Startup Errors
I started the commissioning process on a newly modified IDEX printer. I entered M98 P"config.g" (Step #3) as per the instructions. It returned with a flood of errors that I've never gotten before. I don't know where to begin. Also including the M122 as well as the Config. I appreciate any insight that anybody is willing to give me. TYIA!
8/12/2024, 8:09:24 PM Error in start-up file macro line 90: Heater 2 does not exist 8/12/2024, 8:09:15 PM CAN response timeout: board 122, req type 6031, RID 55 Warning: Heater 0 predicted maximum temperature at full power is 321°C Warning: Discarded std reply src=121 RID=57 exp=58 "Missing sensor number" Warning: Discarded std reply src=121 RID=58 exp=59 "" Warning: Discarded std reply src=121 RID=59 exp=60 "" Warning: Discarded std reply src=121 RID=60 exp=61 "" CAN response timeout: board 122, req type 6026, RID 61 Error: Heater 2 does not exist Error: Heater 2 not found Warning: Discarded std reply src=121 RID=63 exp=64 "" Warning: Discarded std reply src=121 RID=64 exp=65 "" Warning: Discarded std reply src=121 RID=65 exp=66 "" Warning: Discarded std reply src=121 RID=66 exp=67 "" Warning: Discarded std reply src=121 RID=67 exp=68 "Miss" Warning: Discarded std reply src=121 RID=68 exp=69 "" CAN response timeout: board 122, req type 6027, RID 69 Error: Fan number 2 not found CAN response timeout: board 122, req type 6027, RID 71 Error: Fan number 3 not found Warning: Discarded std reply src=121 RID=73 exp=74 "" Warning: Discarded std reply src=121 RID=74 exp=75 "" Warning: Discarded std reply src=121 RID=75 exp=76 "" 8/12/2024, 8:09:14 PM CAN response timeout: board 122, req type 6031, RID 55 Warning: Heater 0 predicted maximum temperature at full power is 321°C Warning: Discarded std reply src=121 RID=57 exp=58 "Missing sensor number" Warning: Discarded std reply src=121 RID=58 exp=59 "" Warning: Discarded std reply src=121 RID=59 exp=60 "" Warning: Discarded std reply src=121 RID=60 exp=61 "" CAN response timeout: board 122, req type 6026, RID 61 Error: Heater 2 does not exist Error: Heater 2 not found Warning: Discarded std reply src=121 RID=63 exp=64 "" Warning: Discarded std reply src=121 RID=64 exp=65 "" Warning: Discarded std reply src=121 RID=65 exp=66 "" Warning: Discarded std reply src=121 RID=66 exp=67 "" Warning: Discarded std reply src=121 RID=67 exp=68 "Miss" Warning: Discarded std reply src=121 RID=68 exp=69 "" CAN response timeout: board 122, req type 6027, RID 69 Error: Fan number 2 not found CAN response timeout: board 122, req type 6027, RID 71 Error: Fan number 3 not found Warning: Discarded std reply src=121 RID=73 exp=74 "" Warning: Discarded std reply src=121 RID=74 exp=75 "" Warning: Discarded std reply src=121 RID=75 exp=76 "" 8/12/2024, 8:09:14 PM Connection established 8/12/2024, 8:09:14 PM Connection interrupted, attempting to reconnect... Operation failed (Reason: Service Unavailable) 8/12/2024, 8:09:12 PM CAN response timeout: board 120, req type 6031, RID 51 Warning: Discarded std reply src=121 RID=53 exp=54 "" Warning: Discarded std reply src=121 RID=54 exp=55 "" CAN response timeout: board 122, req type 6031, RID 55 Warning: Heater 0 predicted maximum temperature at full power is 321°C Warning: Discarded std reply src=121 RID=57 exp=58 "Missing sensor number" Warning: Discarded std reply src=121 RID=58 exp=59 "" Warning: Discarded std reply src=121 RID=59 exp=60 "" Warning: Discarded std reply src=121 RID=60 exp=61 "" CAN response timeout: board 122, req type 6026, RID 61 Error: Heater 2 does not exist Error: Heater 2 not found Warning: Discarded std reply src=121 RID=63 exp=64 "" Warning: Discarded std reply src=121 RID=64 exp=65 "" Warning: Discarded std reply src=121 RID=65 exp=66 "" Warning: