SPI connection lost - broken DUET3 6hc ?
518
  • undefined
    IndeX4D
    hello all together,
    I installed a smaller printer with sbc and a new duet3 6 hc.
    This warning appears all the time - I changed already the raspberry pi from 5 to 3a+ and I used 3 different sd cards.
    Is the board broken???
    Crazy is: I printed 2 hours to test and then I switched off... next day I couldn´t even home my axis.
    Everything I do comes to an lost SPI connecting.
    My 2 other printers are running nicely....
    undefined 1 Reply Last reply 2 May 2024, 14:38 Reply Quote 0
    • undefined
      Does the board behave correctly in standalone mode?
      Can you share the results of M122? Enable DCS logging?
      undefined 3 Replies Last reply 3 May 2024, 16:54 Reply Quote 0
      • undefined
        chrishamm administrators @IndeX4D
        @IndeX4D You could try to replace the ribbon cable and check if that helps. Also make sure you have no other cables next to it if possible. If the same problem persists, the SPI buffers on the Duet right behind the ribbon cable might be damaged (ESD?). When and where did you purchase the 6HC?
        As to your other question: I have a Pi 5 + Debian Bookworm and that combination works perfectly fine here, I don't have any signs of SPI connection resets or TfrRdy timeouts either.
        Duet software engineer
        undefined 1 Reply Last reply 3 May 2024, 17:00 Reply Quote 0
        • undefined
          IndeX4D @Phaedrux
          @Phaedrux
          sadly the board is even restart so often that I can´t make any promps. it´s restarting very often....
          I try to print in standalone mode, now.
          • undefined
            IndeX4D @chrishamm
            @chrishamm
            I used a different (and working on other printer) Raspberry, cable for power the pi, Ribbon Cable, 3 different sd cards.
            No change.... I also used the updatet version of duetPi and the older ones which came out in january ( the experimental boomwork). Can you please tell me which I should use? Raspberry pi 5....
            ESD? The backside of the duet 6HC looks fine. Or where should i look. I also recognized, that after long power OFF, the printer is resetting in a slower way and one time I could home.
            But when I want to make a prompt, it gets worst.
            I´m going to print in standalone mode, now. I´ll report.
            I got my board a few weeks ago from Dold-Mechatronik.com
            undefined 1 Reply Last reply 3 May 2024, 19:14 Reply Quote 0
            • undefined
              IndeX4D @Phaedrux
              @Phaedrux When I try to connect with YAT .,.... not possible.
              • undefined
                Phaedrux Moderator @IndeX4D
                @IndeX4D said in SPI connection lost - broken DUET3 6hc ?:
                Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                • undefined
                  IndeX4D @Phaedrux
                  @Phaedrux
                  Edit: sorry, I haven´t seen your post. Still a case of warranty?
                  thanks
                  While DWC is ´´disconnectedt´´ , I could make a M122.
                  Strangely, after reflashing the image, the printer is starting quiet normal till the first prompts```
                  M122
                  RepRapFirmware for Duet 3 MB6HC version 3.5.1 (2024-04-19 14:30:55) running on Duet 3 MB6HC v1.02 or later (SBC mode)
                  Board ID: 08DLM-9K6R1-L83T8-6J1F6-3S46P-1FJTN
                  Used output buffers: 1 of 40 (2 max)
                  Static ram: 155208
                  Dynamic ram: 85688 of which 0 recycled
                  Never used RAM 105096, free system stack 204 words
                  Tasks: SBC(2,ready,0.3%,652) HEAT(3,nWait 6,0.0%,363) Move(4,nWait 6,0.0%,336) CanReceiv(6,nWait 1,0.0%,797) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,351) TMC(4,nWait 6,9.0%,56) MAIN(2,running,90.3%,444) IDLE(0,ready,0.4%,30), total 100.0%
                  Owned mutexes: HTTP(MAIN)
                  Last reset 00:00:33 ago, cause: power up
                  Last software reset at 2024-05-03 21:13, reason: User, Gcodes spinning, available RAM 94648, slot 0
                  Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                  Error status: 0x00
                  MCU temperature: min 43.3, current 44.3, max 44.3
                  Supply voltage: min 24.1, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                  12V rail voltage: min 12.2, current 12.3, max 12.4, under voltage events: 0
                  Events: 0 queued, 0 completed
                  Driver 0: standstill, SG min n/a, mspos 8, reads 51700, writes 11 timeouts 0
                  Driver 1: standstill, SG min n/a, mspos 8, reads 51701, writes 11 timeouts 0
                  Driver 2: standstill, SG min n/a, mspos 8, reads 51701, writes 11 timeouts 0
                  Driver 3: standstill, SG min n/a, mspos 8, reads 51701, writes 11 timeouts 0
                  Driver 4: standstill, SG min n/a, mspos 8, reads 51701, writes 11 timeouts 0
                  Driver 5: standstill, SG min n/a, mspos 8, reads 51701, writes 11 timeouts 0
                  Slowest loop: 0.21ms; fastest: 0.06ms
                  === Storage ===
                  Free file entries: 20
                  DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                  no step interrupt scheduled
                  Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                  === DDARing 0 ===
                  === DDARing 1 ===
                  Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  SBC is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Aux2 is idle in state(s) 0
