    Multiple Analog ZProbe
    225
    • Zsevenundefined
      Zseven
      IMG_6515.JPEG Hello
      why can I only set 1x analogue sample?
      Why are not more supported?
        What hardware are you using and how are you trying to configure it exactly? Share your config.g and firmware version.
        Zsevenundefined 1 Reply Last reply Reply Quote 0
        • Zsevenundefined
          Zseven @Phaedrux
          @Phaedrux
          Hello ,
          I have the Duet 3 6XD
          I found this in the documentation:
          From RRF 3.1.0, you can define multiple probes.
          The K parameter in M558 selects the Z probe number. If there is no K parameter then 0 is used. You can ignore this parameter if you have only one Z probe.
          Z probe #0 can use probe types 0, 1, 2, 3, 5, 8, 9 or 10. All other probes must be probe type 0, 8, 9 or 10.
          But why is that so ?
          I need 3x type 2
          Translated with DeepL.com (free version)
          • oliofundefined
            oliof @Zseven
            @Zseven why do you need three z probes?
            • Zsevenundefined
              Zseven @oliof
              @oliof
              3 Tool whit analoge z-probe (Pessure Sensor)
                Perhaps reconfigure the probe before use by sending it's own M558 and G31 commands in your tool change files.
                Do you really need one probe for each tool though?
                Zsevenundefined 2 Replies Last reply Reply Quote 0
                • Zsevenundefined
                  Zseven @Phaedrux
                  @Phaedrux
                  Hello ,
                  yes, I have installed a load cell in each tool which outputs an analog value.
                  The background is that I want to measure the tool offset and the filament pressure on the nozzle.
                    If only one tool is being used at a time, you could do the reconfiguration method I mentioned.
                    Are you using toolboards or just the 6XD by itself?
                    • Zsevenundefined
                      Zseven @Phaedrux
                      @Phaedrux
                      Yes i Use 6XD.
                      • Zsevenundefined
                        Zseven @Phaedrux
                        @Phaedrux
                        Thank You it Works.