Discarded std reply src=121 RID=66 exp=67 "" Warning: Discarded std reply src=121 RID=67 exp=68 "Miss" Warning: Discarded std reply src=121 RID=68 exp=69 "" CAN response timeout: board 122, req type 6027, RID 69 Error: Fan number 2 not found 8/12/2024, 8:09:11 PM Connection established 8/12/2024, 8:09:11 PM Connection interrupted, attempting to reconnect... Operation failed (Reason: Service Unavailable) 8/12/2024, 8:09:10 PM ype 6043, RID 43 Warning: Discarded std reply src=121 RID=44 exp=45 "" CAN response timeout: board 122, req type 6042, RID 45 Warning: Discarded std reply src=121 RID=46 exp=47 "" Warning: Discarded std reply src=121 RID=47 exp=48 "" Warning: Discarded std reply src=121 RID=48 exp=49 "" Warning: Discarded std reply src=121 RID=49 exp=50 "" CAN response timeout: board 120, req type 6060, RID 50 CAN response timeout: board 120, req type 6031, RID 51 Warning: Discarded std reply src=121 RID=53 exp=54 "" Warning: Discarded std reply src=121 RID=54 exp=55 "" CAN response timeout: board 122, req type 6031, RID 55 Warning: Heater 0 predicted maximum temperature at full power is 321°C Warning: Discarded std reply src=121 RID=57 exp=58 "Missing sensor number" Warning: Discarded std reply src=121 RID=58 exp=59 "" Warning: Discarded std reply src=121 RID=59 exp=60 "" Warning: Discarded std reply src=121 RID=60 exp=61 "" 8/12/2024, 8:09:09 PM Connection established 8/12/2024, 8:09:09 PM Connection interrupted, attempting to reconnect... Operation failed (Reason: Service Unavailable) 8/12/2024, 8:09:07 PM CAN response timeout: board 122, req type 6042, RID 39 Warning: Discarded std reply src=121 RID=40 exp=41 "" CAN response timeout: board 122, req type 6042, RID 41 Warning: Discarded std reply src=121 RID=42 exp=43 "" CAN response timeout: board 122, req type 6043, RID 43 Warning: Discarded std reply src=121 RID=44 exp=45 "" CAN response timeout: board 122, req type 6042, RID 45 Warning: Discarded std reply src=121 RID=46 exp=47 "" Warning: Discarded std reply src=121 RID=47 exp=48 "" Warning: Discarded std reply src=121 RID=48 exp=49 "" Warning: Discarded std reply src=121 RID=49 exp=50 "" CAN response timeout: board 120, req type 6060, RID 50 CAN response timeout: board 120, req type 6031, RID 51 Warning: Discarded std reply src=121 RID=53 exp=54 "" Warning: Discarded std reply src=121 RID=54 exp=55 "" 8/12/2024, 8:09:06 PM Connection established 8/12/2024, 8:09:06 PM Connection interrupted, attempting to reconnect... Operation failed (Reason: Service Unavailable) 8/12/2024, 8:09:05 PM CAN response timeout: board 122, req type 6042, RID 39 Warning: Discarded std reply src=121 RID=40 exp=41 "" CAN response timeout: board 122, req type 6042, RID 41 Warning: Discarded std reply src=121 RID=42 exp=43 "" CAN response timeout: board 122, req type 6043, RID 43 Warning: Discarded std reply src=121 RID=44 exp=45 "" CAN response timeout: board 122, req type 6042, RID 45 Warning: Discarded std reply src=121 RID=46 exp=47 "" Warning: Discarded std reply src=121 RID=47 exp=48 "" Warning: Discarded std reply src=121 RID=48 exp=49 "" Warning: Discarded std reply src=121 RID=49 exp=50 "" CAN response timeout: board 120, req type 6060, RID 50 8/12/2024, 8:09:04 PM Connection established 8/12/2024, 8:09:04 PM Connection interrupted, attempting to reconnect... Operation failed (Reason: Service Unavailable) 8/12/2024, 8:09:02 PM CAN response timeout: board 122, req type 6042, RID 39 Warning: Discarded std reply src=121 RID=40 exp=41 "" CAN response timeout: board 122, req type 6042, RID 41 Warning: Discarded std reply src=121 RID=42 exp=43 "" CAN response timeout: board 122, req type 6043, RID 43 Warning: Discarded std reply src=121 RID=44 exp=45 "" 8/12/2024, 8:09:01 PM Connection