetControlServer[440]: [debug] Updated key boards
          Jan 26 11:02:28 4prime DuetControlServer[440]: [debug] Requesting update of key inputs, seq 24 -> 26
          Jan 26 11:02:28 4prime DuetControlServer[440]: [debug] Updated key inputs
          Jan 26 11:02:34 4prime DuetControlServer[440]: [debug] Requesting update of key boards, seq 487 -> 488
          Jan 26 11:02:34 4prime DuetControlServer[440]: [debug] Updated key boards
          Jan 26 11:02:36 4prime DuetControlServer[440]: [debug] Requesting update of key boards, seq 488 -> 492
          Jan 26 11:02:36 4prime DuetControlServer[440]: [debug] Updated key boards
          Jan 26 11:02:37 4prime DuetControlServer[440]: [debug] Requesting update of key boards, seq 492 -> 494
          Jan 26 11:02:37 4prime DuetControlServer[440]: [debug] Updated key boards
          Jan 26 11:02:38 4prime DuetControlServer[440]: [debug] Requesting update of key inputs, seq 26 -> 28
          Jan 26 11:02:38 4prime DuetControlServer[440]: [debug] Updated key inputs
          Jan 26 11:02:39 4prime DuetControlServer[440]: [debug] Requesting update of key boards, seq 494 -> 498
          Jan 26 11:02:39 4prime DuetControlServer[440]: [debug] Updated key boards
          Jan 26 11:02:42 4prime DuetControlServer[440]: [debug] Requesting update of key boards, seq 498 -> 499
          Jan 26 11:02:42 4prime DuetControlServer[440]: [debug] Updated key boards
          Jan 26 11:02:43 4prime DuetControlServer[440]: [debug] Requesting update of key boards, seq 499 -> 501
          Jan 26 11:02:43 4prime DuetControlServer[440]: [debug] Updated key boards
          Jan 26 11:02:44 4prime DuetControlServer[440]: [debug] Requesting update of key boards, seq 501 -> 505
          Jan 26 11:02:44 4prime DuetControlServer[440]: [debug] Updated key boards
          Jan 26 11:02:48 4prime DuetControlServer[440]: [debug] Requesting update of key inputs, seq 28 -> 30
          Jan 26 11:02:48 4prime DuetControlServer[440]: [debug] Updated key inputs
          Jan 26 11:02:56 4prime DuetControlServer[440]: [debug] Got new UNIX connection via IPC#33, checking permissions...
          Am I wrong ?
          Am I wrong ?
            @e4d Your log is incomplete. Please post the full log since the start of DCS.
            The output of M122 via the CLI tool /opt/dsf/bin/CodeConsole may help, too.
            • e4dundefined
              e4d @chrishamm
              @chrishamm I couldn't paste because of 20k characters limit, here you can find the output of the log : https://pastebin.com/mmkc4RHW
              When I try to execute : "/opt/dsf/bin/CodeConsole", I get "Failed to connect to DCS".
