    Part Cooling Fan on Duex5
    464
    • alexusundefined
      alexus @droftarts
      @droftarts said in Part Cooling Fan on Duex5:
      ; Fan 0 - print cooling
      M950 F0 C"duex.fan3" Q500 ; create fan 0 on pin fan0 and set its frequency //10.25.2024 - Used to be "fan0"
      M106 P0 S0 H0 ; set value. Thermostatic control is turned off /S-speed 1==100%
      ; Fan 1 - ToolHeatsink Cooler
      M106 P1 T36 H1 ; set fan P1 value. Thermostatic control is turned ON for sensor 0 (S0 in M308) H0
      M563 P0 D0 H0 F0 ; define tool 0 (asign F0 as part cooling fan.. used to be F-1)
      yea i think thats what i want 🙂
      • alexusundefined
        alexus @droftarts
        @droftarts
        so debuging futher to hardware level now
        on GUI ive set fan 40% and VIN shows i have 24V on Duet2 board,....
        when i measure voltage on Duex5 Fan3 port i get nothing there while Duex5 VIN has 24v measured, also Fan jumper is set to VIN
        what could be wrong here? i tried fan speed 100% and no change
          Have you verified the fan works by connecting it to an always on fan port?
          If the fan does work, Ttry a different duex fan port?
          If it works there, perhaps the mosfet on the original port is damaged.
          alexusundefined 1 Reply Last reply Reply Quote 0
          • alexusundefined
            alexus @Phaedrux
            @Phaedrux which port is always on? also whats output voltage?
              The Duet mainboard has 2 always on fans. Voltage depends on what position you have set the fan voltage jumper. Either 5v or VIN.
              https://docs.duet3d.com/duet_boards/duet_2_wifi_ethernet_maestro/duet_2_we_wiring_latest.png
              alexusundefined 3 Replies Last reply Reply Quote 0
              • alexusundefined
                alexus @Phaedrux
                @Phaedrux
                heh yea i just looked up documentation and yes always on worjs so we know fan works lol
                well let me try to assign say fan4 port see what happens
                • alexusundefined
                  alexus @Phaedrux
                  @Phaedrux
                  nope fun4 does not work either 😞
                  • alexusundefined
                    alexus @Phaedrux
                    @Phaedrux
                    interesting observation: when i disconnected tthermistor part cooling starts to spin on duex.fan4 port though speed control does not work. So port should be operable
                      droftarts administrators @alexus
                      @alexus Can you post your current config.g, in full? I think there's a configuration error. Also what firmware are you using; post the response to M122.
                      • alexusundefined
                        alexus @droftarts
                        @droftarts
                        well i kinda gave up and used configuration tool and extracted code related to fan and heater and it started to work majically so i think problem was some where in letter configuration lol
                        so now it looks like it wokring for fan parts at least 🙂
