    My head and extruder STOP functioning when its going to print
    366
    • JlunaMXundefined
      JlunaMX
      So whats happening is everytime I send something to 3D print the head position itself to start printing and then it just stop as well as the extruder. I have tried everything like resetting the parameters etc.. I will share my parameters below.
      ;Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Feb 19 2023 20:39:14 GMT-0500 (Eastern Standard Time)
      M550 P"O&MAKERSLAB" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P5 R1 T2.5:2.5:5:5 S1 ; physical drive 5 goes forwards (X)
      M569 P6 R1 T2.5:2.5:5:5 S0 ; physical drive 6 goes forwards (Y1)
      M569 P7 R1 T2.5:2.5:5:5 S0 ; physical drive 7 goes forwards (Y2)
      M569 P8 R1 T2.5:2.5:5:5 S1 ; physical drive 8 goes forwards (Z)
      M584 X6 Y7 Z5 E8 ; set drive mapping
      M350 X32 Y32 Z16 E16 I1 ; configure microstepping with interpolation
      M92 X21 Y21 Z320 E374.00 ; set steps per mm
      M566 X900.00 Y900.00 Z300 E120 ; set maximum instantaneous speed changes (mm/min)
      M203 X4800 Y4800 Z1800.0 E1200 ; set maximum speeds (mm/min)
      M201 X700 Y700 Z20.00 E500.00 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X708 Y694 Z700 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
      M558 P1 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P1.5 X0 Y0 Z0.1 ; set Z probe trigger value, offset and trigger height
      M557 X15:621 Y15:621 S101 ; define mesh grid
      M143 H0 S300 ; set temperature limit for heater 0 to 300C
      M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as PT1000 on pin e0temp
      M307 H1 B0 S0.50 ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S300 ; set temperature limit for heater 1 to 280C
      M308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 2 as PT1000 on pin e1temp
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      M307 H2 B0 S0.50 ; disable bang-bang mode for heater and set PWM limit
      M143 H2 S315 ; set temperature limit for heater 2 to 315C
      M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1:2 S"Typhoon" ; define tool 0
      M575 P1 B57600 S1
      T0
      ; homeall.g
      ; called to home all axes
      G91 ; relative positioning
      G1 H1 X-621 Y621 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-624 Y624 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G90 ; absolute positioning
      G1 X150 Y150 F6000
      G30
      ; homex.g
      ; called to home the X axis
      ; generated by RepRapFirmware Configuration Tool v3.4.1 on Sun Apr 07 2024 22:36:44 GMT-0400 (Eastern Daylight Time)
      G1 H1 X-1010 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 H2 X5 F6000 ; go back a few mm
      G1 H1 X-1010 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-5 F6000 ; lower Z again
      ; homey.g
      ; called to home the Y axis
      G1 H1 Y-955 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 H2 Y5 F6000 ; go back a few mm
      G1 H1 Y-955 F360 ; move slowly to Y axis endstop once more (second pass)
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Feb 19 2023 20:39:15 GMT-0500 (Eastern Standard Time)
      G1 X150 Y150 F6000
      G30
      ; bed.g
      G29 ; probe the bed and enable compensation
      I am not sure what's stopping the printer to move forward on doing the first layer and continuing to print.
      PLease take a look. any feedback would be much appreciated.
      Thanks!!
      jay_s_ukundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @JlunaMX
        @JlunaMX what firmware version are you running?
        Can you post a sample gcode?
        JlunaMXundefined 1 Reply Last reply Reply Quote 0
        • gloomyandyundefined
          gloomyandy @JlunaMX
          @JlunaMX You don't seem to be setting the motor current for your drivers with M906. What sort of drivers are you using? Also your comment on the M201 is rather odd. What sort of printer is this it seems to have very low steps/mm for X and Y?
          • Phaedruxundefined Phaedrux moved this topic from Duet Web Control
          • JlunaMXundefined
            JlunaMX @jay_s_uk
            @jay_s_uk Hey here is the sample code. it is the same I was using to print. since its too large I am gonna post the most relevant here. Which I guess is the start of the code.