              • e4dundefined
                e4d @e4d
                @e4d after retrying 5-6 times it outputed :
                RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.2 (2023-12-14 10:32:22) running on Duet 3 MB6HC v1.02 or later (SBC mode)
                Board ID: 08DLM-9K6R1-L83T4-6JTD4-3S86Q-9XRTP
                Used output buffers: 1 of 40 (23 max)
                Error in macro line 326 while starting up: M308: Failed to initialise BME280 sensor: hardwareError
                Static ram: 154844
                Dynamic ram: 88684 of which 3932 recycled
                Never used RAM 95676, free system stack 202 words
                Tasks: SBC(2,rWait:,0.8%,438) HEAT(3,nWait,0.0%,336) Move(4,nWait,0.0%,339) CanReceiv(6,nWait,0.0%,772) CanSender(5,nWait,0.0%,334) CanClock(7,delaying,0.0%,348) TMC(4,nWait,7.6%,59) MAIN(2,running,91.5%,103) IDLE(0,ready,0.1%,30), total 100.0%
                Owned mutexes: Telnet(MAIN)
                Last reset 00:12:54 ago, cause: power up
                Last software reset details not available
                Error status: 0x00
                MCU temperature: min 27.9, current 35.6, max 35.8
                Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                12V rail voltage: min 12.1, current 12.2, max 12.4, under voltage events: 0
                Heap OK, handles allocated/used 99/56, heap memory allocated/used/recyclable 2048/916/48, gc cycles 0
                Events: 0 queued, 0 completed
                Driver 0: standstill, SG min n/a, mspos 8, reads 1638, writes 14 timeouts 0
                Driver 1: standstill, SG min n/a, mspos 8, reads 1638, writes 14 timeouts 0
                Driver 2: standstill, SG min n/a, mspos 8, reads 1638, writes 14 timeouts 0
                Driver 3: standstill, SG min n/a, mspos 8, reads 1639, writes 14 timeouts 0
                Driver 4: standstill, SG min n/a, mspos 8, reads 1639, writes 14 timeouts 0
                Driver 5: standstill, SG min n/a, mspos 8, reads 1639, writes 14 timeouts 0
                Date/time: 2024-01-26 11:27:08
                Slowest loop: 26.01ms; fastest: 0.00ms
                === Storage ===
                Free file entries: 20
                DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, ebfmin 0.00, ebfmax 0.00
                no step interrupt scheduled
                Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                === DDARing 0 ===
                === DDARing 1 ===
                Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 5 -1 -1 -1, ordering errs 0
                HTTP is idle in state(s) 0
                Telnet* is doing "M122" in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger* is idle in state(s) 0 77 0, running macro
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon is idle in state(s) 0
                Aux2 is idle in state(s) 0
                File2 is idle in state(s) 0
                Queue2 is idle in state(s) 0
                Q0 segments left 0, axes/extruders owned 0x0000000
                Code queue 0 is empty
                Code queue 1 is empty
                === CAN ===
                Messages queued 6923, received 27621, lost 0, errs 0, boc 0
                Longest wait 1ms for reply type 6018, peak Tx sync delay 385, free buffers 50 (min 49), ts 3875/3874/0
                Tx timeouts 0,0,0,0,0,0
                === SBC interface ===
                Transfer state: 5, failed transfers: 0, checksum errors: 0
                RX/TX seq numbers: 29326/29326
                SPI underruns 0, overruns 0
                State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x258a4
                Buffer RX/TX: 0/0-0, open files: 0
                === Duet Control Server ===
                Duet Control Server version 3.5.0-rc.2 (2023-12-18 12:39:35)
                Trigger:
                >> Doing macro config.g, started by system
                >>> Waiting for acknowledgement, requested by M291 S4 R"Configuration outils" P"Blocs presents" K{"Bloc 0 : "^{global.bloc_0},"Bloc 1 : "^{global.bloc_1},"Bloc 2 : "^{global.bloc_2},"Bloc 3 : "^{global.bloc_3}, " OK"}
                Code buffer space: 4096
                Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                Full transfers per second: 34.24, max time between full transfers: 59.2ms, max pin wait times: 52.2ms/11.3ms
                Codes per second: 0.12
                Maximum length of RX/TX data transfers: 5865/1108
                ok
                I had multiples "Failed to connect to DCS before"
                chrishammundefined 2 Replies Last reply Reply Quote 0
                  @e4d It looks like your BME280 sensor doesn't work:
                  Apart from that the log looks OK. Does anything change if you remove the M291 code from your config.g?
                    @e4d Please post your full config.g as well.
                    • e4dundefined
                      e4d @chrishamm
                      @chrishamm
                      ; Duet 3 Configuration File
                      G21 																		; Work in millimetres
                      G90 																		; Send absolute coordinates...
