    Is my DuetWifiServer.bin properly updated?
    311
    • phoenixundefined
      phoenix
      trying to troubleshoot another problem I discovered a possible cause to a recurring annoyance of mine: the connection to the webinterface tends to reset itself every so often. Haven't bothered so far as more pressing things, but here's what I have: at random intervals I see this in the logs:
      Digging in, I find that the while everything else is at RRP 3.5.0-rc3, the Wifi system is listed DuetWiFiServer 2.1beta6. I can't find what the exact last version needs to be, but I downloaded the Duetwifiserver.bin listed in RRP 3.5.0-rc3 and uploaded it (using webinterface): when restarting it stays at v2.1beta6
      Can you tell me what version there should be?
      Thanks!
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-rc.3 (2024-01-24 17:56:24) running on Duet WiFi 1.02 or later + DueX5
      Board ID: 08DGM-917DA-G4MS8-6J9FL-3SN6N-TVVR9
      Used output buffers: 9 of 26 (26 max)
      Static ram: 23224
      Dynamic ram: 77664 of which 0 recycled
      Never used RAM 12256, free system stack 182 words
      Tasks: NETWORK(1,ready,13.4%,221) ACCEL(6,nWait 5,0.0%,346) HEAT(3,nWait 5,0.1%,327) Move(4,nWait 5,0.0%,360) DUEX(5,nWait 5,0.0%,24) MAIN(1,running,86.0%,742) IDLE(0,ready,0.5%,30), total 100.0%
      Owned mutexes:
      Last reset 00:02:58 ago, cause: power up
      Last software reset at 2024-02-11 15:48, reason: User, Gcodes spinning, available RAM 8392, slot 1
      Error status: 0x04
      Aux0 errors 0,0,0
      MCU temperature: min 20.3, current 27.0, max 27.2
      Supply voltage: min 24.1, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min n/a
      Driver 1: standstill, SG min n/a
      Driver 2: standstill, SG min n/a
      Driver 3: standstill, SG min n/a
      Driver 4: standstill, SG min n/a
      Driver 5: standstill, SG min n/a
      Driver 6: standstill, SG min n/a
      Driver 7: standstill, SG min n/a
      Driver 8: standstill, SG min n/a
      Driver 9: standstill, SG min n/a
      Driver 10:
      Driver 11:
      Date/time: 2024-03-27 08:02:25
      Slowest loop: 15.30ms; fastest: 0.19ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 2.5ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, ebfmin 0.00, ebfmax 0.00
      no step interrupt scheduled
      Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
      === DDARing 0 ===
      Movement locks held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Q0 segments left 0
      Code queue 0 is empty
      === DueX ===
      Read count 1, 0.34 reads/min
      === Network ===
      Slowest loop: 15.13ms; fastest: 0.00ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      === WiFi ===
      Interface state: active
      Firmware version 2.1beta6
      MAC address ec:fa:bc:2d:df:4f
      Module reset reason: Turned on by main processor, Vcc 3.39, flash size 2097152, free heap 43068
      WiFi IP address 192.168.178.30
      Signal strength -44dBm, channel 1, mode 802.11n, reconnections 0
      Clock register 00002002
      jay_s_ukundefined droftartsundefined 3 Replies Last reply Reply Quote 0
        jay_s_uk @phoenix
        @phoenix try 2.1beta7 https://github.com/Duet3D/WiFiSocketServerRTOS/releases/tag/2.1beta7
          droftarts administrators @phoenix
          @phoenix the WiFi server version isn’t aligned to the RRF/DWC version. 3.5.0-rc3 was released with DuetWifiServer 2.1beta6, but as @jay_s_uk points out, there is a newer 2.1beta7 version that’s resolves some connection issues. I’ve been using this and haven’t had a connection failure (apart from poor WiFi signal, but that’s my WiFi location’s problem). So please try that, and report back if your connection problem persists.
          phoenixundefined 1 Reply Last reply Reply Quote 0
          • phoenixundefined
            phoenix @droftarts
            @droftarts Thank you for the pointer - I have updated it but can't see a difference.
              @phoenix said in Is my DuetWifiServer.bin properly updated?:
              Can't see a difference in the version number, or can't see a difference in operation i.e. you're still getting the error messages?
              • phoenixundefined
                phoenix @droftarts
                @droftarts Version is now showing 2.1beta7.
                No change in the behavior. It's mostly annoying when doing config work, as randomly the interfaces loses connection (and reconnects within a second), but it closes the edited config file wihtout saving obviously.
                  I notice it says it's on channel 1. This can cause problems if you're using a Duet 2 WiFi with an aerial that's built into the WiFi module PCB rather than an external one. From https://docs.duet3d.com/en/User_manual/Troubleshooting/WiFi_troubleshooting
                  Try changing the channel on your WiFi router. Most routers default to Auto, but can be set to use a fixed channel instead. The channels overlap, so it is common to use channel 1, 6 or 11. This may also help if another device is causing interference.
                  Particularly if using channel 1, change the router WiFi channel. Duets with onboard WiFi antennas may be more susceptible to interference from the Duet itself at this frequency. Try channel 6 or 11.
                    Can you try the older 1.27 release to see if the behaviour remains?
                    https://github.com/Duet3D/DuetWiFiSocketServer/releases/download/1.27/DuetWiFiServer.bin
                    • phoenixundefined
                      phoenix @Phaedrux
                      @Phaedrux Version 1.27 does not bring any relief unfortunately.
                      I understand @droftarts point - I'll change the channel to 6 or 11 on the home wifi. Crossing my fingers ! 🙂
                      • phoenixundefined
                        phoenix @phoenix
                        @Phaedrux @droftarts on Channel 13 now (Europe, and much less congested than 11 or 6).
                        I believe it's gotten slightly better, but I still see disconnects at random (frequent) intervals. If i understand you right, this is caused by EMF? Is my last resort an external antenna?
                          @phoenix Interference can certainly be an issue. Microwave ovens, cordless phones, baby monitors, or noisy electric motors (eg old fridge), so have a look a look around the immediate area to see if there's anything that could be causing it.
                          It's also worth looking at the LED on (or next to, depending on Duet 2 version) the WiFi module when it disconnects, to see if it is actually disconnecting; the LED should be on constantly when connected, but will flash when it loses connection and tries to reconnect. If it is staying on constantly while you have the error, then it may be a firmware issue.
                          To test the Duet's WiFi itself, change it to AP (Access Point) mode. You can connect directly via WiFi, and see if you get dropouts then. See https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#configuring-duet-in-wifi-access-point-mode
                          Lastly, have a look at the router. Do any other devices drop out? Some routers try and move the Duet WiFi to 5GHz, rather than 2.4GHZ, but then fall back to 2.4GHz, which might cause a disconnection/reconnection. There may be an option in the router to fix the Duet to 2.4GHz.