            Also this is a custom mode 3D print with a build volume of: 1005x970x600 (x,y,z)
            generated by PrusaSlicer 2.7.2-alpha2+win64 on 2024-03-24 at 00:53:04 UTC
            ; external perimeters extrusion width = 1.35mm
            ; perimeters extrusion width = 1.35mm
            ; infill extrusion width = 1.35mm
            ; solid infill extrusion width = 1.35mm
            ; top infill extrusion width = 1.20mm
            ; first layer extrusion width = 1.26mm
            ;TYPE:Custom
            ; Your Printer's setting (G-code)
            M862.3 P "" ; printer model check
            M862.1 P 1.20 ; set nozzle diameter
            M115 U3.12.1 ; tell printer latest fw version
            G90 ; use absolute coordinates
            M83 ; extruder relative mode
            M104 S215 ; set extruder temp
            M140 S60 ; set bed temp
            M190 S60 ; wait for bed temp
            M109 S215 ; wait for extruder temp
            G28 ; home all without mesh bed level
            G80 ; mesh bed leveling
            ; filament priming
            G1 Z0.3 F720
            G1 Y-3 F1000 ; go outside print area
            G92 E0
            G1 X60 E9 F1000 ; intro line
            G1 X100 E12.5 F1000 ; intro line
            G92 E0
            M221 S95
            M290 Z-6.00; adjust Z by -0.02mm
            G21 ; set units to millimeters
            M82 ; use absolute distances for extrusion
            G92 E0
            ; Filament gcode
            M107
            ;LAYER_CHANGE
            ;Z:0.35
            ;HEIGHT:0.35
            G1 E-2.4 F60000
            G92 E0
            G1 Z3.35 F7800
            G1 X56.314 Y58.454
            G1 Z.35
            G1 E2.4 F60000
            ;TYPE:Skirt/Brim
            ;WIDTH:1.26
            G1 F1800
            G1 X58.195 Y56.642 E2.85032
            G1 X61.996 Y53.296 E3.72343
            G1 X65.692 Y50.31 E4.54267
            G1 X69.763 Y47.297 E5.41591
            G1 X73.962 Y44.464 E6.28926
            G1 X78.55 Y41.66 E7.21635
            G1 X82.709 Y39.361 E8.0357
            G1 X87.241 Y37.101 E8.90886
            G1 X91.867 Y35.04 E9.78204
            G1 X96.874 Y33.075 E10.70943
            G1 X101.667 Y31.438 E11.58269
            G1 X106.526 Y30.012 E12.4558
            G1 X111.444 Y28.799 E13.32916
            G1 X116.409 Y27.802 E14.2023
            G1 X121.414 Y27.022 E15.07566
            G1 X126.447 Y26.462 E15.94879
            G1 X131.5 Y26.121 E16.82199
            G1 X136.407 Y26 E17.6683
            G1 X212.763 Y25.76 E30.83343
            G1 X217.514 Y25.848 E31.65272
            G1 X222.569 Y26.157 E32.52591
            G1 X227.606 Y26.685 E33.39913
            G1 X232.615 Y27.433 E34.27234
            G1 X237.893 Y28.466 E35.19962
            G1 X242.815 Y29.66 E36.07287
            G1 X247.381 Y30.975 E36.89212
            G1 X252.479 Y32.688 E37.8194
            G1 X257.202 Y34.515 E38.69253
            G1 X261.842 Y36.546 E39.56583
            G1 X266.11 Y38.634 E40.38505
            G1 X270.561 Y41.05 E41.25824
            G1 X274.903 Y43.658 E42.13154
            G1 X279.127 Y46.453 E43.00483
            G1 X283.225 Y49.429 E43.87805
            G1 X286.539 Y52.063 E44.60794
            G1 X291.244 Y56.114 E45.67842
            G1 X294.908 Y59.61 E46.55159
            G1 X298.417 Y63.262 E47.42481
            G1 X301.561 Y66.824 E48.24397
            G1 X304.749 Y70.76 E49.11728
            G1 X307.943 Y75.087 E50.04457