                      M83 																		; ...but relative extruder moves
                      M669 K1																		; Set Core XY mode
                      G4 S5
                      ;##################################################### Steppers ####################################################################################
                      ;Definition
                      M569 P0.0 S0	            ; Driver X
                      M569 P0.1 S0	            ; Driver Y
                      M569 P0.2 S0	            ; Driver Z3
                      M569 P0.3 S0	            ; Driver Z1
                      M569 P0.4 S1	            ; Driver A
                      M569 P0.5 S0	            ; Driver Z2
                      M569 P1.0 S0	            ; E0 Direct Drive
                      M569 P1.1 S0	            ; E0 Bowden
                      M569 P1.2 S0	            ; E1 Direct Drive
                      M569 P2.0 S1	            ; E1 Bowden
                      M569 P2.1 S0	            ; E2 Direct Drive
                      M569 P2.2 S0	            ; E2 Bowden
                      M569 P3.0 S1	            ; E3 Direct Drive
                      M569 P3.1 S1	            ; E3 Bowden
                      ;Parametres
                      M584 X0.0 Y0.1 Z0.3:0.5:0.2 E1.0:1.1:1.2:2.0:2.1:2.2:3.0:3.1 A0.4				; Apply custom drive mapping
                      M208 X-40.5:396 Y-32.8:370.0 A0:132.0 Z0:395 			    					; Set axis maxima & minima
                      M350 X16 Y16 Z16 A16 E16:16:16:16:16:16:16:16 I1								; Configure microstepping with interpolation
                      M566 X240 Y240 Z400 E1500:1500:1500:1500:1500:1500:1500:1500 A400	      		; Set maximum instantaneous speed changes (mm/min)
                      M203 X30000 Y30000 Z1000 E5000:5000:5000:5000:5000:5000:5000:5000 A2000   		; Set maximum speeds (mm/min)
                      M201 X4000 Y4000 Z500 E4000:4000:4000:4000:4000:4000:4000:4000 A500 		    ; Set accelerations (mm/s^2)
                      M906 X1800 Y1800 Z1200 A400 I30                         			    		; Idle motion motors to 30%
                      M906 E650:650:650:650:650:650:650:650 I10   							    	; Idle extruder motors to 10%
                      M92 X80 Y80 Z800 E400:400:400:400:400:400:400:400 A400   			    		; Set steps per mm assuming x16 microstepping
                      ; ENDSTOPS
                      M574 X1 S1	P"0.io1.in"				                                            ; Set X endstop switch detection
                      M574 Y1 S1	P"0.io2.in"				                                            ; Set Y endstop switch detection
                      M574 Z1 S2				                                                        ; Set Z endstop switch detection
                      M574 A1 S2        ; Set A endstop switch detection
                      ;Z clic probe
                      M558 K0 P8 C"0.io0.in" H5 F700 I0 T10000 		                                ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
                      G31 K0 P200 X0 Y0 Z0 A0				    		                                ; Set Z probe trigger value, offset and trigger height
                      M557 K0 X5:295 Y5:295 P10:10 			    	                                ; Define mesh grid
                      ;FSR offset probe
                      M558 K1 P8 C"!0.io3.in" H5 F80 T500     		                                ; Configure Z probe offset
                      G31 K1 P125 X0 Y0 Z0                        	                                ; Set Z probe trigger value, offset and trigger height
                      M950 P18 C"0.io3.out" 							                                ; reset pin
                      M42 P18 S1										                                ; Init reset pin
                      ;##################################################### Pneumatic ####################################################################################
                      ;Coupler Pump
                      M950 P14 C"2.out1"
                      M42 P14 S0
                      ; Soufflage copeaux
                      M950 P22 c"2.out0"
                      M42 P22 S0
                      ; Blower solenoid
                      M950 P15 C"2.out7" ;M2
                      M42 P15 S0
                      ; Aspiration solenoid