established 8/12/2024, 8:09:01 PM Connection interrupted, attempting to reconnect... Operation failed (Reason: Service Unavailable) 8/12/2024, 8:09:00 PM CAN response timeout: board 122, req type 6018, RID 37 Warning: Discarded std reply src=121 RID=38 exp=39 "" 8/12/2024, 8:08:58 PM CAN response timeout: board 122, req type 6034, RID 35 Warning: Discarded std reply src=121 RID=36 exp=37 "" 8/12/2024, 8:08:57 PM Warning: Discarded std reply src=121 RID=33 exp=34 "" Warning: Discarded std reply src=121 RID=34 exp=35 "" ; Configuration file for RepRapFirmware on Duet 3 Mini 5+ WiFi ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.5.4 on Sat Aug 10 2024 17:00:36 GMT-0400 (Eastern Daylight Time) ; General G90 ; absolute coordinates M83 ; relative extruder moves M550 P"M3ID V2" ; set hostname ; Accessories M575 P1 S0 B57600 ; configure PanelDue support ; Network M552 S1 ; configure WiFi adapter M586 P0 S1 ; configure HTTP ; Wait a moment for the CAN expansion boards to become available G4 S2 ; Accelerometers M955 P121.0 I20 ; configure accelerometer on board #121 M955 P122.0 I20 ; configure accelerometer on board #122 ; Smart Drivers M569 P0.1 S1 D2 ; driver 0.1 goes forwards (X axis) M569 P0.2 S1 D2 ; driver 0.2 goes forwards (Y axis) M569 P0.3 S1 D2 ; driver 0.3 goes forwards (Z axis) M569 P0.4 S1 D2 ; driver 0.4 goes forwards (U axis) M569 P121.0 S1 D2 ; driver 121.0 goes forwards (extruder 0) M569 P122.0 S1 D2 ; driver 122.0 goes forwards (extruder 1) ; Motor Idle Current Reduction M906 I30 ; set motor current idle factor M84 S30 ; set motor current idle timeout ; Axes M584 X0.1 Y0.2 Z0.3 U0.4 ; set axis mapping M350 X16 Y16 Z16 U16 I1 ; configure 16X microstepping with interpolation M906 X1750 Y1750 Z800 U1750 ; set axis driver currents M92 X80 Y80 Z400 U80 ; configure steps per mm M208 X-6:220 Y-9:250 Z0:200 U0:229 ; set minimum and maximum axis limits M566 X900 Y900 Z12 U900 ; set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z180 U6000 ; set maximum speeds (mm/min) M201 X500 Y500 Z20 U500 ; set accelerations (mm/s^2) ; Extruders M584 E121.0:122.0 ; set extruder mapping M350 E16:16 I1 ; configure microstepping with interpolation M906 E424:424 ; set extruder driver currents M92 E2682:2682 ; configure steps per mm M566 E150:150 ; set maximum instantaneous speed changes (mm/min) M203 E3600:3600 ; set maximum speeds (mm/min) M201 E3000:3000 ; set accelerations (mm/s^2) ; Kinematics M669 K0 ; configure Cartesian kinematics ; BLtouch M558 K0 P9 C"121.io0.in" H5 F120 T6000 A2 ; configure BLTouch probe via slot #0 G31 P500 X0 Y24 Z0.7 ; set Z probe trigger value, offset and trigger height M950 S0 C"121.io0.out" ; create servo #0 for BLtouch ; Scanning Z probe M558 K1 P11 C"120.i2c.ldc1612" F36000 T36000 M308 A"SZP coil" S10 Y"thermistor" P"120.temp0" ; thermistor on coil ; Endstops M574 X1 P"io1.in" S1 ; configure X axis endstop M574 Y1 P"io2.in" S1 ; configure Y axis endstop M574 Z1 S2 ; configure Z axis endstop M574 U1 P"io4.in" S1 ; configure U axis endstop ; Mesh Bed Compensation M557 X25:175 Y25:175 S40:40 ; define grid for mesh bed compensation ; Sensors M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0 M308 S1 P"121.temp0" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor #1 M308 S2 P"122.temp0" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor #2 ; Heaters M950 H0 C"out0" T0 ; create heater #0 M143 H0 P0 T0 C0 S120 A0 ; configure heater monitor #0 for heater #0 M307 H0 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #0 M950 H1 C"121.out0" T1 ; create heater #1 M143 H1 P0 T1 C0 S300 A0 ; configure heater monitor #0 for heater #1 M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1 M950 H2 C"122.out0" T2 ; create heater #2 M143 H2 P0 T1 C0 