                  File2 is idle in state(s) 0
                  Queue2 is idle in state(s) 0
                  Q0 segments left 0, axes/extruders owned 0x0000000
                  Code queue 0 is empty
                  Code queue 1 is empty
                  === CAN ===
                  Messages queued 166, received 928, lost 0, errs 1, boc 0
                  Longest wait 0ms for reply type 0, peak Tx sync delay 68, free buffers 50 (min 50), ts 166/165/0
                  Tx timeouts 0,0,0,0,0,0
                  === SBC interface ===
                  Transfer state: 5, failed transfers: 1, checksum errors: 4
                  RX/TX seq numbers: 1389/1303
                  SPI underruns 3, overruns 3
                  State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x253c0
                  Buffer RX/TX: 0/0-0, open files: 0
                  === Duet Control Server ===
                  Duet Control Server version 3.5.1 (2024-04-19 16:23:47, 64-bit)
                  HTTP+Executed:
                  Executing M122
                  Trigger:
                  Buffered code: M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0
                  Buffered code: M140 H0
                  Buffered code: M307 H0 R0.468 K0.275:0.000 D19.70 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
                  Buffered code: M143 H0 S120
                  Buffered code: M308 S1 P"temp1" Y"pt1000" T100000 B4138 ; configure sensor 1 as PT1000 on pin 121.temp0
                  Buffered code: M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
                  Buffered code: M307 H1 R6.672 K0.682:0.000 D2.57 E1.35 S1.00 B0 V23.3 ; disable bang-bang mode for heater and set PWM limit
                  Buffered code: M143 H1 S260
                  Buffered codes: 480 bytes total
                  Doing macro config.g, started by system
                  Code buffer space: 4096
                  Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                  Full transfers per second: 7.54, max time between full transfers: 771.1ms, max pin wait times: 257.0ms/499.8ms
                  Codes per second: 0.98
                  Maximum length of RX/TX data transfers: 3284/808
                  • undefined
                    IndeX4D
                    hey,
                    sadly I have the same Problem with the new board.
                    I tried different raspberrys.
                    It´s quiet strange that I could print 2 or 3 times. When I wanted to print next day after switch off, the printer is stuck in the error loop.
                    How can It change so crazy. Working one day, next day broke till maybe 2 hours later it´s suddenly working..?!
                    I need some help.
                    All other printers are running completely fine.
                    jay_s_ukundefined 1 Reply Last reply 7 Jan 2025, 20:39 Reply Quote 0
                      jay_s_uk @IndeX4D
                      @IndeX4D that error is nothing to do with SPI. It tells you theres an issue with the CAN connection to your other boards
                      undefined 1 Reply Last reply 7 Jan 2025, 20:42 Reply Quote 0
                      • undefined
                        IndeX4D @jay_s_uk
                        @jay_s_uk
                        ok thank you.
                        the topic is almost 0ne year old, sorry
                        Funny fact. I had to return the last board because of that problem.
                        Thanks a lot
                        Is there a way to finf out more about the problems?
                        jay_s_ukundefined 1 Reply Last reply 7 Jan 2025, 20:46 Reply Quote 0
                          jay_s_uk @IndeX4D
                          @IndeX4D i guess its a wiring issue
                          undefined 2 Replies Last reply 7 Jan 2025, 20:47 Reply Quote 0
                          • undefined
                            IndeX4D @jay_s_uk
                            @jay_s_uk
                            Probably... but between the can connections?
                            I have this expensive shielded cables...
                            let me check!
                            • undefined
                              IndeX4D @jay_s_uk
                              @jay_s_uk
                              I disconnected the can cable from the mainboard and I have still the same problem.
                              Can it still be a wiring problem. I think it can´t be?
                              jay_s_ukundefined droftartsundefined 2 Replies Last reply 7 Jan 2025, 20:52 Reply Quote 0
                                jay_s_uk @IndeX4D
                                @IndeX4D post a photo of the connection between the mainboard and the pi
                                  droftarts administrators @IndeX4D
                                  @IndeX4D For "Timeout while waiting for transfer ready pin" errors, see https://docs.duet3d.com/en/User_manual/Machine_configuration/SBC_setup#troubleshooting
                                  This error, reported in the DWC console, is usually caused by:
                                  • Other wires running too close to the ribbon cable, creating interference. Heater and motor wires can be particularly noisy, route them as far away as possible.
                                  • Ribbon cable too long, damaged or poorly connected. Check installation of ribbon cable. Ribbon cable should ideally be not longer than 150mm.
                                  • Signal reflections have been reported by one user. This may have been caused by a ribbon cable that was too long, or damaged.