                      M950 P16 C"2.out6" ;M1
                      M42 P16 S0
                      ; Pneumatic sensor
                      M950 J2 C"!1.io1.in"
                      ;##################################################### Heaters ####################################################################################
                      ;Bed
                      M308 S0 P"0.temp0" Y"thermistor" A"Bed" T100000 B4725 C7.06e-8      ; configure sensor 0 as thermistor on pin temp0
                      M950 H0 C"0.out0" T0 Q10                                            ; create bed heater output on out0 and map it to sensor 0
                      M307 H0 R0.605 K0.237:0.000 D2.36 E1.35 S1.00 B0                         ; enable PID mode for the bed heater and set PWM limit
                      M140 H0                                                             ; map heated bed to heater 0
                      M143 H0 S215                                                        ; set temperature limit for heater 0 to 215C
                      ;Chamber
                      M308 S5 P"1.temp0" Y"pt1000" A"Chamber" T100000 B4725 C7.06e-8  	; Set thermistor
                      M950 H5 C"1.out2" T5												; Chamber heater
                      M950 P17 C"1.out3"													; Chamber heater fan
                      M307 H5 B0 S1.00 					                          		; Bang bang tuning
                      M141 H5                                                         	; Define heated chamber
                      M143 H5 S75 														; Set temperature limit for heater 5 to 70C
                      M570 H5 P999999 T50                                                 ; configure heater fault on H4
                      ;##################################################### Capteurs de blocs matériaux ###############################################################
                      M308 S6 P"1.temp1" Y"linear-analog" A"Bloc_0"
                      M308 S7 P"1.temp2" Y"linear-analog" A"Bloc_1"
                      M308 S8 P"2.temp0" Y"linear-analog" A"Bloc_2"
                      M308 S9 P"2.temp1" Y"linear-analog" A"Bloc_3"
                      global bloc_0 = "vide"
                      global bloc_1 = "vide"
                      global bloc_2 = "vide"
                      global bloc_3 = "vide"
                      G4 S1
                      global Bval_0 = sensors.analog[6].lastReading
                      global Bval_1 = sensors.analog[7].lastReading
                      global Bval_2 = sensors.analog[8].lastReading
                      global Bval_3 = sensors.analog[9].lastReading
                      M98 P"0:/sys/macros/bloc_id.gcode"
                      ;##################################################### Bloc 0 ####################################################################################
                      if sensors.analog[6].lastReading >= 0 && sensors.analog[6].lastReading < 10
                      	set global.bloc_0 = "Filament"
                      	; Heater 0
                      	M308 S1 P"0.temp1" Y"pt1000" A"Heater 0" T100000 B4725 C7.06e-8  	; Set thermistor
                      	M950 H1 C"0.out1" T1												; H1 heater
                      	M143 H1 S400 														; Set temperature limit for heater 1 to 400C
                      	M307 H1 R1.554 K0.205:0.000 D5.28 E1.35 S1.00 B0 V23.8				; PID setup
                      	;Fans
                      	M950 F0 C"0.out4"               									; part cooling fan
                      	M950 F1 C"0.out5"               									; heatsink fan
                      	M106 P1 S1.0 H1 T70	           										; fan full if heater 1 > 70C
                      	M106 P0 S0 															; print cooling fan stop
                      	; Define tool
                      	M563 P0 S"Extruder" D0:1 H1 F0
                      	G10 P0 S0 R0
                      	M567 P0 E1.0:1.0
                      	; Filament monitor
                      	M591 D0 P7 C"1.io0.in" L7 R75:125 E22 S1
                      elif sensors.analog[6].lastReading >= 10  && sensors.analog[6].lastReading < 20
                      	set global.bloc_0 = "Incompatible"
                      elif sensors.analog[6].lastReading >= 20 && sensors.analog[6].lastReading < 30