            G1 X310.595 Y79.029 E50.86373
            G1 X313.242 Y83.347 E51.73698
            G1 X315.699 Y87.776 E52.61025
            G1 X317.959 Y92.308 E53.48341
            G1 X320.141 Y97.224 E54.41075
            G1 X321.985 Y101.941 E55.28398
            G1 X323.622 Y106.734 E56.15724
            G1 X325.048 Y111.594 E57.03051
            G1 X326.261 Y116.511 E57.9037
            G1 X327.258 Y121.477 E58.77701
            G1 X328.037 Y126.481 E59.65018
            G1 X328.57 Y131.202 E60.46933
            G1 X328.924 Y136.255 E61.34269
            G1 X329.057 Y141.318 E62.21594
            G1 X329.462 Y268.474 E84.1399
            G1 X329.373 Y273.381 E84.98609
            G1 X329.038 Y278.749 E85.91342
            G1 X328.496 Y283.784 E86.78655
            G1 X327.788 Y288.482 E87.60571
            G1 X326.755 Y293.761 E88.53316
            G1 X325.641 Y298.379 E89.35222
            G1 X324.246 Y303.248 E90.22549
            G1 X322.533 Y308.346 E91.15277
            G1 X320.825 Y312.78 E91.97202
            G1 X319.139 Y316.663 E92.7019
            G1 X316.587 Y321.977 E93.7183
            G1 X314.015 Y326.7 E94.64554
            G1 X311.563 Y330.77 E95.46479
            G1 X308.768 Y334.994 E96.33808
            G1 X305.792 Y339.092 E97.2113
            G1 X302.439 Y343.297 E98.13859
            G1 X299.318 Y346.879 E98.95773
            G1 X295.832 Y350.553 E99.83096
            G1 X291.959 Y354.285 E100.7583
            G1 X288.397 Y357.429 E101.57746
            G1 X284.461 Y360.617 E102.45077
            G1 X280.39 Y363.63 E103.32401
            G1 X275.928 Y366.632 E104.25125
            G1 X271.603 Y369.267 E105.12445
            G1 X267.445 Y371.566 E105.94365
            G1 X262.913 Y373.826 E106.81681
            G1 X258.286 Y375.887 E107.69015
            G1 X253.28 Y377.852 E108.61738
            G1 X248.487 Y379.489 E109.49064
            G1 X243.627 Y380.915 E110.36391
            G1 X238.71 Y382.128 E111.2371
            G1 X233.744 Y383.125 E112.11041
            G1 X228.74 Y383.905 E112.9836
            G1 X223.706 Y384.465 E113.8569
            G1 X218.653 Y384.806 E114.7301
            G1 X213.747 Y384.927 E115.57623
            G1 X137.547 Y385.168 E128.71446
            G1 X132.327 Y385.066 E129.61465
            G1 X127.584 Y384.77 E130.43401
            G1 X122.547 Y384.242 E131.30723
            G1 X117.229 Y383.44 E132.23451
            G1 X112.26 Y382.461 E133.10772
            G1 X107.642 Y381.347 E133.92678
            G1 X102.773 Y379.951 E134.8001
            G1 X97.675 Y378.239 E135.72732
            G1 X93.241 Y376.531 E136.54657
            G1 X88.596 Y374.512 E137.41983
            G1 X84.044 Y372.293 E138.29296
            G1 X79.32 Y369.721 E139.22035
            G1 X75.251 Y367.269 E140.03945
            G1 X71.027 Y364.474 E140.91274
            G1 X66.68 Y361.308 E141.83995
            G1 X62.965 Y358.346 E142.65915
            G1 X59.142 Y355.024 E143.53239
            G1 X55.245 Y351.317 E144.45974
            G1 X51.949 Y347.895 E145.27892
            G1 X48.592 Y344.103 E146.15212
            G1 X45.404 Y340.167 E147.02543
            G1 X42.21 Y335.84 E147.95272
            G1 X39.558 Y331.898 E148.77188
            G1 X36.911 Y327.58 E149.64513
            G1 X34.309 Y322.873 E150.57244
            G1 X32.194 Y318.618 E151.39171
            G1 X30.134 Y313.992 E152.26482
            G1 X28.168 Y308.986 E153.19212
            G1 X26.627 Y304.492 E154.01125
