    uniform wave artifact on all prints
    441
    • alexusundefined
      alexus
      hey all
      edges of all my prints have strange waves (see pix) they all unoform and looks like wave is formed on z moves.. since they iniform and thoughout whole part i have no idea what causes them
      part on photos has straight wall perpendicular to build plate and wave os parallel to build plate (xy)
      i canged material it got little better but still there...
      any idea how to fix it or what causes it?
      i have 3 axis on Z with lead screws, and regular belt XY
      IMG_7396.HEIC
      IMG_7395.HEIC
      jay_s_ukundefined Notepadundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @alexus
        @alexus is your bed heater set to bang bang or pid?
        alexusundefined 1 Reply Last reply Reply Quote 0
        • alexusundefined
          alexus @jay_s_uk
          @jay_s_uk
          if i read my settings correctly i think extruder is PWM and heatbed is bid bang?
          here are settings
          M140 H-1                                      ; disable heated bed (overrides default heater mapping) - enabled Alexus 12.8.23
          M308 S0 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e0temp
          M950 H0 C"e0heat" T0                          ; create nozzle heater output on e0heat and map it to sensor 0
          M307 H0 R8.944 K0.806:0.000 D1.44 E1.35 S1.00 B0 V24.2
          M307 H0 B0 S1.00                              ; disable bang-bang mode for heater  and set PWM limit
          M143 H0 S300                                  ; set temperature limit for heater 0 to 280C
          ;add heatbed sensor and heaters
          M308 S1 P"bedtemp" Y"thermistor" T11000 B4138 ; configure sensor 1 as for heatbed
          M950 H1 C"bedheat" T1                          ; create bed heater output on bedheat and map it to sensor 1
          M307 H1 R0.072 K0.332:0.000 D33.57 E1.35 S1.00 B0      ; auto tune settings
          M140 H1                                        ; map heated bed to heater 1
          M143 H1 S120                                   ; set temperature limit for heater 1 to 120C
          though not sure how it related to heat bed? as all part top to bottom has same artifact even when far away form bed
          • Notepadundefined
            Notepad @alexus
            @alexus
            This might sound weird, but loosen all the bolts that hold the z lead screws onto the bed.
            Make it so you can manually wiggle the threaded nuts and then try printing again. Obviously you dont want to print like this in the future, but doing a test print like this is a really good test to check if the issue is firmware or if its hardware.
            The real bamboo printer manufacturer
            infiniteloopundefined 1 Reply Last reply Reply Quote 0
            • infiniteloopundefined
              infiniteloop @Notepad
              @Notepad said in uniform wave artifact on all prints:
              Just curious: what hardware issue exactly can you determine (or exclude) by this?
              Notepadundefined 1 Reply Last reply Reply Quote 0
              • Notepadundefined
                Notepad @infiniteloop
                @infiniteloop
                There are really 2 possible reasons for it.
                1. The z nuts are mounted slightly off axis, causing the z motion to be non linear. the spacing of the "wave artifact" looks consistent. If you measure peak to peak, I would be interested to see what the distance is, it may be 4mm spacings which would line up with the thread pitch of a T4 or T8 threaded rod.
                2. The Threaded Z rod could be imparting force against the bed or frame causing either to flex slightly
                There are a couple sub reasons, but most of it is a faint hunch from past experience ive had.
                If it does fix the issue, I'm happy to send you some info about how to design around it / eliminate the issue with some hardware tweaks.
                Sneaky edit: for future posting, i would recommend converting your .heic files which iphone uses as default to something else. Windows11 PCs now need users to pay to view them, so some newer users might not be able to open them
                • alexusundefined
                  alexus @Notepad
                  @Notepad
                  HEIVEC - yea iphone makes things harder
                  my rods are 1605 fairly large and heavy byt yes interestingly enough distance form same repeate line is exactly 5mm (manual not scientific measurement though i can grab microscope ) so is full spin on 1605 gives us 5mm we can relate to that but i dont see how especially that there 3Z bolts and tables sits on ball baring pillows ... well unless its uneven pressure some how
                  i will try to loosen both belts that drive rods and loosen pillows and print cube wase or something (unfortunately im out of grey material that was showing artifact very well)
                    Can you share a photo of your Z axis arrangement?
                    If you turn off the bed heater, do you get the same pattern? Just to rule out the bed heater.
                    • alexusundefined
                      alexus @Phaedrux
                      @Phaedrux
                      here is build pix
                      i will try to turn off heater... shodl i fully turn it off in confog file... or just deactivating in GUI can be ok for test?
                      also i troed to loosen pillows and belts on Z and i dont think it made difference,,, i also increased print speed
                      Phaedruxundefined Notepadundefined 2 Replies Last reply Reply Quote 0
                        Phaedrux Moderator @alexus
                        @alexus said in uniform wave artifact on all prints:
                        Just turn it off after the first couple layers
                        • alexusundefined
                          alexus @Phaedrux
                          @Phaedrux
                          i turned heated in GUI for full build and waves still there
                            That leaves your Z axis mechanism. Maybe a ball screw is bent or binding.
                            Can you post your full config.g?
                            • alexusundefined
                              alexus @Phaedrux
                              @Phaedrux
                              will load file tomorrow, alredy left office
                              bent scew kinda unlikely, 16mm diameter not that easy to bend, also if one is bent it needs to drug 2 others which is harder, and finally if its bent in certain section should artifact change over part height? caz lines stay uniform top to bottom
                              im thinking to disable mesh compensation and see what happens
                              • Notepadundefined
                                Notepad @alexus
                                @alexus
                                OH THESE ARE BALL SCREWS.
                                I am now 100% certain that the issue is with the alignment of the ball screws. The main issue with ball screws is that they are so well manufactured, the steel used is also exceedingly hard meaning any deviation in the alignment of the rods will cause the frame and bed of the printer to warp ever so slightly.
                                I have made about a dozen machines using various ball screws including ones integrated directly into the motor (as i though the issue of non concentric pulleys might have been the cause of issues exactly like yours) to no avail.
                                Thankfully there is a perfect product for you that is relatively inexpensive that should remove any XY impact caused by the z-motion system
                                https://www.aliexpress.com/item/1005004227149356.html - the YouTuber who designed these only made a deal with mellow, so i suggest getting them from there in the size "WS16"
                                Any other oldham coupling should also work, but I have had the best experience from the wobbleX's
                                alexusundefined 2 Replies Last reply Reply Quote 1
                                • alexusundefined
                                  alexus @Notepad
                                  @Notepad
                                  u have some part coming form china now will add it to order and see what happens... i guess i can also make loose ball screw on top that would allow it to be more flexible
                                  • alexusundefined
                                    alexus @Notepad
                                    WS16
                                    ok so i loosened lead screws and waves got even woth so i think i need to work in makeing sure build plate is stable... 😞 before is did 3Z itwas perrry well i guess let me play with mechanincs and try that adapter too
                                    tnx for leading me to right direction