                      	set global.bloc_0 = "Soustractif"
                      	; Define tool
                          M563 P0 S"Fraise"
                          M950 P0 C"0.io4.out" Q1000             	    						; Define unsoll pin output
                          M42 P0 S0			 	                    						; Init ESC
                          M950 P7 C"2.io3.out"                        						; Define direction pin output
                          M42 P7 S0															; Init direction
                      ;##################################################### Bloc 1 ####################################################################################
                      if sensors.analog[7].lastReading >= 0 && sensors.analog[7].lastReading < 10
                      	set global.bloc_1 = "Filament"
                      	; Heater 1
                      	M308 S2 P"0.temp2" Y"pt1000" A"Heater 1" T100000 B4725 C7.06e-8  	; Set thermistor
                      	M950 H2 C"0.out2" T2												; H2 heater
                      	M143 H2 S400 														; Set temperature limit for heater 2 to 400C
                      	M307 H2 R1.554 K0.205:0.000 D5.28 E1.35 S1.00 B0 V23.8				; PID setup
                      	M950 F2 C"0.out6"               									; part cooling fan
                      	M950 F3 C"0.out7"               									; heatsink fan
                      	M106 P3 S1.0 H2 T70	           										; fan full if heater 1 > 70C
                      	M106 P2 S0 															; print cooling fan stop
                      	;Define tool
                      	M563 P1 S"Extruder" D2:3 H2 F2
                      	M567 P1 E1.0:1.0
                          G10 P1 S0 R0
                      	; Filament monitor
                      	M591 D2 P7 C"1.io5.in" L7 R75:125 E22 S1
                      elif sensors.analog[7].lastReading >= 10  && sensors.analog[7].lastReading < 20
                      	set global.bloc_1 = "Incompatible"
                      elif sensors.analog[7].lastReading >= 20 && sensors.analog[7].lastReading < 30
                      	set global.bloc_1 = "Soustractif"
                      	; Define tool
                      	M563 P1 S"Fraise"													; Define tool
                      	M950 P1 C"0.io4.out" Q1000 											; Define unsoll pin output
                      	M42 P1 S0			 	                							; Init ESC
                       	M950 P8 C"2.io4.out"                    							; Define direction pin output
                          M42 P8 S0															; Init direction
                      ;##################################################### Bloc 2 ####################################################################################
                      if sensors.analog[8].lastReading >= 0 && sensors.analog[8].lastReading < 10
                      	set global.bloc_2 = "Filament"
                      	; Heater 2
                      	M308 S3 P"0.temp3" Y"pt1000" A"Heater 2" T100000 B4725 C7.06e-8  	; Set thermistor
                      	M950 H3 C"0.out3" T3												; H3 heater
                      	M143 H3 S400 														; Set temperature limit for heater 3 to 400C
                      	M307 H3 R1.554 K0.205:0.000 D5.28 E1.35 S1.00 B0 V23.8				; PID setup
                      	M950 F4 C"0.out8"               									; part cooling fan
                      	M950 F5 C"0.out9"               									; heatsink fan
                      	M106 P5 S1.0 H3 T70	           										; fan full if heater 3 > 70C
                      	M106 P4 S0 															; print cooling fan stop
                      	; Define tool
                      	M563 P2 S"Extruder" D4:5 H3 F4
                      	M567 P2 E1.0:1.0
                          G10 P2 S0 R0
                      	; Filament monitor
                      	M591 D4 P7 C"2.io0.in" L7 R75:125 E22 S1
                      elif sensors.analog[8].lastReading >= 10  && sensors.analog[8].lastReading < 20
                      	set global.bloc_2 = "Pellet"
                      	; Heater 2
                      	M106 P5 S1.0 H3 T70	           										; fan full if heater 1 > 70C
                      	M950 F11 C"3.out3"  												; TEMPORAIRE !!!!!!
                      	M106 P11 S1 														; TEMPORAIRE !!!!!!