            G1 X25.188 Y299.636 E154.88449
            G1 X23.893 Y294.416 E155.81179
            G1 X22.951 Y289.759 E156.631
            G1 X22.158 Y284.757 E157.5042
            G1 X21.584 Y279.724 E158.3776
            G1 X21.215 Y274.359 E159.3048
            G1 X21.094 Y269.453 E160.15093
            G1 X20.691 Y142.453 E182.04799
            G1 X20.781 Y137.546 E182.89418
            G1 X21.089 Y132.491 E183.76736
            G1 X21.658 Y127.143 E184.69465
            G1 X22.419 Y122.136 E185.56786
            G1 X23.331 Y117.473 E186.38707
            G1 X24.513 Y112.548 E187.26034
            G1 X25.908 Y107.679 E188.13361
            G1 X27.621 Y102.581 E189.06089
            G1 X29.448 Y97.857 E189.93418
            G1 X31.479 Y93.218 E190.80732
            G1 X33.567 Y88.95 E191.62654
            G1 X35.983 Y84.499 E192.49973
            G1 X38.591 Y80.157 E193.37303
            G1 X41.564 Y75.676 E194.30021
            G1 X44.362 Y71.835 E195.11955
            G1 X46.995 Y68.521 E195.84933
            G1 X50.836 Y64.048 E196.86587
            G1 X54.322 Y60.374 E197.7391
            G1 X56.185 Y58.579 E198.18515
            ;WIPE_START
            G1 F6240
            G1 X56.314 Y58.454 E196.54432
            G1 X56.374 Y58.396 E195.78515
            ;WIPE_END
            G92 E0
            G1 X257.425 Y45.724 Z3.35 F7800
            G1 Z.35
            G1 E2.4 F60000
            ;TYPE:Perimeter
            ;WIDTH:1.26
            G1 F1800
            G1 X261.576 Y47.754 E3.1967
            G1 X265.633 Y49.964 E3.99325
            G1 X269.591 Y52.348 E4.78991
            G1 X273.441 Y54.903 E5.58659
            G1 X277.176 Y57.623 E6.38323
            G1 X280.788 Y60.503 E7.17973
            G1 X284.271 Y63.539 E7.97637
            G1 X287.619 Y66.723 E8.77298
            G1 X290.825 Y70.051 E9.56973
            G1 X293.882 Y73.515 E10.3663
            G1 X296.786 Y77.109 E11.16297
            G1 X299.53 Y80.826 E11.95956
            G1 X302.109 Y84.66 E12.75625
            G1 X304.518 Y88.602 E13.55278
            G1 X306.753 Y92.646 E14.34943
            G1 X308.81 Y96.783 E15.14603
            G1 X310.684 Y101.006 E15.94262
            G1 X312.373 Y105.307 E16.73932
            G1 X313.872 Y109.678 E17.53604
            G1 X315.179 Y114.11 E18.33273
            G1 X316.291 Y118.594 E19.12927
            G1 X317.207 Y123.123 E19.92596
            G1 X317.924 Y127.687 E20.72252
            G1 X318.442 Y132.278 E21.51911
            G1 X318.759 Y136.888 E22.31583
            G1 X318.875 Y141.539 E23.11799
            G1 X319.278 Y268.473 E45.00366
            G1 X319.256 Y269.642 E45.20525
            G1 X319.191 Y273.126 E45.80605
            G1 X318.903 Y277.737 E46.60261
            G1 X318.415 Y282.332 E47.39932
            G1 X317.727 Y286.9 E48.1958
            G1 X316.84 Y291.435 E48.99253
            G1 X315.756 Y295.926 E49.78909
            G1 X314.477 Y300.366 E50.58575
            G1 X313.006 Y304.746 E51.38239
            G1 X311.345 Y309.057 E52.17894
            G1 X309.497 Y313.292 E52.97562
            G1 X307.467 Y317.443 E53.77232
            G1 X305.257 Y321.501 E54.56902
            G1 X302.873 Y325.458 E55.36553
            G1 X300.318 Y329.308 E56.16221
            G1 X297.598 Y333.043 E56.95885
            G1 X294.717 Y336.655 E57.75546
            G1 X291.682 Y340.139 E58.55212
            G1 X288.498 Y343.486 E59.34861
            G1 X285.17 Y346.692 E60.14536
