    diag LED on continuously in duet2 wifi
    335
    • R006undefined
      R006
      hey,
      I have one duet2 wifi board, which on power up , is stuck in connecting state.
      When I reset the board as per given link, the diag LED stays ON continuously, even after reset.
      Tried fall back procedure#2 as well, but no luck.
      https://docs.duet3d.com/User_manual/Troubleshooting/Duet_wont_respond
      On trying to erase & update firmware with Bossa, the flashing fails with warning as stated below during verify stage:
      Can you suggest how to find the problem with the board? Is it repairable?
      NOTE:
      1. The board was functioning fine, but suddenly stopped responding, after I removed the card & inserted again. After inserting card, board's Diag LED stayed ON.
      2. I have tried different cards, still the behaviour is same, it stays in connecting state.
      3. Diag LED stays ON continuously.
      @dc42 @Phaedrux @T3P3Tony
        droftarts administrators @R006
        @R006 Try removing the SD card, then flashing the firmware. If it flashes okay, connect via USB . What firmware are you trying to flash? Does the board show as a Bossa port in the device manager?
        I don't have any definitive answer as to why removing and replacing the card would cause this behaviour. Static shock? Something shorting out within the SD card socket? Other possible shorts on the board (metal filings bridging pins etc)? Check the SD card socket is soldered correctly, and components around it look okay.
        R006undefined 1 Reply Last reply Reply Quote 0
        • R006undefined
          R006 @droftarts
          @droftarts
          I attempted to flash the firmware without using an SD card using the BOSSA application. The flashing process was reported as successful, but during the verification phase, I encountered error "verify failed" .
          RRF 3.5.1
          YES
          but Diag LED stays ON continuously.
          droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
            @R006 What exact file are you flashing to the board?
            • R006undefined
              R006 @droftarts
              @droftarts said in diag LED on continuously in duet2 wifi:
              Duet2CombinedFirmware.bin for 3.5.1
                dc42 administrators @R006
                @R006 said in diag LED on continuously in duet2 wifi:
                Did you remove the Erase jumper after putting the board into Bossa mode but before commanding Bossa to write the file? You need to do that.
                • R006undefined
                  R006 @dc42
                  Yes.
                    Have you tried re-downloading the files and flashing again?
                    • R006undefined
                      R006 @Phaedrux
                      @Phaedrux
                      yes i am tried.
                      please give me suggestion on this what should i do?
                        @R006 Have you checked the SD card socket and the rest of the board for potential short circuits, eg metal filings? Is it fully disconnected, ie just USB is connected? Is the USB port loose, poorly soldered or broken, or possibly the cable damaged or picking up interference? It is odd that it flashes without issue, but then fails to verify.
                        Otherwise, it is possible the flash memory in the MCU has failed. When and from where did you buy the board?
                        • R006undefined
                          R006 @droftarts
                          How to i found if it's short circuited?
                          if it's short circuited so it's reparable?
                          at time of flashing it's disconnected from machine and only connected with USB
                          directly from duet.
                            @R006 This does seem like an odd failure. Let's replace it under warranty.
                            Please send an email to warranty@duet3d.com. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