                      	; Define tool
                      	M906 E650:650:650:650:1400:650:650:650 I10							; Set stepper current to 1A
                          M563 P2 S"Pellet" D4 H3 F4
                          G10 P2 S0 R0
                      elif sensors.analog[8].lastReading >= 20 && sensors.analog[8].lastReading < 30
                      	set global.bloc_2 = "Soustractif"
                      	M563 P2 S"Fraise"						                			; Define tool
                      	M950 P2 C"0.io7.out" Q1000 				               				; Define unsoll output
                      	M42 P2 S0			 	                                			; Init ESC
                       	M950 P9 C"2.io5.out"                                    			; Define direction pin output
                      	M42 P9 S0															; Init direction
                      ;##################################################### Bloc 3 ####################################################################################
                      if sensors.analog[9].lastReading >= 0 && sensors.analog[9].lastReading < 10
                      	set global.bloc_3 = "Filament"
                      	; Heater 3
                      	M308 S4 P"3.temp0" Y"pt1000" A"Heater 3" T100000 B4725 C7.06e-8  	; Set thermistor
                      	M950 H4 C"3.out0" T4												; H4 heater
                      	M143 H4 S400 														; Set temperature limit for heater 4 to 400C
                      	M307 H4 R1.554 K0.205:0.000 D5.28 E1.35 S1.00 B0 V23.8				; PID setup
                      	M950 F6 C"3.out5"               									; part cooling fan
                      	M950 F7 C"3.out4"               									; heatsink fan
                      	M106 P7 S1.0 H4 T70	           										; fan full if heater 1 > 70C
                      	M106 P6 S0 															; print cooling fan stop
                      	;Define tool
                      	M563 P3 S"Extruder" D6:7 H4 F6
                          M567 P3 E1.0:1.0
                          G10 P3 S0 R0
                      	; Filament monitor
                      	M591 D6 P7 C"3.io0.in" L7 R75:125 E22 S1
                      elif sensors.analog[9].lastReading >= 10  && sensors.analog[9].lastReading < 20
                      	set global.bloc_3 = "Pellet"
                      	; Heater 3
                      	M570 H3 P300 T99999													; TEMPORAIRE !!!!!!!!!!!!!!!
                      	;Define tool
                      	if move.extruders[4].current == 1000
                      		M906 E650:650:650:650:1400:650:1400:650 I10						; Set stepper current to 1A
                      	else
                      		M906 E650:650:650:650:650:650:1400:650 I10
                      	M563 P3 S"Pellet" D6 H4 F6
                          G10 P3 S0 R0
                      elif sensors.analog[9].lastReading >= 20 && sensors.analog[9].lastReading < 30
                          set global.bloc_3 = "Incompatible"
                      ;##################################################### IO ####################################################################################
                      ;led strip
                      M950 E0 C"led" T1 Q3000000 U100
                      M150 E0 B255 R0 U0 P100 S100
                      ;Pebble Wiper
                      M950 S21 C"2.io1.out"
                      M280 P21 S50
                      ;Capteurs ouverture de portes
                      ;M950 J5 C"2.io1.in" 													;ouverture de porte
                      ;M950 J6 C"2.io2.in"														;ouverture du couvercle
                      M308 S25 P"2.io2.in" Y"linear-analog"
                      ; Bloc 48V alim
                      M950 P19 C"2.out5"														; Relais de contrôle des alimentations 48V
                      M42 P19 S0
                      ; TESTS COLINE
                      M950 P30 C"3.io5.out"
                      ; BME 280  armoire à matériaux
                      M308 S10 P"spi.cs0" Y"bme280" A"Temperature"
                      ;M308 S11 P"S10.1" Y"bme-pressure" A"pressure[hPa]"
                      M308 S12 P"S10.2" Y"bme-humidity" A"Humidity[%]"
                      ; Filtre à air
                      M950 P20 C"3.out2"
                      M42 P20 S0
                      ; Accelerometer Input Shaping
                      ;M955 P0 C"spi.cs2+spi.cs3" I14											; Temporaire
                      ;##################################################### Variables ##############################################################################
                      global fan_chamber = false
                      global pneumatic_debug = 0
                      global iteration = 0
                      global togglePneumatic = false
                      global runDaemon = true
                      global timeBed = 0
                      global x_pos = 0
                      global y_pos = 0
                      global z_pos = 0
                      global x_off = 0
                      global y_off = 0
                      global z_off = 0
                      global z_plateau_ref = 0
                      global outil_select = 99
                      global seuils_definis = false
                      global homeall = false
                      global timer_filtre = 0
                      global timer_filtre_incr = 0
                      global pwm_fraise = 0
                      global ip_addr = ""
                      global tool_T0_posX = 0
                      global tool_T0_posY = 0
                      global tool_T1_posX = 0
                      global tool_T1_posY = 0
                      global tool_T2_posX = 0
                      global tool_T2_posY = 0
                      global tool_T3_posX = 0
                      global tool_T3_posY = 0
                      global tool_T0_posX_mes = 0
                      global tool_T0_posY_mes = 0
                      global tool_T1_posX_mes = 0
                      global tool_T1_posY_mes = 0
                      global tool_T2_posX_mes = 0
                      global tool_T2_posY_mes = 0
                      global tool_T3_posX_mes = 0
                      global tool_T3_posY_mes = 0
                      ;##################################################### Post Config ############################################################################
                      ;M586 P1 S1 R80 C"*"
                      M501
                      M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
                      ;##################################################### Affichage #############################################################################
                        @e4d The panel of the temperature graph looks odd to me. Perhaps try to disable your ad-blocker (if any) and if that doesn't help, open the dev tools via F12 and check the JS Console for errors.
