    Part Cooling Fan on Duex5
    464
    • alexusundefined
      alexus @jay_s_uk
      @jay_s_uk
      handg on... when i select tool i see GUI changes
      Tool fan is that's a part cooling fan?
      if so i guess it shows up and now i need to test electrical why it does not spin
        jay_s_uk @alexus
        @alexus I've just noticed a mistake on line 7 of your first post. It should be P1 and not P0.
        But yes, essentially the tool fan is the part cooling fan of the active tool.
        alexusundefined 1 Reply Last reply Reply Quote 0
        • alexusundefined
          alexus @jay_s_uk
          @jay_s_uk
          if i cange to P1 i ger error
          Error in start-up file macro line 103: Fan number 1 not found
          assuming u meant to figuration like this?
          ; Fan 0 -  print cooling
          M950 F0 C"duex.fan3" Q500                             ; create fan 0 on pin fan0 and set its frequency //10.25.2024 - Used to be "fan0"
          M106 P1 S1 H1                                    ; set value. Thermostatic control is turned off /S-speed 1==100%
          ; Fan 1 - ToolHeatsink Cooler
          M950 F1 C"fan1" Q500                            ; create fan 1 on pin fan1 and set its frequency
          M106 P0 T36 H0                               ; set fan P1 value. Thermostatic control is turned ON for sensor 0 (S0 in M308) H0
          M563 P0 D0 H0 F0                             ; define tool 0 (asign F0 as part cooling fan.. used to be F-1)
          G10 P0 X0 Y0 Z0                               ; set tool 0 axis offsets
          G10 P0 R0 S0                                  ; set initial tool 0 active and standby temperatures to 0C
          droftartsundefined 2 Replies Last reply Reply Quote 0
            droftarts administrators @alexus
            @alexus P0 on line 4, P1 on line 7.
            • alexusundefined
              alexus @droftarts
              @droftarts
              ok so like this and GUI shows "Tool Fan" as name
              M106 P0 S1 H1                                    ; set value. Thermostatic control is turned off /S-speed 1==100%
              M106 P1 T36 H0                               ; set fan P1 value. Thermostatic control is turned ON for sensor 0 (S0 in M308) H0
                @alexus said in Part Cooling Fan on Duex5:
                See https://docs.duet3d.com/en/User_manual/Connecting_hardware/Fans_connecting#thermostatically-controlled-fans
                The convention is that Fan 0 is the part cooling fan (or tool fan) and Fan 1 is the thermostatic fan for the hot end. Though it actually doesn't matter too much which way around you do it, but most importantly:
                Note: thermostatic fans SHOULD NOT be mapped to tools.
                Currently, you have Fan 0 (F0) as thermostatic with H1, and Fan 1 (F1) as not thermostatic (H0), and have F0 mapped to your tool:
                You initially said you wanted the part cooling fan on the Duex, so I would guess what you actually want is:
                M106 P0 S0 H0                                    ; set value. Thermostatic control is turned off /S-speed 1==100%
                M106 P1 T36 H1                               ; set fan P1 value. Thermostatic control is turned ON for sensor 0 (S0 in M308) H0
                alexusundefined 2 Replies Last reply Reply Quote 0
                • alexusundefined
                  alexus @droftarts
                  @droftarts said in Part Cooling Fan on Duex5:
                  yea i think thats what i want 🙂
                  • alexusundefined
                    alexus @droftarts
                    @droftarts
                    so debuging futher to hardware level now
                    on GUI ive set fan 40% and VIN shows i have 24V on Duet2 board,....
                    when i measure voltage on Duex5 Fan3 port i get nothing there while Duex5 VIN has 24v measured, also Fan jumper is set to VIN
                    what could be wrong here? i tried fan speed 100% and no change
                      Have you verified the fan works by connecting it to an always on fan port?
                      If the fan does work, Ttry a different duex fan port?
                      If it works there, perhaps the mosfet on the original port is damaged.
                      • alexusundefined
                        alexus @Phaedrux
                        @Phaedrux which port is always on? also whats output voltage?
                          The Duet mainboard has 2 always on fans. Voltage depends on what position you have set the fan voltage jumper. Either 5v or VIN.
                          https://docs.duet3d.com/duet_boards/duet_2_wifi_ethernet_maestro/duet_2_we_wiring_latest.png
                          alexusundefined 3 Replies Last reply Reply Quote 0
                          • alexusundefined
                            alexus @Phaedrux
                            @Phaedrux
                            heh yea i just looked up documentation and yes always on worjs so we know fan works lol
                            well let me try to assign say fan4 port see what happens
                            • alexusundefined
                              alexus @Phaedrux
                              @Phaedrux
                              nope fun4 does not work either 😞
                              • alexusundefined
                                alexus @Phaedrux
                                @Phaedrux
                                interesting observation: when i disconnected tthermistor part cooling starts to spin on duex.fan4 port though speed control does not work. So port should be operable
                                  @alexus Can you post your current config.g, in full? I think there's a configuration error. Also what firmware are you using; post the response to M122.
                                  • alexusundefined
                                    alexus @droftarts
                                    @droftarts
                                    well i kinda gave up and used configuration tool and extracted code related to fan and heater and it started to work majically so i think problem was some where in letter configuration lol
                                    so now it looks like it wokring for fan parts at least 🙂