S300 A0 ; configure heater monitor #0 for heater #2 M307 H2 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #2 ; Heated beds M140 P0 H0 ; configure heated bed #0 ; Fans M950 F0 C"121.out2" ; create fan #0 T0 Heat Sink Fan M106 P0 S0 B0.1 H1 T45 ; configure fan #0 T0 Heat Sink Fan M950 F1 C"121.out1" ; create fan #1 T0 Part Cooling fan M106 P1 S0 L0 X1 B0.1 ; configure fan #1 T0 Part Cooling Fan M950 F2 C"122.out2" ; create fan #2 T1 Heat Sink Fan M106 P2 S0 B0.1 H2 T45 ; configure fan #2 T1 Heat Sink Fan M950 F3 C"122.out1" ; create fan #3 T1 Part Cooling Fan M106 P3 S0 L0 X1 B0.1 ; configure fan #3 T1 Part Cooling Fan ; Tools M563 P0 D0 H1 F0 ; create tool #0 T0 M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C M563 P1 D1 H2 F2 ; create tool #1 T1 M568 P1 R0 S0 ; set initial tool #1 active and standby temperatures to 0C ; Miscellaneous T0 ; select first tool M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.2 (2024-06-11 17:14:16) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: ZBVGS-QP6KL-K65J0-409N0-NK02Z-HT6JA Used output buffers: 3 of 40 (40 max) Error in macro line 90 while starting up: Heater 2 does not exist === RTOS === Static ram: 103368 Dynamic ram: 122176 of which 248 recycled Never used RAM 12768, free system stack 188 words Tasks: NETWORK(2,nWait 7,18.4%,203) HEAT(3,nWait 6,0.0%,350) Move(4,nWait 6,0.0%,355) CanReceiv(6,nWait 1,0.1%,796) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,0.8%,101) MAIN(1,running,78.6%,665) IDLE(0,ready,1.2%,29) AIN(4,delaying,0.9%,259), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:08:25 ago, cause: power up Last software reset at 2024-08-12 14:57, reason: User, Gcodes spinning, available RAM 12532, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 505579, completed 505579, timed out 0, errs 0 MCU temperature: min 29.8, current 30.2, max 30.9 Supply voltage: min 24.1, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/36/0, gc cycles 0 Events: 3 queued, 3 completed Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 10, reads 21137, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 16, reads 21134, writes 3, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 16, reads 21134, writes 3, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 16, reads 21133, writes 3, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 16, reads 21134, writes 3, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2024-08-12 20:14:45 Cache data hit count 982879655 Slowest loop: 2002.25ms; fastest: 0.13ms === Storage === Free file entries: 20 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 0.9ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 3658, received 15885, lost 228, errs 0, boc 0 Longest wait 1ms for reply type 6034, peak Tx sync delay 6, free buffers 26 (min 25), ts 2008/2008/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 21.63ms; fastest: 0.06ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1.0 MAC address e8:68:e7:e1:4e:33 Module reset reason: Power up, Vcc 3.34, flash size 2097152, free heap 42952 WiFi IP address 192.168.1.163 Signal strength -57dBm, channel 2, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0 -
What all do you have connected for canbus hardware?
@SonnyD1 I suspect that the boards at CAN addresses 121 and 122 are running older firmware than your Mini5+. Use M115 B120 and M115 B121 to check. The Machine Specific page of DWC should also tell you the software versions.
@Phaedrux
T0 - Heater, Thermistor, BLTouch, Duet Z Scanner, Part cool fan, Heat sinc fan, stepper motor, and E3D filament runout sensor and action button.
T1 - Heater, Thermistor, Part cool fan, heat sinc fan, stepper, and E3D filament runout and action button.Roto Extruder on a Roto Toolboard.