            G1 X281.706 Y349.75 E60.94204
            G1 X278.112 Y352.653 E61.7386
            G1 X274.395 Y355.397 E62.53519
            G1 X270.561 Y357.976 E63.33188
            G1 X266.619 Y360.385 E64.12841
            G1 X262.575 Y362.621 E64.92515
            G1 X258.438 Y364.677 E65.72167
            G1 X254.214 Y366.551 E66.51842
            G1 X249.914 Y368.24 E67.31495
            G1 X245.543 Y369.739 E68.11167
            G1 X241.111 Y371.046 E68.90836
            G1 X236.627 Y372.158 E69.7049
            G1 X232.098 Y373.074 E70.50159
            G1 X227.534 Y373.791 E71.29815
            G1 X222.943 Y374.309 E72.09474
            G1 X218.333 Y374.626 E72.89146
            G1 X213.682 Y374.742 E73.69362
            G1 X137.547 Y374.984 E86.82064
            G1 X132.895 Y374.897 E87.62286
            G1 X128.284 Y374.609 E88.41942
            G1 X123.689 Y374.121 E89.21613
            G1 X119.12 Y373.433 E90.01278
            G1 X114.586 Y372.546 E90.80934
            G1 X110.095 Y371.462 E91.6059
            G1 X105.655 Y370.183 E92.40256
            G1 X101.275 Y368.712 E93.1992
            G1 X96.963 Y367.051 E93.99591
            G1 X92.728 Y365.203 E94.79259
            G1 X88.578 Y363.173 E95.58914
            G1 X84.52 Y360.963 E96.38584
            G1 X80.563 Y358.579 E97.18235
            G1 X76.713 Y356.024 E97.97903
            G1 X72.978 Y353.304 E98.77567
            G1 X69.365 Y350.423 E99.57241
            G1 X65.882 Y347.388 E100.36894
            G1 X62.534 Y344.204 E101.16555
            G1 X59.329 Y340.876 E101.96218
            G1 X56.271 Y337.412 E102.75886
            G1 X53.368 Y333.818 E103.55542
            G1 X50.624 Y330.101 E104.35201
            G1 X48.045 Y326.267 E105.1487
            G1 X45.635 Y322.325 E105.94532
            G1 X43.4 Y318.281 E106.74197
            G1 X41.343 Y314.144 E107.53857
            G1 X39.469 Y309.92 E108.33532
            G1 X37.781 Y305.62 E109.13179
            G1 X36.282 Y301.249 E109.92851
            G1 X34.975 Y296.817 E110.7252
            G1 X33.863 Y292.333 E111.52174
            G1 X32.947 Y287.804 E112.31843
            G1 X32.229 Y283.24 E113.11502
            G1 X31.712 Y278.649 E113.91159
            G1 X31.395 Y274.039 E114.70831
            G1 X31.279 Y269.388 E115.51047
            G1 X30.876 Y142.454 E137.39614
            G1 X30.963 Y137.801 E138.19854
            G1 X31.25 Y133.19 E138.99509
            G1 X31.739 Y128.595 E139.79182
            G1 X32.427 Y124.027 E140.5883
            G1 X33.314 Y119.492 E141.38503
            G1 X34.398 Y115.001 E142.18159
            G1 X35.677 Y110.561 E142.97825
            G1 X37.148 Y106.181 E143.77489
            G1 X38.809 Y101.87 E144.57144
            G1 X40.656 Y97.635 E145.36805
            G1 X42.687 Y93.484 E146.16483
            G1 X44.896 Y89.426 E146.96145
            G1 X47.28 Y85.469 E147.75796
            G1 X49.835 Y81.619 E148.55464
            G1 X52.555 Y77.884 E149.35128
            G1 X55.436 Y74.272 E150.14789
            G1 X58.471 Y70.788 E150.94455
            G1 X61.656 Y67.441 E151.74116
            G1 X64.983 Y64.235 E152.53778
            G1 X68.447 Y61.177 E153.33446
            G1 X72.041 Y58.274 E154.13102
            G1 X75.759 Y55.53 E154.92775
            G1 X79.592 Y52.951 E155.72429
            G1 X83.535 Y50.542 E156.52097
            G1 X87.579 Y48.306 E157.31771
            G1 X91.716 Y46.25 E158.11423
            G1 X95.939 Y44.376 E158.91082
