    Issue with Heater 1 Predicted Maximum Temperature Warning
    479
    • R006undefined
      R006
      hey,
      i am using Duet 2 wifi with RRF 3.5.2 rc1.
      Upon powering on the machine, I consistently encounter a warning stating that Heater 1 has reached a predicted maximum temperature of 589°C.
      Could you please provide detailed steps or recommendations for troubleshooting this specific warning?
      @dc42 @Phaedrux
        droftarts administrators @R006
        @R006 The warning message is just that, saying that the hot end heater can potentially get very hot, based on the model parameters. Not an error, but it shouldn't be ignored that you hot end heater is powerful, with the potential to melt the hot end.
        R006undefined 1 Reply Last reply Reply Quote 0
        • R006undefined
          R006 @droftarts
          @droftarts
          Ok.
          So this will not affect the printing or the machine?
          modal parameters means PID parameter?
            @R006 said in Issue with Heater 1 Predicted Maximum Temperature Warning:
            No, it's just a warning to say if you set it to a high temperature, while turning off limits such as M143 and M570, or the heater suffers from thermal runaway (possibly if there's a wiring fault), things are going to get very hot!
            R006undefined 1 Reply Last reply Reply Quote 1
            • R006undefined
              R006 @droftarts
              @droftarts
              okay,
              Is there any way to re-solved this (like electronic end)?
                @R006 Can you post the exact error message? I misread your first post, where you said:
                Heater 1 has reached a predicted ...
                The usual error message is something like:
                Warning: Heater 1 predicted maximum temperature at full power is 589°C
                Obviously these are two quite different things. You should only get the message at startup. As far as I'm aware there's no way to disable it. It's just a warning. The only way to avoid it is to fit a lower power heater, and retune the heater.
                • R006undefined
                  R006 @droftarts
                  @droftarts
                  okay
                    The warning is telling you what temperature it calculates as the maximum that could be reached in a failure condition where power was stuck on. It's up to you do mitigate that with a thermal fuse that could physically cut power to the heater when a temperature has been reached. They usually only cost a few cents and are used in everyday appliances that have heaters like kettles or toasters.
                    • R006undefined
                      R006 @Phaedrux
                      @Phaedrux @droftarts :
                      thank you for the clarification. I will try for fuse, before that I have couple of questions more:
                      1. If this warning appears, then it must appear every time for that machine or heater , right ?
                      2. Is it possible to reduce "S" value in M307, so that it never uses 100% PWM & may not cause this effect?
                      note: My concerns is to remove this warning, so that client does not mis interpret this as a problem with the extruder heating.
                        As far as I know, there's no way to remove the warning message. However, it only shows at startup, and as it is a warning, it will disappear after 5 seconds. And you will only see it on the PanelDue or in DWC if you are already connected.
                        1. Is it possible to reduce "S" value in M307, so that it never uses 100% PWM & may not cause this effect?
                        That may remove the warning (though I'm not sure it will), but then your heater will take a lot longer to heat up, as it is using less power. It also doesn't protect you from a MOSFET or wiring failure, where the hot end would receive 100% power, and hit the temperature predicted.
                        The only real way around this is to fit a less powerful heater. But then, again, it will take longer to heat up.
                        • R006undefined
                          R006 @droftarts
                          @droftarts
                          Okay,
                          I have two machine with same heater. but this warning message appears only in one machine. heater watt is 50.
                          So can i do something with its resistor value.
                          deckingmanundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                          • deckingmanundefined
                            deckingman @R006
                            @R006 If you get a warning that a heater could potentially reach a dangerous temperature, then the safest way to address this is to use a less powerful heater. Then if say a MOSFET failed, the heater would get hot, but not dangerously so.
                              @R006 Are both machines running the same firmware version? Check in config.g what the M307 command is for each heater; they are probably different. If you have M501 in config.g, also check config-override.g for M307.
                              The code for the warning is here: https://github.com/Duet3D/RepRapFirmware/blob/1f1ce4c1adbce5bc32e141a1940c697b71e02c22/src/Heating/Heater.cpp#L237
                              The firmware makes a prediction, based on M307 parameters, what the highest temperature is. If this is higher than the maximum heater temperature (set by M143) - ambient temperature, then multiplied by 1.5 plus 50, you get the warning.