Reply from M115 B121 and 122 below:
8/13/2024, 1:57:03 PM CAN response timeout: board 122, req type 6024, RID 39
8/13/2024, 1:57:01 PM M115 B122
Warning: Discarded std reply src=121 RID=38 exp=39 "Duet TOOL1RR firmware version 3.5.2 (2024-06-10 13:24:08)"
8/13/2024, 1:56:56 PM M115 B121
Duet TOOL1RR firmware version 3.5.2 (2024-06-10 13:24:08)It does not show the 122 in the Machine Specific. So I'm assuming that all of the hardware that is connected to board 122 is what is causing a lot of the errors. Question is, why isn't it reading 122? The LEDs on the board are all doing what they should.
Has that board ever responded?
@Phaedrux Not that I am aware of, no.
Can you go through the steps of resetting that boards and setting it up as if it were the single and only tool board?
@Phaedrux How would I do that? What If I physically swap the 121 and 122 boards? I assume you're trying to confirm that the board works.
@Phaedrux What if I physically swap the two boards? And then I swap every reference to 121 and 122 in the config. If 122 works then, it's likely a wiring issue. If it doesn't then it's the board. Does what I'm saying track?
Can you go through the commissioning steps on that board and do a factory reset as described here?
https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Toolboard_1LC#commissioning
@Phaedrux YEEESSSSS!!!!. Ok now I feel like I wasted your time. Now that its fixed, I see what the issue was. In my defense, I've never configured IDEX Toolboards before. I disconnected the 121 board; reset the 122 board; reassigned the new board number of 122 and turned off the machine. On reset the new error was showing that it was unable to find the 121 board (because it was still disconnected). I confirmed with M115 B122 that it was reading the board, turned off the machine, reconnected the 121 board and turned it back on. Now it reads them both with far less errors. I must have a reference to 120 in my config that I need to fix since I don't have a 120. Now my reply from M98 is:
8/17/2024, 10:49:17 AM CAN response timeout: board 120, req type 6060, RID 50 CAN response timeout: board 120, req type 6031, RID 51 Warning: Heater 0 predicted maximum temperature at full power is 321°C 8/17/2024, 10:49:11 AM M98 P"config.g" HTTP is enabled on port 80 M122:
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.2 (2024-06-11 17:14:16) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: ZBVGS-QP6KL-K65J0-409N0-NK02Z-HT6JA Used output buffers: 3 of 40 (28 max) === RTOS === Static ram: 103368 Dynamic ram: 122628 of which 80 recycled Never used RAM 15340, free system stack 194 words Tasks: NETWORK(2,nWait 7,13.9%,213) HEAT(3,nWait 6,0.0%,350) Move(4,nWait 6,0.0%,355) CanReceiv(6,nWait 1,0.1%,796) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,0.8%,101) MAIN(1,running,83.2%,665) IDLE(0,ready,1.1%,29) AIN(4,delaying,0.9%,259), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:09:25 ago, cause: power up Last software reset at 2024-08-12 14:57, reason: User, Gcodes spinning, available RAM 12532, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 565903, completed 565903, timed out 0, errs 0 MCU temperature: min 28.8, current 33.0, max 33.2 Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 2 queued, 2 completed Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 10, reads 29756, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 16, reads 29750, writes 16, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 16, reads 29750, writes 16, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 16, reads 29749, writes 16, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 16, reads 29750, writes 16, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2024-08-17 10:51:43 Cache data hit count 1103314026 Slowest loop: 2006.54ms; fastest: 0.15ms === Storage === Free file entries: 20 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 10.3ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 5155, received 22544, lost 47, errs 0, boc 0 Longest wait 1ms for reply type 6034, peak Tx sync delay 6, free buffers 26 (min 25), ts 2830/2829/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 1921.82ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1.0 MAC address e8:68:e7:e1:4e:33 Module reset reason: Power up, Vcc 3.35, flash size 2097152, free heap 42956 WiFi IP address 192.168.1.163 Signal strength -62dBm, channel 2, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0 Now I can continue on with the rest of the commissioning process to clear out the rest of the errors. If you see anything else, please don't hesitate to let me know. Thank you for your time and patience.
@Phaedrux Yup, I found the 120 error. For some reason my config.g had the z scanner connected to a 120 board. I must have screwed it up when I was configuring.
undefined Phaedrux marked this topic as a question 18 Aug 2024, 17:15
undefined Phaedrux has marked this topic as solved 18 Aug 2024, 17:15