                        • e4dundefined
                          e4d @chrishamm
                          @chrishamm my adblocker is already disabled, here's the output of the dev console on 3 differents browser Chrome, Opera and Edge :
                          index.ts:420 TypeError: Failed to execute 'appendChild' on 'Node': parameter 1 is not of type 'Node'.
                              at window.Node.appendChild (vue-fragment.esm.js:1:4055)
                              at window.Node.insertBefore (vue-fragment.esm.js:1:3770)
                              at Object.insertBefore (vue.runtime.esm.js:6311:16)
                              at updateChildren (vue.runtime.esm.js:6800:29)
                              at patchVnode (vue.runtime.esm.js:6913:21)
                              at updateChildren (vue.runtime.esm.js:6787:17)
                              at VueComponent.patch [as __patch__] (vue.runtime.esm.js:7081:17)
                              at v._update (vue.runtime.esm.js:3769:25)
                              at VueComponent.ne (vue.runtime.esm.js:3875:16)
                            @e4d Okay, the new version 3.5.0-rc.3 should have a bug fix for this error message, although I don't think it's the reason why DWC stays in "Connecting". Can you try to upgrade your SBC using apt update/apt upgrade and check if that helps?
                            • e4dundefined
                              e4d @chrishamm
                              @chrishamm thanks for the release, the error message is fixed in the dev console on the browser.
                              The connection issue was still there sadly. I identified that the issue is caused by the line
                              M141 H5
                              If I have it in the config.g file, impossible to connect and when I comment it I can connect on the board as usual. If I comment it on the config, power up and then write "M141 H5" in the console it goes on connection screen.
                              Is it a known bug or something new ? I can't figure out how to have the control on the heated chamber without using M141 to declare it. Is there a workaround or do you plan a bug fix soon ?
                                @e4d Is there any way you could provide a minimal config.g that lets you reproduce this problem? I just put M141 H5 in my config.g and after a restart my machine came up as expected.
                                • e4dundefined
                                  e4d @chrishamm
                                  @chrishamm
                                  This config let us reproduce the problem :
                                  ;Bed
                                  ;Chamber
                                  To test this I did :
                                  • Put this config with "M141 H5" commented
                                  • Access the DWC in Chrome browser
                                  • Execute "M141 H5" in the console
                                  • Refresh the webpage
                                  chrishammundefined 2 Replies Last reply Reply Quote 1
                                    @e4d Thanks! I could reproduce and fix it. The fix will be included in the next DWC version, so probably 3.5.0 stable.
                                    e4dundefined 1 Reply Last reply Reply Quote 1
                                    • e4dundefined
                                      e4d @chrishamm
                                      @chrishamm thank you for your quick inputs on my issue. Do you have any timeline on the release of 3.5 stable ? I can't use an heated chamber in the meantime ?
                                        @e4d You can replace DWC in SBC mode by uploading DuetWebControl-SBC.zip from here on the Files -> System page. This build should fix the problem again (it was actually caused by the JS error you reported).
                                        • chrishammundefined chrishamm referenced this topic
                                        • e4dundefined
                                          e4d @chrishamm
                                          @chrishamm it works well on my machines, thank you again for your time on my issue