                              • R006undefined
                                R006 @droftarts
                                @droftarts
                                Thank you.
                                After changing the 50W heater to a 40W heater, the warning no longer appears on one machine, but it should still be showing on the other machine. Now, I want to add a comment about this in RRF 3.4b3, but I am encountering multiple errors.
                                Building file: ../src/GPIO/GpOutPort.cpp
                                Building file: ../src/GCodes/GCodeBuffer/BinaryParser.cpp
                                Invoking: Cross G++ Compiler
                                arm-none-eabi-g++ -std=gnu++17 -D__SAME70Q20B__ -DRTOS -DDUET3_V06 -D_XOPEN_SOURCE -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\common\utils" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils\cmsis\same70\include" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\arm\CMSIS\5.4.0\CMSIS\Core\Include" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\SAME70" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils\preprocessor" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils\header_files" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\sam\drivers" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RepRapFirmware\src" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RepRapFirmware\src\Hardware\SAME70" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RepRapFirmware\src\Networking" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RepRapFirmware\src\Networking\LwipEthernet\Lwip" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RepRapFirmware\src\Networking\LwipEthernet\Lwip\src\include" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\FreeRTOS\src\include" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\FreeRTOS\src\portable\GCC\ARM_CM7\r0p1" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RRFLibraries\src" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CANlib\src" -O2 -Wall -c -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -mno-unaligned-access -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fexceptions -nostdlib -Wundef -Wdouble-promotion -Werror=return-type -Wsuggest-override -fsingle-precision-constant "-Wa,-ahl=GpOutPort.s" -fstack-usage -MMD -MP -MF"src/GPIO/GpOutPort.d" -MT"src/GPIO/GpOutPort.o" -o "src/GPIO/GpOutPort.o" "../src/GPIO/GpOutPort.cpp"
                                arm-none-eabi-g++ -std=gnu++17 -D__SAME70Q20B__ -DRTOS -DDUET3_V06 -D_XOPEN_SOURCE -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\common\utils" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils\cmsis\same70\include" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\arm\CMSIS\5.4.0\CMSIS\Core\Include" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\SAME70" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils\preprocessor" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils\header_files" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\sam\drivers" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RepRapFirmware\src" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RepRapFirmware\src\Hardware\SAME70" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RepRapFirmware\src\Networking" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RepRapFirmware\src\Networking\LwipEthernet\Lwip" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RepRapFirmware\src\Networking\LwipEthernet\Lwip\src\include" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\FreeRTOS\src\include" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\FreeRTOS\src\portable\GCC\ARM_CM7\r0p1" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RRFLibraries\src" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CANlib\src" -O2 -Wall -c -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -mno-unaligned-access -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fexceptions -nostdlib -Wundef -Wdouble-promotion -Werror=return-type -Wsuggest-override -fsingle-precision-constant "-Wa,-ahl=BinaryParser.s" -fstack-usage -MMD -MP -MF"src/GCodes/GCodeBuffer/BinaryParser.d" -MT"src/GCodes/GCodeBuffer/BinaryParser.o" -o "src/GCodes/GCodeBuffer/BinaryParser.o" "../src/GCodes/GCodeBuffer/BinaryParser.cpp"
                                ../src/Hardware/ExceptionHandlers.cpp: In function 'void SoftwareReset(SoftwareResetReason, const uint32_t*)':
                                ../src/Hardware/ExceptionHandlers.cpp:86:9: error: 'ResetProcessor' was not declared in this scope
                                Finished building: ../src/Hardware/I2C.cpp
                                86 | ResetProcessor();
                                ../src/Hardware/ExceptionHandlers.cpp: In function 'void OutOfMemoryHandler()':
                                ../src/Hardware/ExceptionHandlers.cpp:92:57: error: 'GetStackPointer' was not declared in this scope
                                92 | SoftwareReset(SoftwareResetReason::outOfMemory, GetStackPointer());