            G1 X100.24 Y42.687 E159.70752
            G1 X104.61 Y41.188 E160.50408
            G1 X109.042 Y39.881 E161.30077
            G1 X113.526 Y38.769 E162.09731
            G1 X118.055 Y37.853 E162.894
            G1 X122.62 Y37.136 E163.69073
            G1 X127.211 Y36.618 E164.48732
            G1 X131.82 Y36.301 E165.28387
            G1 X136.472 Y36.185 E166.0862
            G1 X212.606 Y35.943 E179.21305
            G1 X217.258 Y36.03 E180.01527
            G1 X221.87 Y36.318 E180.81201
            G1 X226.464 Y36.806 E181.60855
            G1 X231.033 Y37.494 E182.4052
            G1 X235.568 Y38.381 E183.20193
            G1 X240.059 Y39.465 E183.99849
            G1 X244.499 Y40.744 E184.79515
            G1 X248.879 Y42.215 E185.59179
            G1 X253.19 Y43.876 E186.38834
            G1 X257.26 Y45.652 E187.15398
            ;WIPE_START
            G1 F6240
            G1 X257.425 Y45.724 E185.50952
            G1 X257.499 Y45.76 E184.75398
            ;WIPE_END
            G92 E0
            G1 X257.923 Y44.648 Z3.35 F7800
            G1 Z.35
            G1 E2.4 F60000
            G1 F1800
            G1 X262.119 Y46.701 E3.20541
            G1 X266.223 Y48.935 E4.01105
            G1 X270.225 Y51.346 E4.81661
            G1 X274.118 Y53.93 E5.62223
            G1 X277.894 Y56.68 E6.42763
            G1 X281.547 Y59.593 E7.23321
            G1 X285.069 Y62.663 E8.03877
            G1 X288.455 Y65.883 E8.84441
            G1 X291.696 Y69.247 E9.64981
            G1 X294.788 Y72.75 E10.45541
            G1 X297.724 Y76.385 E11.26105
            G1 X300.498 Y80.144 E12.06654
            G1 X303.106 Y84.02 E12.87202
            G1 X305.543 Y88.006 E13.67754
            G1 X307.803 Y92.095 E14.48307
            G1 X309.883 Y96.279 E15.28869
            G1 X311.778 Y100.549 E16.09415
            G1 X313.485 Y104.899 E16.89984
            G1 X315.001 Y109.318 E17.70534
            G1 X316.322 Y113.799 E18.51081
            G1 X317.447 Y118.334 E19.31642
            G1 X318.373 Y122.913 E20.1219
            G1 X319.099 Y127.529 E20.92756
            G1 X319.622 Y132.171 E21.73298
            G1 X319.942 Y136.832 E22.53851
            G1 X320.06 Y141.523 E23.34757
            G1 X320.463 Y268.483 E45.23772
            G1 X320.441 Y269.664 E45.44138
            G1 X320.375 Y273.174 E46.04667
            G1 X320.084 Y277.837 E46.85221
            G1 X319.591 Y282.483 E47.65776
            G1 X318.894 Y287.102 E48.46317
            G1 X317.998 Y291.688 E49.26882
            G1 X316.901 Y296.229 E50.07429
            G1 X315.608 Y300.719 E50.8799
            G1 X314.121 Y305.148 E51.68542
            G1 X312.441 Y309.508 E52.49103
            G1 X310.573 Y313.79 E53.29651
            G1 X308.52 Y317.987 E54.10208
            G1 X306.286 Y322.09 E54.90757
            G1 X303.875 Y326.092 E55.71313
            G1 X301.291 Y329.985 E56.51875
            G1 X298.541 Y333.761 E57.32415
            G1 X295.628 Y337.414 E58.12973
            G1 X292.558 Y340.937 E58.93542
            G1 X289.338 Y344.322 E59.74093
            G1 X285.974 Y347.563 E60.54633
            G1 X282.471 Y350.655 E61.35193
            G1 X278.836 Y353.591 E62.15757
            G1 X275.077 Y356.365 E62.96306
            G1 X271.201 Y358.973 E63.76854
            G1 X267.215 Y361.41 E64.57406
            G1 X263.126 Y363.67 E65.37959
            G1 X258.942 Y365.75 E66.18521
            G1 X254.672 Y367.645 E66.99067
            G1 X250.322 Y369.352 E67.79636
            G1 X245.903 Y370.868 E68.60186
            G1 X241.422 Y372.19 E69.40738
            G1 X236.887 Y373.314 E70.21295
            G1 X232.308 Y374.24 E71.01843
            G1 X227.692 Y374.966 E71.82409
            G1 X223.05 Y375.489 E72.62951
            G1 X218.389 Y375.81 E73.43505
            G1 X213.698 Y375.927 E74.24411
            G1 X137.538 Y376.169 E87.37544
            G1 X132.847 Y376.081 E88.18439
            G1 X128.184 Y375.79 E88.98993
            G1 X123.538 Y375.296 E89.79549
            G1 X118.918 Y374.6 E90.60104
            G1 X114.333 Y373.703 E91.40656
            G1 X109.791 Y372.607 E92.21215
            G1 X105.302 Y371.314 E93.0176
            G1 X100.873 Y369.827 E93.82312
            G1 X96.513 Y368.147 E94.62873
            G1 X92.231 Y366.279 E95.43421
            G1 X88.034 Y364.226 E96.23978
            G1 X83.931 Y361.992 E97.04527
            G1 X79.929 Y359.581 E97.85083
            G1 X76.036 Y356.997 E98.65645
            G1 X72.259 Y354.247 E99.46199
            G1 X68.607 Y351.334 E100.26743
            G1 X65.084 Y348.264 E101.07312
            G1 X61.699 Y345.044 E101.87863
            G1 X58.457 Y341.68 E102.68415
            G1 X55.366 Y338.177 E103.48964
            G1 X52.43 Y334.542 E104.29528
            G1 X49.655 Y330.783 E105.10087
            G1 X47.047 Y326.907 E105.90635
            G1 X44.611 Y322.921 E106.71178
            G1 X42.351 Y318.832 E107.51731
            G1 X40.271 Y314.648 E108.32293
            G1 X38.376 Y310.377 E109.12855
            G1 X36.669 Y306.028 E109.93408
            G1 X35.153 Y301.609 E110.73958
            G1 X33.831 Y297.128 E111.5451
            G1 X32.706 Y292.593 E112.35071
            G1 X31.78 Y288.014 E113.15619
            G1 X31.055 Y283.398 E113.96182
            G1 X30.531 Y278.756 E114.76726
            G1 X30.211 Y274.095 E115.57279
            G1 X30.094 Y269.404 E116.38185
            G1 X29.691 Y142.444 E138.272
            G1 X29.778 Y137.753 E139.08095
            G1 X30.069 Y133.09 E139.88649
            G1 X30.563 Y128.444 E140.69205
            G1 X31.259 Y123.825 E141.49743
            G1 X32.156 Y119.239 E142.30312
            G1 X33.252 Y114.698 E143.10855
            G1 X34.545 Y110.208 E143.91416
            G1 X36.033 Y105.779 E144.71974
            G1 X37.712 Y101.419 E145.52529
            G1 X39.581 Y97.137 E146.33084
            G1 X41.634 Y92.94 E147.13641
            G1 X43.868 Y88.837 E147.9419
            G1 X46.279 Y84.835 E148.74746
            G1 X48.862 Y80.942 E149.55299
            G1 X51.613 Y77.166 E150.3585
            G1 X54.526 Y73.513 E151.16408
            G1 X57.595 Y69.99 E151.96966
            G1 X60.815 Y66.605 E152.77517
            G1 X64.18 Y63.364 E153.5807
            G1 X67.683 Y60.272 E154.3863
            G1 X71.317 Y57.336 E155.1918
            G1 X75.076 Y54.561 E155.99739
            G1 X78.952 Y51.954 E156.80278
            G1 X82.939 Y49.517 E157.60845
            G1 X87.028 Y47.257 E158.41398
            G1 X91.212 Y45.177 E159.2196
            G1 X95.482 Y43.282 E160.02506
            G1 X99.831 Y41.575 E160.83059
            G1 X104.25 Y40.059 E161.63609
            G1 X108.732 Y38.737 E162.44178
            G1 X113.266 Y37.613 E163.24718
            G1 X117.846 Y36.686 E164.05286
            G1 X122.461 Y35.961 E164.85832
            G1 X127.104 Y35.438 E165.66391
            G1 X131.765 Y35.117 E166.46945
            G1 X136.455 Y35 E167.27834