                                ../src/Hardware/ExceptionHandlers.cpp: In function 'void Terminate()':
                                ../src/Hardware/ExceptionHandlers.cpp:286:61: error: 'GetStackPointer' was not declared in this scope
                                286 | SoftwareReset(SoftwareResetReason::terminateCalled, GetStackPointer());
                                ../src/Hardware/ExceptionHandlers.cpp: In function 'void __cxa_pure_virtual()':
                                ../src/Hardware/ExceptionHandlers.cpp:296:66: error: 'GetStackPointer' was not declared in this scope
                                296 | SoftwareReset(SoftwareResetReason::pureOrDeletedVirtual, GetStackPointer());
                                ../src/Hardware/ExceptionHandlers.cpp: In function 'void __cxa_deleted_virtual()':
                                ../src/Hardware/ExceptionHandlers.cpp:301:66: error: 'GetStackPointer' was not declared in this scope
                                301 | SoftwareReset(SoftwareResetReason::pureOrDeletedVirtual, GetStackPointer());
                                Building file: ../src/GCodes/GCodeBuffer/ExpressionParser.cpp
                                ../src/Hardware/ExceptionHandlers.cpp:93:1: warning: 'noreturn' function does return
                                93 | }
                                ../src/Hardware/ExceptionHandlers.cpp:287:1: warning: 'noreturn' function does return
                                287 | }
                                ../src/Hardware/ExceptionHandlers.cpp:297:1: warning: 'noreturn' function does return
                                297 | }
                                ../src/Hardware/ExceptionHandlers.cpp: In function 'void cxa_deleted_virtual()':
                                ../src/Hardware/ExceptionHandlers.cpp:302:1: warning: 'noreturn' function does return
                                302 | }
                                make[1]: *** [src/Hardware/subdir.mk:33: src/Hardware/ExceptionHandlers.o] Error 1
                                make[1]: *** Waiting for unfinished jobs....
                                Finished building: ../src/Hardware/NonVolatileMemory.cpp
                                -DRTOS -DDUET3_V06 -D_XOPEN_SOURCE -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\common\utils" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils\cmsis\same70\include" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\arm\CMSIS\5.4.0\CMSIS\Core\Include" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\SAME70" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils\preprocessor" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\sam\utils\header_files" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CoreN2G\src\SAM4S_4E_E70\asf\sam\drivers" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RepRapFirmware\src" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RepRapFirmware\src\Hardware\SAME70" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RepRapFirmware\src\Networking" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RepRapFirmware\src\Networking\LwipEthernet\Lwip" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RepRapFirmware\src\Networking\LwipEthernet\Lwip\src\include" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\FreeRTOS\src\include" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\FreeRTOS\src\portable\GCC\ARM_CM7\r0p1" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\RRFLibraries\src" -I"C:\Users\rishita.butala\eclipse-workspace\Firmware_updatedM109\CANlib\src" -O2 -Wall -c -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -mno-unaligned-access -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fexceptions -nostdlib -Wundef -Wdouble-promotion -Werror=return-type -Wsuggest-override -fsingle-precision-constant "-Wa,-ahl=ExpressionParser.s" -fstack-usage -MMD -MP -MF"src/GCodes/GCodeBuffer/ExpressionParser.d" -MT"src/GCodes/GCodeBuffer/ExpressionParser.o" -o "src/GCodes/GCodeBuffer/ExpressionParser.o" "../src/GCodes/GCodeBuffer/ExpressionParser.cpp"
                                Finished building: ../src/Hardware/IoPorts.cpp
                                Finished building: ../src/Hardware/SoftwareReset.cpp
                                Finished building: ../src/GPIO/GpInPort.cpp
                                Finished building: ../src/GPIO/GpOutPort.cpp
                                Finished building: ../src/GCodes/GCodeBuffer/BinaryParser.cpp
                                Finished building: ../src/GCodes/GCodeBuffer/ExpressionParser.cpp
                                make: *** [makefile:98: all] Error 2
                                "make -j8 all" terminated with exit code 2. Build might be incomplete.
                                10:55:51 Build Failed. 8 errors, 8 warnings. (took 46s.991ms)
                                  Phaedrux Moderator @R006
                                  Best to start a new thread about your build errors.