            G1 X212.615 Y34.758 E180.40967
            G1 X217.306 Y34.846 E181.21862
            G1 X221.969 Y35.137 E182.02416
            G1 X226.615 Y35.63 E182.82971
            G1 X231.235 Y36.327 E183.63529
            G1 X235.82 Y37.223 E184.44077
            G1 X240.362 Y38.32 E185.2464
            G1 X244.852 Y39.613 E186.05201
            G1 X249.281 Y41.1 E186.85753
            G1 X253.64 Y42.78 E187.66298
            G1 X257.758 Y44.576 E188.43758
            ;WIPE_START
            G1 F6240
            G1 X257.923 Y44.648 E186.79312
            G1 X257.997 Y44.684 E186.03758
            ;WIPE_END
            G92 E0
            G1 X258.42 Y43.572 Z3.35 F7800
            G1 Z.35
            G1 E2.4 F60000
            • JlunaMXundefined
              JlunaMX @gloomyandy
              @gloomyandy
              Yes, I understand. I was discussing with @Phaedrux (long time ago), and we agreed that the current steps per millimeter setting is correct. Oddly enough, when I use the calculated number, it results in inaccurate prints, which is unusual for this printer, but it seems to work fine as is. I've successfully printed several parts, including some for actual use.
              On a different note, I encountered an issue after updating the firmware on the Duet controller. Now, the printer only performs the homing process and doesn’t move at all when I try to start a print.
                gloomyandy @JlunaMX
                @JlunaMX You didn't reply to my points about not setting motor current. You do not have an M906 in your config, you do have this line:
                But M201 sets acceleration not motor current. Maybe that is causing some of your problems. What control board are you using? It seems odd that you are using drivers 5, 6, 7 and 8.
                • JlunaMXundefined
                  JlunaMX @gloomyandy
                  @gloomyandy Ohhh I got it now. Maybe thats why, COuld you send a sample code of M906.
                  And I am using 5,6,7 and 8 because I am using an expansion board.
                  gloomyandyundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                    gloomyandy @JlunaMX
                    @JlunaMX See: https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m906-set-motor-currents
                      droftarts administrators @JlunaMX
                      @JlunaMX @gloomyandy judging by this thread https://forum.duet3d.com/topic/32299/using-close-loop-encoder-for-nema-23 are you using the Duet EBoB (External Breakout Board) and external drivers? If so, you don't need to set M906 for those, as motor current is controlled by the external drivers.
                      @JlunaMX said in My head and extruder STOP functioning when its going to print:
                      Can you remember what version you were running previously, and what version are you running now? Send M115 and post the response.
                      • JlunaMXundefined
                        JlunaMX @droftarts
                        @droftarts this is my current firmware.
                        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.5.0-rc.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2024-01-24 17:56:24
                          Phaedrux Moderator @JlunaMX
                          3.5.0-rc.3
                          Can you update to 3.5.1 final?
                          https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.1
